  1. Feb 10, 2023 at 10:36 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Interested too, @Cthulhu just made me a little nervous. I do too much Los Angeles freeway driving to worry about my truck’s handling on the freeway. I don’t have stock shocks, so they do a lot of work, but I need peace of mind too.
    AggiePhil, Cthulhu and RobertD like this.
  2. Feb 10, 2023 at 10:41 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Southbound on N. Padre out of CC; until we haven't seen people for at least a mile. Hopefully the fact that it's February and not high season will make the 'until we haven't seen people for at least a mile' possible. We're old guys, so we get a VRBO when we go 'glamping', so it's not a camping on the beach situation; and when we hit the beach will depend a little on how much whisky isn't left in the bottle from the night before; but it'll be the weekend of the 24th. If you're out there and see a big brown Shiny TuRD, flag us down.
    Dsptundra[QUOTED] and texasrho83 like this.
  3. Feb 10, 2023 at 11:34 AM
    AZBoatHauler
    So.Arizona
    If you guys don’t hear from me by dinner time safe to say it didn’t do well. ;)
  4. Feb 10, 2023 at 12:38 PM
    Azblue
    The Dirty T ( ^_^)_且
    You will be fine.
    But if not, I call dibs on your coolest stuff.
  5. Feb 10, 2023 at 3:15 PM
    AZBoatHauler
    So.Arizona
    :fistbump:
    Thankfully (or unfortunately for @Azblue) I made it without any issues. Slightly more body roll going through high speed curves and needed a little more steering input with a tiny bit looser feel if that makes sense. Essentially feels like driving with the a slightly softer suspension IMO which I’m good with.
  6. Feb 10, 2023 at 3:40 PM
    BlueRibbon4x4
    Geno
    Nice! Glad you made it. I’m ok with all that.
    Cthulhu and AZBoatHauler[QUOTED] like this.
  7. Feb 10, 2023 at 9:50 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yesterday, I did this:
    Today, I put it all back together, with a few tweaks and prepping for a few more…
    Reinstalled the ECU and instrument cluster for my parking sonar (long story)
    Rago dash plate installed
    Added a on/off switch for my power mirror auto-fold
    Removed every single t-tap that had ever been installed and replaced with break-out harnesses and in a few cases new fuse-taps with multi-line distribution for future tapping
    Added MESO extended fuse box cover
    Prepped for manual reverse light over-ride (turn on all the reverse lights with a switch in addition to standard function)
    Prepped for VSC auto-off setup
  8. Feb 10, 2023 at 9:51 PM
    Taco-Spike
    Two Trucks
    Does the mirror control illuminate?
    Tripleconpanna likes this.
  9. Feb 10, 2023 at 9:53 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :rofl::rofl::rofl:
  10. Feb 10, 2023 at 9:53 PM
    Tripleconpanna
    I just want to know if he can get rid of my connected services :D
    Taco-Spike[QUOTED] likes this.
  11. Feb 10, 2023 at 9:56 PM
    Taco-Spike
    Two Trucks
    AggiePhil and the red like this.
  12. Feb 10, 2023 at 10:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    No.
    I’ve exhausted pretty much every option there short of cutting open the switch and trying to hack something inside of it.
    The control switch from a European “Auris” (their corolla) has it’s own micro-processor built into the switch (it is a 28-pin connector) - it isn’t made to handle the sort of power draw that the bigger mirrors need. I tried - sourced one, wired it up, bench tested the function, then installed it and nada - it will trip itself before it actually fully moves the mirror in any way. Even trying to swap guts and other parts won’t work - they are completely and utterly different inside and even the buttons and parts aren’t compatible.
    The KJTO option (if/when they have it) uses this particular switch. And it won’t work in a Platinum/1794 at all because they use their own ECU in each door to actually control the mirrors (part of the memory function).
    I thought I had found one that would work from a Japanese Prado, but it ended up being just enough the wrong shape and size that it couldn’t be made to fit.
    So, unless someone starts making on in the aftermarket market, I do not see any options for it.
  13. Feb 10, 2023 at 10:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I’ve been through that thread many times too - having green illumination would drive me nuts and I wanted to have upper illumination too. I may revisit it again some day…or not. I really don’t fuck with my mirror switch very often, especially having the auto-fold set up.
