  1. Feb 5, 2023 at 7:06 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Me too.
    shifty`[QUOTED] likes this.
  2. Feb 5, 2023 at 7:35 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Pulled the skid plate and plastic covers that go on the side and scrubbed em down with soapy water and a scrub brush. Broke off one screw, going to have to drill that one out.
    Now to decide whether to repaint this.
    txagg, oscardog86 and Jack McCarthy like this.
  3. Feb 5, 2023 at 7:42 PM
    Jake92
    Jake92 New Member
    2000 Toyota Tundra SR5 4x4 TRD
    Thank you I just ordered this and will report back when I get it and use it. I also switched the grill to a different grill as well. That’s for the information about the restoring of the trim
  4. Feb 5, 2023 at 7:46 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    I guess I have never really given it any thought, but what exactly does that piece of foam thing do on the skid plate? The first time doing an oil change I thought the previous owner had left it here to soak up some sort of leak, but then I realized it belonged on the plate and haven't thought about it since. Any answers?
    w666 likes this.
  5. Feb 5, 2023 at 7:49 PM
    I think it tucks up to the radiator to kinda seal the air flow, and making it go thru the rad Vs under or over it(there’s one up top too)
  6. Feb 5, 2023 at 7:53 PM
    It's not that expensive to buy new, but if you get some Rustoleum "satin" outdoor spray paint (link) it matches the factory look perfectly and you can lay it over rusty stuff if you really want. This is the stuff I've been using on frames for 15-20 years now.
    I got a rusty as hell, soil-packed, weeds growing in it, surface rusty skid plate from one of the later-gen guys in my area, and hit it with that. This was the result, and it still looks like this after being outdoor in the rain and sleet of ATL winters: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1440#post-2918238
  7. Feb 5, 2023 at 7:53 PM
    This ^^
    And you don't want to look up what Toyota charges for that block of foam :rofl:
    (it's seriously ludicrous)
  8. Feb 5, 2023 at 8:27 PM
    Jake92
    Jake92 New Member
    I got some. It should be delivered Tuesday and will report back when I use it. :)
    shifty`[QUOTED] and NUDRAT like this.
  9. Feb 5, 2023 at 9:33 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Saw a bottle of Mr. Pink in the returns warehouse of the large women jungle @ 1/2 price. Bought it. When it arrives it will sit about uninstalled in the foam cannon, which will not be washing any vehicles for awhile. it's still winter in the new Englands.
    All the talk earlier about lubricating stuff reminded me to add some other product to my cart (Not Franks R.H.) that won't go unused.
  10. Feb 5, 2023 at 9:35 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Take a before shot. and a mid point. you'll get sucked in by it's wowness.
    shifty` and Jake92[QUOTED] like this.
  11. Feb 5, 2023 at 9:48 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
  12. Feb 5, 2023 at 10:41 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    Got out this weekend and finally wired up the winch (I’d been waiting on the solenoid relocation kit forever.) The main power cable was a little too short to route cleanly, so it’s just draped in the engine bay until I can find an extended one. Threw on a Factor 55 Flatlink for good measure.
    Also installed a TRD grille. Was a little hesitant to replace the one I had color matched during the repaint, but really like the way it came out. Got a tri-color heritage badge in a gold colorway to complement the wheels.
    Starting point:
    Finished (for now) product:
  13. Feb 6, 2023 at 12:19 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    A trans drain and fill isn't a bad idea but hard shift from 1 to 2 in 4Lo is normal. Theres just so much load when switching gears that's how it works.
  14. Feb 6, 2023 at 4:12 AM
    bfunke
    bfunke Tundra Curmudgeon
    The skid plat on my 2000 is fiberglass. Now that it’s 22 years old it sheds some fibers when removing and makes my arms itch. I wonder if I could spray it with something to lock in the glass fibers
  15. Feb 6, 2023 at 10:12 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Had a can on the way already and planned to paint it, but it kept getting delayed, so I threw the skid plate in the bed. Yesterday I dropped the truck off with a local Cruiserhead who's going to do the timing belt and water pump (has worked on a lot of 4.7s because of the 100-series LC -- actually had an Aisin TB kit on the shelf), and will also throw new LBJs on. While she's opened up -- and yes I have read this thread -- I wonder if there's a definitive list of what else would be good to knock out? Upper and lower rad hoses look and feel great. Thinking t-stat and gasket, serpentine belt, spark plugs, belt tensioner pulley.....what am I missing?
