Add a sub to the JBL system
Discussion in '3rd Gen Tundras (2022+)' started by pal9000, Dec 17, 2022.
  1. Dec 17, 2022 at 5:29 PM
    pal9000
    pal9000 [OP] New Member
    2023 Tundra TRD pro
    Westcott lift with 37 bfg km3s Kicker HS10 x 2 PPF
    Hey…first post. Thought I would share how I added subwoofers to the JBL system. Not too much info out there for JBL systems so hopefully this helps someone. As far as I know there isn’t a wiring harness so you’ll have to tap into a speaker input. I chose the low level signal going to the sub. See pics…. Its very easy to get to. Just pull off the stock sub enclosure. Don’t worry if you break a plastic clip or 2…they’re pretty flimsy. Then you’ll find the plug going to the sub which has 4 wires (brown, green, black and grey). I carefully exposed about 1-2 inches of each wire and soldered my amps input wire there. The JBL sub is 2 channel which they designate as WF1 (brown + and green -) and WF2 (black + and grey -). I chose 2 kicker hs10s for my subs which have left and right inputs so I treated WF1 and WF2 as “left” and “right.” Running the power wire was fairly easy. I used the grommet in the passenger side fire wall and got power from the fuse box under the hood (see pics). Ground supplied by bolt behind the seat. I made a platform for the subs from 1/4 mdf and covered it in back carpet. Running the sub control was very straightforward but the only downside is that you need 2…connecting both with a 1/8 splitter does not work. I think it came out pretty nice and it sounds amazing. Way more bass than I need.
  2. Dec 17, 2022 at 5:33 PM
    pal9000
    2023 Tundra TRD pro
  3. Dec 18, 2022 at 8:41 AM
    osu1978
    osu1978 New Member
    Thanks for the info and pics. Are you running the Westcott TRD Pro lift? How do you like it?
  4. Dec 18, 2022 at 8:59 AM
    pal9000
    2023 Tundra TRD pro
    Yes running the Westcott lift. No issues so far. Truck seems to ride the same as before. Got the black anodized aluminum version (only took a few weeks) and can't even tell its modified. Its very high quality. Bought km3s since they run a little small but still rubs slightly at full lock on that useless safety bump. I did remove the bracket that holds the liner in place in the front wheel well and pinned it back using body clips I bought at home depot. That took about 20 min. You will also need to remove the front mud flaps. I did nothing to the rear and have about 1/2 inch clearance from the rear mud flaps. I may take it to a shop to cut off those bumps in the front wheel wells. Truck looks way better with 37s.
    iiawah808 likes this.
  5. Dec 18, 2022 at 9:28 AM
    osu1978
    osu1978 New Member
    I am waiting on an mgm or solar Pro. Probably going with Baja Boss 305/70r18 which are 35.3” x 12.2”. Do you think I will have any rubbing with the Westcott lift?
    Pumped about the slim Kicker 10” as I was originally going for the jbl 8” but the kicker seems like a better deal.
  6. Dec 18, 2022 at 9:37 AM
    pal9000
    2023 Tundra TRD pro
    No shouldn’t have any rubbing at all. You’ll still have to make the mods in the front wheel well (pin liner, etc) but that annoying safety bump shouldn’t be an issue with 35s. Solar is very bright. I had mine next to one at the dealer and it was super bright…like orange. Personally I think the grey looks way better. But that’s just my opinion. Yeah I was originally going to get the jbl sub but its only like 100 watts with a 6x8 sub… Kicker is way more powerful. If you plan to install one then no need to make a platform…it’ll fit vertically right next to the stock sub. I had one installed like that initially.
  7. Dec 18, 2022 at 10:04 AM
    osu1978
    osu1978 New Member
    Thanks for all the info!
  8. Jan 4, 2023 at 11:36 AM
    MateoAirborne
    MateoAirborne New Member
    Mateo
    2023 iForce Max 1794 TRD Off Road Package
    Following!
  9. Jan 7, 2023 at 6:43 PM
    99ways2die
    99ways2die New Member
    OP:
    Did the "dc offset" remote power-on work for you (did you even try it?), or did you have to wire up the standard/separate remote-on wire?
    Thanks.
    -99
  10. Jan 7, 2023 at 7:40 PM
    Descend
    Descend New Member
    North West
    '23 Tundra TRD Pro MGM
    Forgive my ignorance but are there any plug and play options if you just want to replace/upgrade the oem JBL sub?
    Jodster71 and MateoAirborne like this.
  11. Jan 11, 2023 at 8:17 AM
    Max713
    Max713 New Member
    Edit: Answered my own question
  12. Jan 14, 2023 at 4:15 PM
    Max713
    Max713 New Member
    Just did this to my truck after seeing this thread. I went with just one sub in the factory location. Significant improvement over stock, and an easy install.
  13. Jan 14, 2023 at 5:13 PM
    99ways2die
    Did you disconnect, and remove the stock subwoofer?
    What did you use for "remote ON" on the Kicker powered sub?
    Thanks.
