  1. Feb 7, 2023 at 4:22 AM
    At least the fog lights match.
  2. Feb 7, 2023 at 5:37 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If I drove the Tundra more than once a month in the dark I'd drop cash on some projectors.
    Compared to the Altima it feels like I've got 2 flashlights stuck on the hood. Not good ones either those plastic Eveready shits you could buy for $2.
    Siebler, shifty`, bmf4069 and 5 others like this.
  3. Feb 7, 2023 at 5:40 AM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Ah yes, the story of my childhood:
    Siebler, NUDRAT, shifty` and 3 others like this.
  4. Feb 7, 2023 at 5:42 AM
    I referred to mine as coal miners lamps. They sucked. New lenses and the harness with 85/100w bulb upgrade woke them right up. Did the 9006 fog light mod as well. Lots of light now
  5. Feb 7, 2023 at 5:54 AM
    kieljon
    kieljon New Member
    Southeast US
    2005 Double cab 4x4 TRD
    Oh man! I had the exact same in blue. Just told my kids last week about how I used to keep my savings stashed inside. Think I had about $150 of cash rolled up in that thing when I was around 10. Thought I was RICH! :rofl:
    oscardog86, NUDRAT, shifty` and 2 others like this.
  6. Feb 7, 2023 at 7:21 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    So after getting the skid plate off, took some time to inspect a little better. looks like these CV axles have been replaced (assuming that’s a date code). Some surface rust I need to attend to. CV boots leaking was a known issue (one threw a lot of grease, the other just one drop), but hard to see what the issue is - not cracked and the clamp isn’t loose. Anyway, here are some pics under the old gal’s skirt:
  7. Feb 7, 2023 at 7:34 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    No, that pink tag with the part number is normal for original OEM CVs. I'd be willing to bet they are the originals and have never been replaced.
    If you don't want to go through the trouble of re-booting and re-greasing them, you should be able to find a dealer local to you that sells re-manufactured CV axles for $80ish per side, plus a $75 core charge. If you turn in your old CVs when you buy the remans, you get your $75 core charge per side back.
    The reman part number is 43430-0C010-84. They MSRP for $115, but participating Toyota Parts Program dealers will sell them for less.
    More info on the remans here: https://www.tundras.com/threads/front-cv-axle-recommendations.110714/
  8. Feb 7, 2023 at 12:03 PM
    WhatsUpDoc
    WhatsUpDoc New Member
    WNC
    2004 Tundra DC 4x4 PGP Limited
    16" FJ Wheels Bilstein 5100's Flowmaster Exhaust Camper Top Upgraded Sound System with (2) 8" subs under back seat
    What Decked system are you using?
  9. Feb 7, 2023 at 12:46 PM
    Twist that dagger some more, breau! :rofl:
    There's some flashback nostalgia. We also had a yellow and black, I think Eveready brand that was way better.
    bmf4069[QUOTED] and FrenchToasty like this.
  10. Feb 7, 2023 at 4:14 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I think this is the date code OP refers to:
  11. Feb 7, 2023 at 5:23 PM
    It's not a US date format. I think it's 2001.
    Jack McCarthy, des2mtn and lsaami like this.
  12. Feb 7, 2023 at 5:35 PM
    des2mtn
    SW
    Tonto cover
    Either way, that's the ADD tube and it shouldn't need replacing unless the 4WD is totally screwed up.
  13. Feb 7, 2023 at 7:15 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Changed the oil today, as well as trans drain and fill, and throttle body/MAF clean off. "Reset" the ECU. See if there's any difference in gas mileage.
    Wanted to do the Griots garage plastic treatment but didn't really have time and it's supposed to rain so I'll put that off for another day.
    oscardog86, bmf4069, des2mtn and 3 others like this.
  14. Feb 7, 2023 at 7:19 PM
    How did the trans fluid look?
    JasonC. likes this.
  15. Feb 7, 2023 at 7:19 PM
    Looking forward to seeing what your result is. I was near-end of a tank when I did it, went through a full tank learning the first bit, and on the 2nd full tank after I know everything re-learned, saw my mileage jump. I know my truck saw a veritable crapton of dusty roads daily, though.
    JasonC. and FrenchToasty like this.
