  1. Feb 11, 2023 at 6:21 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    well now I need to rewire my Rago mount with a connector lol thanks
  2. Feb 11, 2023 at 8:05 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Right? :mad: I'll do it when I install my FRAC.
  3. Feb 11, 2023 at 8:31 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    I ordered mine over a month ago and was told its still on back order, still waiting.
  4. Feb 11, 2023 at 10:41 PM
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Mine was backordered almost a year!
  5. Feb 12, 2023 at 3:15 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    Are they a failure point? I could see it with vibrations. Did you solder all the connections?
  6. Feb 12, 2023 at 4:09 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    Items ordered:
    Engine skid - steel + 15% off
    Trans skid - steel
    cat guards - steel - (free w trans skid)
    Total shipped $778
    OHwendTrd likes this.
  7. Feb 12, 2023 at 5:01 AM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Hey. I had same issue with FRAC harness. It was acting weird and actually killed my battery. I just replaced it with anytime camera harness. All good now
  8. Feb 12, 2023 at 5:08 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Y'all let Lou know at FRAC. He will want to know about quality control issues with his harness.
    TundraTex likes this.
  9. Feb 12, 2023 at 5:13 AM
    Piki
    Piki New Member
    Yeah. I just pulled out and replaced it. Never looked back or complain.
  10. Feb 12, 2023 at 5:31 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    The peace of mind is worth it to ditch those t-taps. :thumbsup:
  11. Feb 12, 2023 at 6:34 AM
    SR5style
    SR5style New Member
    2019 MGM SR5 4wd Crewmax
    I just installed the RCI steel engine skid plate yesterday. It's well built, but man is it heavy in steel. Very happy with it.
    Didn't order the trans or cat plates, so no experience with them. I'm hesitant to put on a trans plate because I'm not sure I want to have to remove it for trans fluid changes.
    bulldog93 likes this.
  12. Feb 12, 2023 at 6:36 AM
    I would highly recommend it due to cat theft. It's not like you will be pulling in for transmission service all the time.
    cartage1 and Tundrastruck91 like this.
  13. Feb 12, 2023 at 6:46 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    What harness did you replace it with got a link?
  14. Feb 12, 2023 at 8:37 AM
    Sergicalmaneuver
    Sergicalmaneuver New Member
    So Cal
    2019 Platinum Crewmax
    Nice looking set up
  15. Feb 12, 2023 at 9:21 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The traditional t-taps and “scotchblocks” are damaging to the wire and the insulation - they can break stands (in already very small wires), cause weak spots, introduce an entry point for moisture, etc. The posi-taps are much better but are also bulky and can still potentially introduce a bind/kink point.
    In other cases, I am actually needing to cut or “hijack” a factory wire to re-route it through an alternative system - such as the auto-fold relay on my power mirrors, and the upcoming manual reverse light switch.
    So I have opted to make a break-out harness anywhere I am tapping or cutting factory wires, and then using solder joints for any splices an taps within those break-out harnesses.
  16. Feb 12, 2023 at 9:40 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    I'll second this. Cat plates at a minimum.
    cartage1 and Tundra234[QUOTED] like this.
  17. Feb 12, 2023 at 9:44 AM
    Piki
    Piki New Member
    Tundrastruck91 and bulldog93 like this.
  18. Feb 12, 2023 at 9:47 AM
    lunchbox
    lunchbox Im lost
    Killeen
    2018 TURD 4x4
    "Stock"
    Got a pretty gnarly pin stripe :mudding:
  19. Feb 12, 2023 at 10:05 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    How it it?
  20. Feb 12, 2023 at 10:09 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    So far since I added it the other day. It’s been charging my phone fine no problem. I definitely like having it because if I don’t need my phone plugged into the wire for GPS. I just put it in the console with my Apple Music on.
  21. Feb 12, 2023 at 10:41 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Thanks for the ideas. No skid plates here though.
    I have some SuperLube silicone grease so I will have to give that a try. Looks like the only areas will be between the bar and bushing on the 2 frame mounting points.
    Taco-Spike likes this.
  22. Feb 12, 2023 at 10:57 AM
    SAGE63
    San Diego County
    Thank you
  23. Feb 12, 2023 at 1:54 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Just re-tightened and checked all my Amp Power Step bolts. Also sprayed in lithium grease in the hinges to help with lubrication.
    It's been pretty cold here but over the last couple weeks, my power step deployment has sometimes stopped short of full deployment. Figured it can't hurt to lube those hinges up.
  24. Feb 12, 2023 at 2:04 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Np hopefully a little grease on those points does the trick for ya. Good luck and let us know if that does it.
  25. Feb 12, 2023 at 2:47 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    EZ install. The baggy has what was in my little organizer tray (pens, fire starter, loose ammo, pics of ex-gfs, you know the usual stuff)
    shawn3210, OHwendTrd, WFD473 and 5 others like this.
  26. Feb 12, 2023 at 2:47 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Woohoo! I'll wait for the detailed write-up to decide whether or not I follow ya down this little rabbit hole
  27. Feb 12, 2023 at 2:49 PM
    centex
    centex New Member
    Made it do truck stuff.
  28. Feb 12, 2023 at 3:16 PM
    What year is your K5? I had a 1981 with a 400 small block on a set of 33's.
    Taco-Spike and texasrho83 like this.
  29. Feb 12, 2023 at 3:44 PM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    IMG_0278.jpg Greased the rear drive shaft - The front does not have fittings. 55,000 miles on it.
  30. Feb 12, 2023 at 4:03 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Sexy lookin plow truck
    WFD473 likes this.