    -99
  14. Jan 14, 2023 at 5:36 PM
    Max713
    Max713 New Member
    I removed the stock woofer… it does absolutely nothing and I wanted to maintain the little behind the seat storage there is on the other side
  15. Jan 14, 2023 at 7:18 PM
    rss29
    rss29 New Member
    22 WCP DC LTD
    When only using a single sub, would you use both JBL channels or are they mirrored? Thinking of adding one sub plus factory woofer.
  16. Jan 14, 2023 at 7:57 PM
    pal9000
    2023 Tundra TRD pro
    No need for remote wire…sub will turn on after it senses a signal. Theres a setting on the side.
  17. Jan 14, 2023 at 8:01 PM
    pal9000
    2023 Tundra TRD pro
    I used both to maximize the signal the kicker amp gets…probably mirrored but you never know. Yeah would definitely just leave the stock sub in place. Still provides bass and won’t interfere with the kicker sub…might have to change the phase on the kicker sub though which is just a switch.
  18. Jan 14, 2023 at 8:02 PM
    pal9000
    2023 Tundra TRD pro
    Not yet that I know of but this is a pretty easy install especially if you just add 1.
  19. Jan 22, 2023 at 1:47 PM
    rss29
    rss29 New Member
    22 WCP DC LTD
    I added a single sub and kept the JBL. There wasn't enough room behind the seat so I mounted it under the middle section of the bench. Built a little platform for it to sit on. That was the most time-consuming part since the floor is angled and uneven in that section. Turned out pretty good and wasn't terribly difficult.
  20. Jan 23, 2023 at 9:04 AM
    99ways2die
    Did you use both pairs/channels for input, or just one?
    Did you test w/o the OEM sub (is there any point to keeping it active)?
    Thanks.
    -99
  21. Jan 23, 2023 at 9:42 AM
    rss29
    rss29 New Member
    22 WCP DC LTD
    I used both channels- left/right. Though I'm not sure exactly how they differ since it's a single channel speaker. I did try unplugging the JBL sub, but felt it sounded fuller with it running. I may have been able to mount the Kicker sub in place of the JBL but that would have been a much bigger project that required removing the back seat. More than I felt like doing in my snowy driveway. I have a double cab and everything back there is a little tighter and harder to get to.
  22. Jan 23, 2023 at 1:34 PM
    Cisom85
    Cisom85 New Member
    2022 Platinum Blk 4x4 6.5
    Hey Max713 - What sub did you replace the factory JBL sub with?
  23. Jan 23, 2023 at 3:44 PM
    99ways2die
    Thanks for re:
    I got my Kicker 2 weeks ago, but likewise, the weather here (NJ) is crappy and I'm in no mood to rush this in the cold, just to get it done.
    I'll probably end up like you, with both OEM + Kicker subs on.
    -99
  24. Jan 25, 2023 at 6:26 PM
    wilfong9
    wilfong9 New Member
    I’d be curious if it has full range. My guess is the factory crossover limits full range to keep the factory speaker from working too hard. Anyone know for sure?
  25. Jan 26, 2023 at 5:59 PM
    Gambolified
    Gambolified New Member
    2023 Tundra Platinum
    I plan on running a kicker 800 watt amp and kicker rt loaded enclosure with passive radiator. I will also be adding a lc2pro line converter with accubass. My question to any that have done this is where did you get remote signal from? I’ve removed the sub and it’s barely noticeable. The new set up should be a lot better than what it came with.
  26. Jan 27, 2023 at 4:59 AM
    FALQN
    FALQN New Member
    Midnight Black, 4x4 Crew, TRD Sport
    OEM Running Boards, Wheel Locks, Hard Cover, Home-made Kicker Sub
    The 400w Kicker sub amp I installed on my non-JBL system, turns on automatically as soon as electrical energy is received from the speaker level inputs. Since I did not have a sub to begin with, I pulled the full range sound from the rear door speakers before the OEM crossovers. The latest line of Kicker amps come with a remote signal wire, but you do not need it because of the ‘power-on’ capability through the speaker level inputs.
    Gambolified[QUOTED] likes this.
  27. Feb 3, 2023 at 10:44 PM
    NVRsyDI
    NVRsyDI 22 TRD PRO Prerunner
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Wescott level kit KMC Bead Lock 17" (Unreleased) 37" Nitto Tires Burger 4P Tuner Burger BOV Hike It Pedal Controller Black Widow Exhaust (2) JL Audio 13.5 TWv2 subs 10% Tint Windshield 50% 8 gang switch hub 12 smart rgb rock lights
    Two JBL 13.5’s
    Kap1 and Gambolified like this.
  28. Feb 4, 2023 at 6:35 AM
    Breathing Borla
    aren’t those jl and jbl?
  29. Feb 4, 2023 at 8:44 AM
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    No the amp is where the JBL was.
  30. Feb 4, 2023 at 11:02 AM
    2017TundraNC
    2017TundraNC New Member
    North Carolina
    2022 Tundra 1794 4x4 6.5'
    Custom box? Hybrid?
