Transmission drain and full amount
Discussion in '2.5 Gen Tundras (2014-2021)' started by 11bravoz71, Jan 26, 2023.
  1. Jan 27, 2023 at 4:26 PM
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Read the procedure I posted in Post#12. There is a section in green font that tells how to put the vehicle into a diagnostic mode to alert you when the fluid is at the correct temperature. What will happen is the “D” (for Drive) will be off when the fluid is too cold, it will turn on solid when the temperature is within range, and it will start flashing when it gets too hot for checking.
    IowaGuy[QUOTED] and Joe333x like this.
  2. Jan 27, 2023 at 4:28 PM
    Redline870
    Ian
    Central NY
    However, don’t confuse this for meaning the vehicle needs to be in Drive, you don’t want to run yourself over! Although you will need to move the shifter around a bunch to get it into the diagnostic mode, it should remain in park once you are in the diagnostic mode. I’d recommend doing a dry run the next time you drive your truck for practice. You’ll see what I’m talking about with the drive light being off-then on-then flashing, and it will make more sense.
    IowaGuy and Joe333x like this.
  3. Jan 28, 2023 at 10:40 PM
    11bravoz71
    11bravoz71 [OP] New Member
    Daffy Duck
    As a point of data. I pinned the transmission thermostat then ran the engine for a minute and parked at a incline on ramps. Drained pan, Then I dropped the transmission pan and removed “strainer” aka filter let all that drain. Cleaned the magnets etcc.
    I got exactly what looks to be 5 quarts out.
    Now When I only drained and filled a few days ago, I only got 3 quarts out. But I was leveled and didn’t pin the thermostat. Just data.
    looks like this fluid is original with 155k miles based on it being blacker then my soul. Although The Transmission runs very very strong and feels like new IMO. Even with this really dirty ATF. Must be a testament to the tundras over built durability.
    I Will be running the truck with the thermostat pinned moving forward for Lower trans temps. So the fluid can circulate at all times.
    I deleted my Silverados trans thermostat because across the board the torque converters we’re grenading by 150k miles or less, due to over heating to achieve the 0.2 MPG CAFE requirements. By running trannys hotter at 200F regularly. The heat wears out the fluid much faster and if you don’t change it regularly Silverados don’t last like that. transmissions don’t like heat 150F is ideal IMO. Although Maybe the tundra can handle the heat better
    Joe333x likes this.
  4. Jan 29, 2023 at 8:21 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Just imagine how awesome it would be if Toyota and every manufacturer would just PUT THE FREAKIN DIP STICK back in the trans . Ill gladly pay the 5 dollars more on the window sticker if its really going to break the bank. :mad:
  5. Jan 29, 2023 at 8:57 AM
    11bravoz71
    Daffy Duck
    They won’t. This industry among many others has shifted to pure unfiltered greed. They want them to fail at some point. Or force the basic DIY selfer out of the picture. And pay up big dollar signs for the dealer to do it.
    Wallygator, WILLINH and Rob's Inferno like this.
  6. Jan 29, 2023 at 9:05 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    What are you talking about? ;) Volvo has had undrainable transfer case and differential 20+ years ago, you can't even drain them properly w/o splitting in halves. So no one did any fluid replacement. Opposite to that, Tundra is a beautiful old school piece of machinery that lets you access pretty much everything for routine maintenance with ease.
    Seriously, people overthink ATF. I can understand you may need to set the level once, after you've got the truck second hand, but following ATF replacements are a mere drain&fill the same quantity.
  7. Jan 29, 2023 at 9:22 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    11bravoz71[OP] and WILLINH like this.
  8. Jan 29, 2023 at 10:30 AM
    brandostundra
    brandostundra New Member
    I highly doubt this is true.
    if you drain whats in the pan by just removing the drain bolt , you'll get the 3+ qts , but letting it sit overnight with the oil pans drain open isnt going to get you any more, maybe just a few drops but not 2-3 more qts
    TTund16 likes this.
  9. Jan 29, 2023 at 11:47 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Last time I drained ~4 quarts as usual before realizing my stocked ATF is T-IV, not WS. I drove to the nearest dealer and bought a six-pack of WS. When I came back home in about an hour-hour and a half, I notice a puddle under the transmission. Removed the hand tightened drain plug and it drained 2 more quarts.
  10. Jan 29, 2023 at 11:56 AM
    brandostundra
    Im hoping the vehicle you drove to get the correct fluid was not the vehicle you just drained 4qts out of ??
    TTund16 likes this.
  11. Jan 29, 2023 at 1:14 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    After owning Volvo exclusively for more than a decade, I'm following "N + 1" formula: N drivers in the family, N + 1 vehicles in the family ;)
    DZ_ likes this.
  12. Jan 29, 2023 at 5:07 PM
    brandostundra
    is that greek , I read it 5 times and still cant figure it out?