  14. Feb 10, 2023 at 11:08 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I ordered some that were a little thicker almost like a gel sticker. But like mentioned only blacked the front out and left the sides silver which to me looks fine
  15. Feb 11, 2023 at 4:49 AM
    ThatGuyTheCooler
    ThatGuyTheCooler New Member
    Not happy with my current set-up so going to put the stock tail pipe back on. I got this for free on FB. It's from a 4.6L but I believe it will work. I just hit it with the wire wheel and sprayed with Rust-Oleum bbq paint.
    The OE tail has a tip, which now looks like crap, and the Helmholtz resonator which has been nothing but a PITA
  16. Feb 11, 2023 at 4:51 AM
    biebs96
    PA
    What’s the problem with the Helmholtz?
  17. Feb 11, 2023 at 6:05 AM
    ThatGuyTheCooler
    It keeps resting on the spare tire no matter how tight I get the clamp. This then turns the tip upward and it rests on the rear bumper. Heat + paint/rubber is not good. Its burned a nice mark in the tire already. Since the DD pipes are not 'keyed', the tail pipe is free to rotate
    bulldog93 likes this.
  18. Feb 11, 2023 at 6:12 AM
    AZBoatHauler
    So.Arizona
    :confused:
    Can you send a pic of this “key” on the OEM setup?
    biebs96 likes this.
  19. Feb 11, 2023 at 7:00 AM
    centex
    centex New Member
    Couple of tack welds would solve that twisting problem I would think. Or maybe a hanger on the resonator to support it?
  20. Feb 11, 2023 at 7:30 AM
    redrum448
    redrum448 New Member
    I had a galaxy S9 with Zero charging issues and when I went to a S21 ultra I was getting the charge-no charge-charge error too till I (by accident) found if i put this "pad " in the console it charges just fine now
    Just a FYI ( @1UP )
    GAknight, Blowdart, cartage1 and 4 others like this.
  21. Feb 11, 2023 at 7:32 AM
    redrum448
    Android is NOT wired only.....
    This is wireless FYI
  22. Feb 11, 2023 at 7:34 AM
    Sergicalmaneuver
    Sergicalmaneuver New Member
    So Cal
    2019 Platinum Crewmax
    My charger has been hit or miss. Might have to try this idea
  23. Feb 11, 2023 at 7:50 AM
    Sergicalmaneuver
    So Cal
    Nice looking set up. I’ve been looking at a Wolf Pup as well. For a while just haven’t committed
  24. Feb 11, 2023 at 8:14 AM
    biebs96
    PA
    maybe a photo of the clamp tightened down as well. I thought mine was snugged, but an impact driver got another almost 1/2” of threads tightened down.
    AZBoatHauler[QUOTED] likes this.
  25. Feb 11, 2023 at 8:37 AM
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    Want to sell the resonator?
    biebs96 likes this.
  26. Feb 11, 2023 at 8:49 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Hoooooooly Shit! It freaking works.
    Bruh..... Thank you. :cheers:
  27. Feb 11, 2023 at 8:53 AM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Where did you get the pad? My iPhone 8 charged no problem but my 13 is flakey.
  28. Feb 11, 2023 at 8:57 AM
    1UP
    1UP Truck Gang
    Tundrastruck91 and ColoradoTJ like this.
  29. Feb 11, 2023 at 9:06 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I ran without my front sway bar for a couple years and it was fine. Just a little more leaning on turns. Once I installed the supercharger, high speeds on highway (85+) and “very accelerated” runs on the highway made the truck sway side to side (hard to describe but like a quick rocking left to right). Not a safe feeling and I ended up putting the front sway bar back on. It fixed the high speed swaying.
    Now I have some kind of clunk that is definitely coming from sway bar reinstallation. I’ve been under the truck to tighten, loosen, whatever and can’t get it to go away.
  30. Feb 11, 2023 at 9:09 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Well...all the "I paid it off" posts inspired me. I chatted with the wife and she agreed we should go ahead and do it, so today she went down to the bank and...PAID IT OFF.
    :yay:
    Tyman, PlaysARobin, wiltech and 30 others like this.
