Leaky Head? Leaky something?
Discussion in '1st Gen Tundras (2000-2006)' started by evanhmn, Jan 31, 2023.
  1. Jan 31, 2023 at 11:23 AM
    evanhmn
    evanhmn [OP] mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    So I noticed what seems to be a leak of some sort coming from my engine bay, and after inspection, it looks to me as if my valve cover gasket could be slightly leaking. I am not familiar with such a problem so I am not 100% on it. The leak is apparent on both sides as well as you can see in the pictures. And yes I know, I need to clean my engine bay.
    Mind my fat thumb :)
  2. Jan 31, 2023 at 11:33 AM
    shifty` One great big festering neon distraction
    looks like valve cover gaskets and spark plug tube seals to me.
    You may want to check the torque on your valve cover bolts. They tend to loosen over time, as the gasket compresses, especially if you have really low miles [or] really high miles.
    But the leaks starting mid-way, oil flows down, so if the leak starts at the perimeter of a coil pack openining, it's probably your spark plug tube seals. Someone may've already placed, and chose not to use OEM, or didn't install the replacements correctly. See here for more info on the process etc.
    DarkMint, Aerindel and evanhmn[OP] like this.
  3. Jan 31, 2023 at 12:13 PM
    evanhmn
    State of Taxes
    Torque will be checked when I'm done with work and class, and just an FYI I am sitting at about 190k currently.
    shifty`[QUOTED] likes this.
  4. Jan 31, 2023 at 12:18 PM
    Just know correct torque is in INCH LB, not FT LB and you're aiming for 53 inch lbs per the FSM which is in the ballpark of 4.5 ft lb if my math is on-point.
    evanhmn[QUOTED][OP] likes this.
  5. Feb 24, 2023 at 7:59 PM
    evanhmn
    State of Taxes
    After a further inspection on this matter, I will replace my valve cover gaskets, sparkplugs, and coil packs. Would it be possible to get some help finding which gaskets to use? On the parts.toyota.com website, two different gaskets are available - one for the left and one for the right possibly? Just not sure and would love some input. Thanks!
  6. Feb 24, 2023 at 8:20 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you're totally committed to doing coils, make sure and get Denso brand from rockauto and not scamazon. Parts store coils are not great.
    If I were you though I'd only do the coils if you are getting misfires or having issues.
    For sparkplugs I would suggest whatever plug the manual suggests. I'd also recommend staying away from unreliable sources for spark plugs. There are counterfeit parts on many websites. Rockauto is your friend.
  7. Feb 25, 2023 at 9:17 AM
  8. Feb 27, 2023 at 2:28 PM
    bfunke
    bfunke Tundra Curmudgeon
    What Shifty said. Easy job if you have some basic mechanical skills. I would not switch your coils if you’re not getting misfires. I would purchase new bolts that have the integrated rubber seal. Don’t overtighten and don’t forget the half moons. The fact you referred to it as a head gasket may suggest letting a mechanic do the job.
    w666 likes this.
