TRD Pro Wheel Well Camo Trim
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Aug 9, 2022.
  1. Feb 2, 2023 at 10:07 PM
    #241
    trailhunters
    trailhunters New Member
    I just received my set today, but the box for Rear Left (PT871-34222-02) had another Front Right (PT871-34220-02) in it, with the orange LED marker missing. What a mess!
    Does anyone have an extra Rear Left (PT871-34222-02)? Will contact the dealer tomorrow, but asking just incase.
    This has been posted many times, but I'm including the orientation+stamp along with the part numbers.
    PT871-34220-02 - Front Right (FR-R)
    PT871-34221-02 - Front Left (FR-L)
    PT871-34222-02 - Rear Left (RR-L)
    PT871-34223-02 - Rear Right (RR-R)
    ryanwgregg and Unitdosed like this.
  2. Feb 3, 2023 at 10:15 PM
    #242
    NVRsyDI
    NVRsyDI 22 TRD PRO Prerunner
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Wescott level kit KMC Bead Lock 17" (Unreleased) 37" Nitto Tires Burger 4P Tuner Burger BOV Hike It Pedal Controller Black Widow Exhaust (2) JL Audio 13.5 TWv2 subs 10% Tint Windshield 50% 8 gang switch hub 12 smart rgb rock lights
    Got my fiberwerx going and putting them on as I type.
    Yaboy, ToyoMon, ryanwgregg and 3 others like this.
  3. Feb 4, 2023 at 6:25 AM
    #243
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    ryanwgregg likes this.
  4. Feb 4, 2023 at 8:51 AM
    #244
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    montera.built likes this.
  5. Feb 4, 2023 at 9:00 AM
    #245
    jgoliath
    They come painted or did you have to get them painted?
  6. Feb 4, 2023 at 9:03 AM
    #246
    montera.built
    montera.built New Member
    Jordan
    2022 AG Toyota Tundra TRD Offroad
    Man those look awesome! Might be placing an order soon for the fronts. My only concern is no fender liner, I don't want water splashing into the intakes... How much was install if you don't mind me asking?
    Also how was fitment from the get go? Did they require a ton of work so far?
  7. Feb 4, 2023 at 9:03 AM
    #247
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    No they don’t come painted. They also need a lot of trimming and in-filling to make the gaps consistent. Had to fab a bracket for the tailgate and so forth.
  8. Feb 4, 2023 at 9:05 AM
    #248
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    Front is a lot easier install. Painting the inner black with steelit and made an instant shroud. Probably 2k-3k install and paint. Front only.
  9. Feb 4, 2023 at 9:16 AM
    #249
    montera.built
    Jordan
    Man that's steep. I hear they do fitment on the fronts for $500 but idk how perfect they dial it in.
  10. Feb 4, 2023 at 9:18 AM
    #250
    NVRsyDI
    Russ
    Huntington Beach
    Tundra TRD Pro 22
    If you look at my photos the yellow tape all over are places that need trimming or infill. The flat parts aren’t perfect either so they need smoothing too.
    montera.built[QUOTED] likes this.
  11. Feb 4, 2023 at 10:50 AM
    #251
    montera.built
    Jordan
    Really wish fiberglass wasn't so much work haha
  12. Feb 5, 2023 at 12:56 PM
    #252
    jgoliath
    RRW 0 offset. Rough country flares help tuck them a bit more. I also did a layer of clear PPF between the flare and where it rubs against the body/paint to help protect the paint underneath. Now that I have these on, the stock”flares” don’t even seem like flares. They are more like an esthetic black trim piece. Some before and after comparisons below.
    A6D99B2C-8D3F-4DFC-A99E-3A86E13904AD.jpg B79B4B98-2F8B-4575-88A4-DB6F2EDD0463.jpg 94E68AFA-C15F-4EC4-A9CC-ED8805BFB4F7.jpg 07604ADE-41D8-479D-B217-36DAF11DDDA9.jpg
    =JSG=, iiawah808, ryanwgregg and 2 others like this.
  13. Feb 6, 2023 at 3:51 PM
    #253
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    2022 Limited Crewmax L
    MBM - TRD Offroad
    I just got notified that my online order has been cancelled because the parts are no longer available. My order was placed in December. Not too sure where to try next? I wonder if Sparks has them?
  14. Feb 7, 2023 at 8:08 AM
    #254
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    Has anyone had success getting these Pro Flares from Sparks recently?
  15. Feb 13, 2023 at 3:26 PM
    #255
    Tundra17944Ever
    Tundra17944Ever ‘16 Limited to ‘23 1794
    Tom
    GA
    2023 Tundra CrewMax 1794 TRD 4x4
    Fuel Rebel 6 Bronze 20x9 +20 Nitto Recon Grappler LT295/60R20 PRO fender flares color matched and wired Fox suspension from TRD Pro TRD Pro shift knob Grille surround color matched CBI Covert bumper with bull bar Rear bumper arms color matched BakFlip MX4 tonneau cover WeatherTech mats Gloss black window trim TT cat shield Black TRD grille Tufskinz tailgate letters Tufskinz TRD logo and stripes Tufskinz door sill protector Center console safe TWC 5” exhaust tip TWC slip-on exhaust TWC titanium valve stem caps Beat Sonic amp TRD air filters Diode Dynamics amber fog lights Color matched digital camo fog light bezel OEM Dashcam
    I followed your advice and it worked perfectly. I have the flares installed but not wired. How did you determine which pin is hot and ground?