  13. Jan 29, 2023 at 7:55 PM
    Redline870
    Ian
    Central NY
    I assume he means number of drivers + 1.
    Ex. 2 drivers is 2 cars + 1 for a spare = 3 cars total.
    Wallygator likes this.
  14. Jan 29, 2023 at 8:10 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yep.
  15. Jan 30, 2023 at 7:57 PM
    brandostundra
    you guys must be in some sort of secret club with this code talk
  16. Jan 31, 2023 at 8:28 AM
    M3Tundra-JK
    Scott
    2005 GX470
  17. Jan 31, 2023 at 9:47 AM
    AZBoatHauler
    So.Arizona
    Some people aren’t big on the algebra.
    Ready for another drain and fill on my rig - I always get 4 qts.
  18. Jan 31, 2023 at 10:02 AM
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    This is the funny part of the entire process.
    1. Have truck no more than 1 degree off of level (precision)
    2. Ensure fluid temp at the pan is in an exact range (precision)
    3. Wait until fluid comes out at a “trickle” (WTF???)
    TRD ROB and JLS in WA like this.
  19. Jan 31, 2023 at 10:29 AM
    AZBoatHauler
    So.Arizona
  20. Jan 31, 2023 at 10:37 AM
    #50
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    How often have you been replacing your fluid?
  21. Jan 31, 2023 at 10:48 AM
    #51
    AZBoatHauler
    So.Arizona
    Ive done 4 qts about every 15k miles (1x/year) since 45k.
    coldcanuk likes this.
  22. Jan 31, 2023 at 10:55 AM
    #52
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I’m doing a drain and fill this weekend
    I’ll wager I get 4qts
    using the scangauge3 for temp
    doing differentials as well
    having the tune checked / dyno on Tuesday
    changing oil as well
    M3Tundra-JK and AZBoatHauler like this.
  23. Jan 31, 2023 at 11:28 AM
    #53
    BillyB
    BillyB New Member
    Billy
    AZ
    Oh damn, quite a bit. I just went over 18k miles, so starting to ponder the idea.
  24. Jan 31, 2023 at 4:34 PM
    #54
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    LOL. I know. I was there like, where's the trickle?
  25. Feb 1, 2023 at 3:39 AM
    #55
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yessssss
    well said.
    all this high level precision comes down to a trickle.
    as I said earlier....don't over think this.
    and I'll call an audible here.....if you don't have a pan temp measurement...just make sure the pan is warm, & you are good to go on the trickle. the thermodynamic expansion difference is negligible.
    "negligible" accuratizes the lack of temp. the trickle seals the deal. I guaran-damn-tee you will have the right amount of fluid.
    I use the SG3 to get my temp only if I desire to get up off the damn garage floor.
  26. Feb 1, 2023 at 1:39 PM
    #56
    Redline870
    Ian
    Central NY
    Holy shit, why are we making such a project out of this? And stop will all the bad advice from the backyard mechanics. If you want to check your fluid incorrectly, that’s your prerogative, I could care less what you do with your own vehicle, but stop regurgitating bad advice.
    EVERY SINGLE TRUCK HAS A BUILT IN TEMPERATURE SENSOR!
    - You don’t need a code scanner
    - You don’t need and don’t want to use an IR temp gun
    - You definitely don’t want to go by how it “feels”
    I posted a fool proof procedure on how to do this, it’s not rocket science and the process leaves nothing to chance. Just follow that process and the truck will literally tell you exactly when the fluid is in the correct temperature range by illuminating the D light. It also tells you exactly when the fluid is too hot by flashing the D light.
  27. Feb 1, 2023 at 7:07 PM
    #57
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Seriously, it's funny reading the ways people will go around doing it the correct way when it's not even difficult. These are the people that tell you they have a shortcut and then turn 14 times and get there at the same time as you who drove in a straight line but hit a couple lights. The comments about what a trickle means is funny too, if you've ever drained anything it's pretty easy to understand that it's either coming out full force, not coming out at all, or trickling. I let mine drain til the fluid stream is too weak to flow straight down and starts to go off to the side.
  28. Feb 1, 2023 at 7:32 PM
    #58
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Agreed, the best advice comes from Youtube Certified Master Auto Technicians! Haha
  29. Feb 2, 2023 at 9:32 AM
    #59
    AZBoatHauler
    So.Arizona
    its probably overkill but I do tow and off-road frequently and run 34” tires. Also plan to keep the truck forever. Figure I can swing $50/year to refresh the ATF.
    JLS in WA, Joe333x and NWPirate like this.
  30. Feb 2, 2023 at 4:50 PM
    #60
    Wahoo155
    Wahoo155 New Member
    Lee
    Southside Virginia
    2008 Salsa Red
    M3Tundra-JK likes this.