  16. Feb 6, 2023 at 10:20 AM
    How many miles again?
    Just make sure the LBJ are OEM, and it's not ideal to re-use bolts. Unless you like seeing your wheel stuffed up into your fender or laying horizontal.
    JasonC.[QUOTED] likes this.
  17. Feb 6, 2023 at 11:03 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Yes, definitely will do on the OEM parts. I need to remind him about the bolts. Just hit 43,000 miles on the way to drop it off for the TB. Was an older gentleman's hunting/fishing vehicle.
    Can't wait to get it back and try out your paint correction advice! Definitely metallic paint. My fear is that it's the two-stage you mentioned and the clear's gone in those spots, but will definitely report back once she's had the major mechanical items sorted -- my first priority.
    abcinv likes this.
  18. Feb 6, 2023 at 12:09 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Man I am glad to hear you say that. I have never had an auto transmission 4WD vehicle, so just assumed it was something wrong. Really appreciate the feedback, love this site!
  19. Feb 6, 2023 at 6:05 PM
    dropindeuces
    dropindeuces New Member
    Just got her back from the shop with new set of BFG K02s. 285/70/17. Leveled the front and had to throw on some 1.25" spacers due to tires rubbing against the upper control arms.
  20. Feb 6, 2023 at 6:28 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    mix up a little resin, a little hardner, recoat as necessary. Paint to your purdy.
    How to Fiberglass: 14 Steps (with Pictures) - wikiHow
    oscardog86 likes this.
  21. Feb 6, 2023 at 6:36 PM
    oscardog86
    oscardog86 New Member
    Southern California
    wow truck looks great and thats gotta be one of the best looking front bumpers ive seen for a FGT!
    RUSTYNUTS, JasonC. and FrenchToasty like this.
  22. Feb 6, 2023 at 7:25 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Thanks man! That’s an Addicted Offroad bumper that I had painted to match the truck. I really like the design - it’s beefy enough to be functional, but slim enough that it doesn’t look like overkill on a smaller sized truck. It was definitely worth the wait.
  23. Feb 6, 2023 at 7:47 PM
    oscardog86
    Southern California
    Although isnt that the company that wouldnt send you the bumper as a kit, and also didnt leave the light mount tabs unwelded for you to do yourself? Thats kinda lame. But the bumper is still amazing.
    Funny how a company not willing to help out a customer when its no extra work on their part ends up creating negative talk about them in the end. Probably couldve been more acommodating to you
  24. Feb 6, 2023 at 7:51 PM
    That was me.
    I wasn’t a fan of the plate style, no one makes a “great” looking FB for our trucks. I wasn’t a fan of coastal after I did the rear from them. I settled on to tacticool tubular from them(addicted) And binford5k it.
  25. Feb 6, 2023 at 8:28 PM
    Those headlights stab me in the heart a little each time I see 'em.
  26. Feb 6, 2023 at 10:08 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Sucked it up and dropped her off at the local shop for a remote start in the morning. With the Jeep in the garage it will be nice to have it in the winter since it sits outside most days. And my wife/in-laws went in to give me birthday money for it so I figured now is the best time.
    oscardog86, RUSTYNUTS, txagg and 2 others like this.
  27. Feb 6, 2023 at 10:31 PM
    TravisJr
    TravisJr New Member
    Lots o’ mods
    Thanks for clarifying that - I was totally lost.
    Overall my experience with Addicted was painless, but I can understand the frustration if you couldn’t get it the way you wanted it. My fabrication skills… don’t exist, so I was just buying off the rack.
    oscardog86 and RUSTYNUTS like this.
  28. Feb 6, 2023 at 11:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Lunch time Ghosties!
    txagg and bmf4069 like this.
  29. Feb 7, 2023 at 2:37 AM
    POR-15 Semi-black FTW. Gets rid of the edge rust.
  30. Feb 7, 2023 at 4:08 AM