  16. Feb 7, 2023 at 7:22 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Same. Raining here. :/ Waiting for it to dry up for that and the Cerakote headlight kit.
  17. Feb 7, 2023 at 7:26 PM
    NickB_01TRD
    KY
    Missed this quote in my last reply.
    What aftermarket headlight housings are you running? No random light throw or anything like that? Like I mentioned recently my headlight harness upgrade and new bulbs were pretty mediocre.
    It looked like good red fluid. Smell was a little off though. This was my 3rd drain and fill I've done but the first one in a little while. No immediate change in shifting performance. Hasn't been any change the last 2 times either.
    In all honesty though I never calculate my MPG just check how many miles I get to a tank. My trip odos reset when I unhooked the battery so it'll be a while before I see anything out of it.
    Probably going to "torch" my front bumper plastics then coat them after. I've done the torch method twice and it usually just fades right back so maybe this really good Griots plastic restorer will keep it looking better. If not I'm either replacing or painting them.
  18. Feb 7, 2023 at 7:39 PM
    Generic OEM knockoffs. Actually reused my factory adjusters on the new housings due to the new ones being pitiful. Since I went 85/100w bulbs, I went with the relay harness upgrade to prevent melting my chintzy factory wiring. Light output improved dramatically. The fog light upgrade was money too.
  19. Feb 7, 2023 at 8:02 PM
    NickB_01TRD
    KY
    Just wondering if you recall a specific brand.
    I've done the exact same upgrade (I think with the exact same parts and all) and I'm not impressed I think my cleaned and clear coated headlights have more of a haze on them then it appears and that may be causing my issues.
  20. Feb 8, 2023 at 4:21 AM
    I use Road Trip LE. It was free if you only use it for one vehicle. You input the mileage, gallons, total at every fill up, it calculates your MPG and gas price. Takes 20 seconds. It does the rest. Interestingly, the calculator helped me to realize I overpaid for gas almost a dollar because the pump wasn't pumping right. Filed a complaint, got a refund.
    JasonC. and NickB_01TRD[QUOTED] like this.
  21. Feb 8, 2023 at 1:30 PM
    Any know if the plastic clips just pop off or can they get easily destroyed doing it?
  22. Feb 8, 2023 at 3:27 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Huh.. I think the original black grille was better.
  23. Feb 8, 2023 at 3:47 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Yeah, it was definitely a judgement call, and I had votes on both sides before I made the change. I still have the original, and it’s just six bolts to swap out, so I can always go back. I don’t think either looks bad, just a matter of preference.
    Eventually I’ll have some lights installed on the front bumper, and the grille will likely be so obscured that it will render the issue moot.
    oscardog86 and FrenchToasty like this.
  24. Feb 8, 2023 at 5:23 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I like the modern look of the new one. Wish they came in white though
    TravisJr[QUOTED] likes this.
  25. Feb 8, 2023 at 6:37 PM
    They do, you just gotta pay to have 'em painted.
    CodyP[QUOTED], RUSTYNUTS and TravisJr like this.
  26. Feb 8, 2023 at 8:34 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Yeah, any paint shop should be able to paint match that for you pretty reasonably. I’ve considered running the TRD one out to my paint guy to color match it to the gloss black, but for now I’m sticking with the matte look.
    shifty` likes this.
  27. Feb 9, 2023 at 7:13 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
  28. Feb 9, 2023 at 7:19 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Guy is several hours into my timing belt and today. Here are progress photos:
  29. Feb 9, 2023 at 7:29 PM
    Just make sure that crank position sensor wire gets tucked back away properly.
    oscardog86, hammeron, bmf4069 and 2 others like this.
  30. Feb 10, 2023 at 8:08 AM
    Hummer
    Hummer New Member
    2023 Tundra CrewMax Limited 10K miles
    Studs Baby, Studs!
    I want a matching chrome name badge that reads "Best Gen", to place above the Toyota Tundra badge. A decal would be okay, too, I suppose.
    hs6056J5eIAENRIYuuz3XoV4PZqQYAs6dfQEynH2_419f6573cf2a10e634bc439633f7751316f9441b.jpg
    oscardog86, bmf4069 and txagg like this.
