  1. Feb 11, 2023 at 9:09 AM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    Did my first 10K oil change
    I'm normally a 5-6k interval, but have done a ton of long trips since Christmas for grand total of 8,000 mi since Christmas Eve. Being that it was all highway and I was running synthetic 5W-30 I wasn't too worried about going 10K.
    Oil came out not too dirty and still had good viscosity. Ran a strong magnet through the pleats of the filter and came up completely clean.
    I also finally remembered to install the magnetic drain plug I've had the last 2 years.
    I'm trying Castrol edge extended performance 5W30 for this fill will be interesting to see how it affects noise and fuel mileage.
    Last fill was the Pennzoil Platinum.
    80K in 5 1/2 years of ownership down, 200K and 20 more to go
  2. Feb 11, 2023 at 9:10 AM
    Bulldog9
    NOVA
    It's a good feeling ...
  3. Feb 11, 2023 at 9:11 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    We are officially car payment and mortgage free.
  4. Feb 11, 2023 at 9:12 AM
    Bulldog9
    NOVA
    Congràts! We're heading that direction too. We just paid off the mortgage on our primary home and have a year and a half left to go on the mountain vacation home. Perfect timing as I retire 2 years from now.
  5. Feb 11, 2023 at 9:13 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    If I remember correctly there are a couple spots on the sway bar installation that could benefit from a little synthetic grease. I think the trd rear sway bar when you purchase it even came with a little tube. Hit those bushing up lightly. If it's not that and you have the trd skid plate it could definitely be that too.
    Cthulhu and BlueRibbon4x4 like this.
  6. Feb 11, 2023 at 9:15 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    That's dope.:thumbsup:
    Our rate is so freaking low we may never try to pay it off early.
    Currently its been better for us to buy stock (SPY mainly) and sell covered calls every week.
  7. Feb 11, 2023 at 9:20 AM
    We don't use that function. Sorry.
    But...we give these out often...
  8. Feb 11, 2023 at 9:20 AM
    redrum448
    redrum448 New Member
    https://www.amazon.com/gp/product/B07HT1GCGV?ie=UTF8
    this is one of the cheap options... I actually only use the charging tray "pad" as I use these inserts everywhere else
    (the tufskinz tray pad is much thicker and doesnt work)
    https://www.tufskinz.com/collection...roducts/tun003-bucket-seat-foam-toyota-tundra
    and are 10 times nicer
    Clemsonman14, occruiser and bulldog93 like this.
  9. Feb 11, 2023 at 9:23 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Awesome. Thanks for the tip. Ad @mgm16trdpro said, you may wanna check the pro skid, if you have one. Mine was clunking until I used some nylon washers between the mounts.
    Cthulhu and AZBoatHauler like this.
  10. Feb 11, 2023 at 9:35 AM
    vilord
    vilord New Member
    Jesse
    2019 TRD
    I just paid mine off too. Only had the note a couple of weeks but at 8% I was not going to keep paying on that. Mortgage will have to go quite a few months with just the minimum...
    Getting the truck and trailer loaded up for the Miami trip. Thinking maybe I'll air up the 295's a lot (55/65 instead of 38/38? will see how it handles). Maybe the weight of the bed and trailer will keep if from being too bouncy, and hopefully eke out an extra MPG
  11. Feb 11, 2023 at 9:37 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Got Toyo R/T Trails 285/75/17’s a few days ago. Wheels are 701’s at 0 offset.C2B0421E-AE58-4E4F-82FE-F714651DE5DE.jpg
    GAknight, NightR8R, pvmike and 10 others like this.
  12. Feb 11, 2023 at 9:38 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
  13. Feb 11, 2023 at 9:45 AM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    Massive accomplishment. You should be very proud! Well done sir!
  14. Feb 11, 2023 at 9:52 AM
    SwitchThrottle
    My rates were low on the house and the truck (2.5%), but I hate owning anyone anything. House has been paid off for a couple years. Wifes Subaru was financed at 0%, so we ran that one to term and was paid off in 2022.
  15. Feb 11, 2023 at 10:17 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    Well I just got the replacement bolted up and did a test drive. For now, the Helmholtz is NOT going back on.
