  1. Feb 4, 2023 at 1:54 PM
    Icepuddle
    Icepuddle New Member
    Kris
    North Idaho
    03 AC SR5 TRD 4x4
    Come on up, make sure to bring beer ;)
    RUSTYNUTS, oscardog86, CodyP and 2 others like this.
  2. Feb 4, 2023 at 2:06 PM
    Riverbend
    Riverbend ISO - 2022 TRD Trail Edition Bronze 16" Wheels
    Darren
    Birmingham, AL
    2006 Toyota Tundra SR5 DC 4WD
    abcinv, I am looking for just this truck. Please let me know if you post this vehicle for sell in the next 4-6months. I sure I am not the only one...haha
  3. Feb 4, 2023 at 8:33 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Replaced the six-disc changer and factory amp with a Boss head unit to get hands free calling and Bluetooth stuff; waiting on the tailgate handle with backup camera to come in from Master Tailgaters so I Can have rearward visibility (not great with the cap). Prewired Crutchfield harness totally worth the $25.
    Rear window replacement hinges came in, hope to get those in tomorrow.
    BFG ATs tire codes are March of 2007.
    Really got a chance to drive it for the first time since the long drive home; 4LO and 4HI engage well and no weird noises, but 4LO does have a noticeable jump between 1 and 2 gear. Drain and fill trans case fluid may be in order.
    mcharfauros, Jack McCarthy and NUDRAT like this.
  4. Feb 4, 2023 at 9:06 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Nice. What brand is that? I assume no longer available. Saw a local listing on Craigslist with one made by Ranch Hand, also NLA for 1GTs.
  5. Feb 4, 2023 at 9:19 PM
    Icepuddle
    Kris
    North Idaho
    03 AC SR5 TRD 4x4
    It's pending, I'll let you know if it doesn't sell. I just told some dude the same thing, and he offered $200. I'm not Ebay and standby my word, those kinda people piss me off, those that offer more and those that except!
    flyfisher, JasonC. and oscardog86 like this.
  6. Feb 5, 2023 at 8:24 AM
    Has anyone tried to grease the little wheels that turn the heat/fan knobs? It looks like you have to pull these tabs over for the black part to slide out. Curious what lube you used.
    Filthyphil likes this.
  7. Feb 5, 2023 at 9:05 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I haven't but I would just make sure the grease you use doesn't get liquidy in the heat and start dripping everywhere this summer.
  8. Feb 5, 2023 at 9:28 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Haven't. Think I'd try to find success with powdered graphite.
  9. Feb 5, 2023 at 9:30 AM
    Yeah I had that assembly replaced back in 03, some sort of thick off-white grease. Just a dab of it per dial. No bending of tabs to get that out though.
    IIRC, you push it back and twist downwards to pull out?
    oscardog86 likes this.
  10. Feb 5, 2023 at 9:34 AM
    Some bracketry yesterday
    bmf4069, oscardog86, des2mtn and 3 others like this.
  11. Feb 5, 2023 at 12:25 PM
    I typically use clear SuperLube grease with PTFE in it, the clear stuff, it's NGLI and food grade. Same stuff I started using when rebuilding espresso machines. You can put it pretty much anywhere, temp range is like -40 to +250 F or something.
    PHM did a great write-up on how to lube the cables and gears which makes those knobs turn easier. I can find and link up if you come up short on locating it yourself. I've posted the links in a couple of vent posts here, I think if you look for my n....
    Nevermind, here it is, even you replied on it :D: https://www.tundras.com/threads/vent-control-binding-solved.58386/
  12. Feb 5, 2023 at 12:26 PM
    Yeah that’s what the plumbers use for valves and seats on faucets. It’s good stuff!
    DaBoro54 likes this.
  13. Feb 5, 2023 at 12:34 PM
    Totally!
    The stuff I use for food grade stuff, anything with rubber seals and sometimes gearing is p/n: 56204 (link)
    The stuff I use for mechanical (and also OK for 'incidental' food contact) is p/n: 41160 (link)
    I'm sure they have a wider array of stuff out there, and smaller/larger sizes. My bench downstairs has several tubs of grease, I've just gotten used to needing different types for different stuff.
  14. Feb 5, 2023 at 1:53 PM
    When I worked at McDowells the ice cream machines had to be assembled with special grease from the manufacturer, pretty sure it was just rebranded super lube, I’ve still got a tube or two
    txagg, oscardog86 and shifty`[QUOTED] like this.
  15. Feb 5, 2023 at 2:11 PM
    bfunke
    bfunke Tundra Curmudgeon
    I get tubes of SuperLube from my pool supply store. I had a big one from Arizona that lasted 20 years. Now I get the little tube that lasts 3-4 years.
    shifty` and FrenchToasty like this.
  16. Feb 5, 2023 at 4:15 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    drove the tundra to pick up a new farm truck. 1988 F250 7.3 IDI with a Banks turbo kit. 5-speed Manual and 4x4.
    bmf4069, txagg, oscardog86 and 7 others like this.
  17. Feb 5, 2023 at 4:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I use dielectric grease for errythang like at. Never gave a fuck about carcinogens, nor grades really unless it's driveshaft, SPC related.
    Any lube is better than no lube. Even if it's the wrong lube. Better than going in dry. :wink:
  18. Feb 5, 2023 at 4:35 PM
    I use moly grease for everything.
  19. Feb 5, 2023 at 4:37 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    was the chicken part of the deal?
    bmf4069, NUDRAT and FrenchToasty like this.
  20. Feb 5, 2023 at 4:38 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Ha! nope. That sucker is worth more than the truck is right now.
  21. Feb 5, 2023 at 5:06 PM
    Spit: Nature's lube.
    Unfortunately it won't keep my gears from grinding.
  22. Feb 5, 2023 at 5:15 PM
    Coconut oil is natural too….. it’s like franks red hot, I put that shit on everything
  23. Feb 5, 2023 at 5:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    that might be odd in bed.
    bmf4069 and Azblue like this.
  24. Feb 5, 2023 at 5:17 PM
    Hahaha it’s actually not, and leaves you moisturized……….. is what a friend told me:anonymous:
  25. Feb 5, 2023 at 5:34 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
  26. Feb 5, 2023 at 5:37 PM
    Azblue
    The Dirty T ( ^_^)_且
    And adds a nice tropical scent to the air, makes you feel like you're drinking a pina colada on a beach while getting laid.
    bmf4069 and FrenchToasty[QUOTED] like this.
  27. Feb 5, 2023 at 6:58 PM
    Jake92
    Jake92 New Member
    2000 Toyota Tundra SR5 4x4 TRD
    Put a new all black
    Cool grill on the old girl. The neighbor named her Tammy so I guess her name is Tammy the Tundra
    bfunke, bmf4069 and oscardog86 like this.
  28. Feb 5, 2023 at 7:00 PM
    Now get a bottle of this for your plastics :rofl:
    (It actually does work)
    NUDRAT likes this.
  29. Feb 5, 2023 at 7:02 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Post about spending moneys...
    Forum: Here, now that you did that, buy this....
    :spending:
    bmf4069, NUDRAT and oscardog86 like this.
  30. Feb 5, 2023 at 7:02 PM
    This hurts. I don't want to add up the $$ in uninstalled/unused parts I have laying around. Too painful to think about.
    Tundra2[QUOTED] likes this.