  16. Feb 13, 2023 at 4:28 PM
    #256
    Buellride
    Buellride [OP] New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    Honestly, I am not sure which is hot and/or ground. If you look back through this thread you will find my description of how I did the wiring on my SR5. The rear flares are easy to figure out....the headlights are slightly more difficult.....
    Taikowaza likes this.
  17. Feb 13, 2023 at 4:29 PM
    #257
    Toy too Tundra
    Toy too Tundra New Member
  18. Feb 13, 2023 at 5:21 PM
    #258
    Tundra17944Ever
    Tom
    GA
    You gave a good description in post #184. Your connections to the truck make perfect sense. I need to figure out which pin on the light is ground. I could try trial and error as long as I don’t burn out the light. Would be nice if it’s on the light somewhere.
    Unitdosed likes this.
  19. Feb 15, 2023 at 5:46 AM
    #259
    Jgrunst
    Jgrunst New Member
    2023 Tundra SR5 TRD - Off Road
    Anyone have any pictures of the pro flares on an sr5 or platinum with stick wheels? I have SR5 trd offroad with 20in TRD offroad wheels. Curious if the extra width of the flares will look goofy with stock wheels that don’t have any extra offset/tire poke. Thanks
    Unitdosed, YotaGang0404 and Taikowaza like this.
  20. Feb 15, 2023 at 6:25 AM
    #260
    Jgrunst
    Jgrunst New Member
    Yea that’s that I was thinking. Would 1”spacer be enough? Would there be any issue with rubbing or anything like that? Thanks
  21. Feb 15, 2023 at 8:12 AM
    #261
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
  22. Feb 15, 2023 at 10:43 AM
    #262
    RickyPNW
    RickyPNW New Member
    '23 off-road 1794
    Just placed an order for all 4 flares and was informed they're on national backorder as expected, but at least my dealer didn't flat out tell me that I couldn't get it. Seems like Toyota is slowly chipping away at the backlogs based on what he told me about my backordered bed steps.
  23. Feb 15, 2023 at 10:46 AM
    #263
    RickyPNW
    RickyPNW New Member
    '23 off-road 1794
    I scanned through all pages in the thread and I'm sorry if I missed this, but has anyone taken a stab at wrapping the flares? As much as I like the camo pattern, it would look seriously out of place on the 1794 trim with all the chrome.
    I actually don't mind the chrome and plan on keeping it, but the Pro flares would look a lot better if wrapped in the same gloss black as the current flares (1794 w/ TRD off-road).
    Meangreen likes this.
  24. Feb 15, 2023 at 10:47 AM
    #264
    RickyPNW
    RickyPNW New Member
    '23 off-road 1794
    Did you get a better deal than the $84 per flare that I paid, if you don't mind my asking? I also prefer local pickup since my dealer tends to have discounted prices online, and I can inspect everything on the spot.
  25. Feb 15, 2023 at 10:55 AM
    #265
    RickyPNW
    RickyPNW New Member
    '23 off-road 1794
    Dang that's a steal!!! Although with shipping I'm sure it will be more than local prices.... Tbh the full price of ~$90 isn't terrible either considering you get the marker lights, which is the only reason I want to retrofit the Pro flares. If it were just the flare alone, I likely would pass.
  26. Feb 15, 2023 at 12:49 PM
    #266
    RickyPNW
    RickyPNW New Member
    '23 off-road 1794
    That's so backwards hahaha.. makes me think the Pro flare prices will catch up or adjust, so better get is sooner than later!
    I love the look and I guess I could do the prep and paint myself since it's a pretty small part. Might be easier and more durable than wrapping. I didn't realize how expensive the wrap itself can be too jeez.
  27. Feb 15, 2023 at 1:14 PM
    #267
    Tundra17944Ever
    Tom
    GA
    I had mine painted to match my Smoked Mesquite. I wanted the digital pattern to show through.
    RickyPNW[QUOTED] and ryanwgregg like this.
  28. Feb 15, 2023 at 2:13 PM
    #268
    urmomspad
    urmomspad New Member
    SoCali
    23 Tundra TRD OR
    Quick update here as I know some people were asking about stock availability. I ordered a set from West Coast Toyota in Long Beach, Ca and just received them today. It took 3 weeks and paid $70.40 per piece.
  29. Feb 15, 2023 at 5:46 PM
    #269
    Tundra17944Ever
    Tom
    GA
    I’ll take a couple tomorrow.
  30. Feb 15, 2023 at 6:05 PM
    #270
    Tundra17944Ever
    Tom
    GA