    OE muffler
    DD muffler
    OE tail pipe
  16. Feb 11, 2023 at 10:23 AM
    harrydunn
    harrydunn New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
    Family member traded in his '21 1794 so I bought items he had on it at different points for the massive family discount ha. TRD Pro wheels with 5K E-load ATs, TRD Off-Road wheels with 5k P-metrics and a Corsa cat-back system. Swapped everything in about 3 hours. This is my first set of black wheels so it is taking me a little while to get used to them. If I can't I'll slap the originals back on. If I like them long-term, I may swap the badges over to black. Not interested in swapping to body color bumpers and all of that jazz. I'm loving the way the Corsa sounds! Throaty with no drone which is what Corsa is known for obvs. He had the red TRD center caps and the gold TOYOTA center caps from the Heritage Edition Land Cruiser. The red TRD caps clashed with Inferno Orange soon I slapped the much more subtle LC caps on.
    67D5BAD9-51CB-408F-96CD-E9B5FC2321C5.jpg 7EF186DD-4B68-4C36-817E-BC5E3558639A.jpg 1DEF577B-10C2-4E86-9545-0948567514EB.jpg
  17. Feb 11, 2023 at 10:51 AM
    el_conquistador
    el_conquistador New Member
    Kansas City, MO
    2019 Toyota Tundra 1794 Edition
    Just a few
    Installed my front sumo springs this AM. I am going to do the rears once my new U bolts arrive from sparks.
    bulldog93 likes this.
  18. Feb 11, 2023 at 11:17 AM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Tripleconpanna likes this.
  19. Feb 11, 2023 at 11:28 AM
    ThatGuyTheCooler
    Those look great! Def get the black badges.
    harrydunn[QUOTED] likes this.
  20. Feb 11, 2023 at 11:59 AM
    SAGE63
    San Diego County
    reach out to keith @dirtydeeds
  21. Feb 11, 2023 at 12:07 PM
    ThatGuyTheCooler
    It's all good. I'm going to try without the resonator for a bit. Not his fault in the least. I ordered a new exhaust gasket and may try some aluminum foil wrapped around the pipes (under the clamp) to tighten it all up.
  22. Feb 11, 2023 at 1:34 PM
    twotrack
    twotrack New Member
    Clint
    Tampa, FL
    2015 Tundra SR5
    Installed the TRD sway bar today, you can definitely feel the difference. Can't wait to tow the trailer and see what it feels like.
  23. Feb 11, 2023 at 1:55 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    In continuing the electrical draw issue I’ve confirmed the alternator is good and nothing from the engine bay fuse block is causing the issue. I have a feeling it’s the shotty wiring done by the previous owner for the frac harness to the factory head unit. I’ll continue this search next week while the wifes out of town. Probably add the new headlights also.
    Moved the spare further back in the bed and added another hook. If we go camping then I’ll just push it back towards the cab. But for the majority of the time it’ll live here to keep that weight as far towards the rear as possible.
  24. Feb 11, 2023 at 2:52 PM
    SAGE63
    San Diego County
    ok updated OVS 270LTE pictures
    Wallygator, Jego, GAknight and 16 others like this.
  25. Feb 11, 2023 at 4:10 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Messed around with this trying to get my controls working again:
    After having the dash apart I only had cold and only on the windshield. I messed around with it all I had time and patience for. It moved the gears so I know it was lined up, but now nothing. Now I've only got heat and only on the windshield. I decided that'll have to do for now, but I need to get it sorted at some point. Another thing since I got my dash back together is the control screen only comes on after about a minute. :confused: I wish I never touched it. :frusty:
  26. Feb 11, 2023 at 4:18 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Decided to pick up a little something for putting it to work20230211_112853.jpg
  27. Feb 11, 2023 at 4:42 PM
    TRD_Ghost
    TRD_Ghost New Member
    17 Superwhite TRD Pro
    Job well done. I am about to do the same install.
  28. Feb 11, 2023 at 4:43 PM
    TRD_Ghost
    I like it. Do they make it without the bullbar? Super stealthy.
    RainMan_PNW likes this.
  29. Feb 11, 2023 at 4:49 PM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
  30. Feb 11, 2023 at 6:03 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Got my mirror “reverse” lights working again off the switch - replaced the power lead I had coming off my new distribution connector. There is no longer a single T-Tap connector anywhere in my entire truck with all of the add-on stuff that I have done. And I’m going to keep it that way moving forward.
    Revised the wiring on the Rago dash charger port to use a JST 2-pin connector for future access/disconnect.
    Put 0.020” (twenty thousandths) brass shim under the left screw of the Rago top plate to even out the gap to the dash along the back edge.
    And ordered the connector pair I need to make a break-out harness to hijack the rear reverse light power and run it through a SPDP relay to also work with the mirror reverse light manual switch.
