Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Nov 30, 2022 at 1:54 PM
    #2941
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    I knew they were going to clear the brakes. I was more worried about the positioning of the weights when they were balanced. It was the first thing I checked when I picked it up from the shop. I’m getting about 14mpg now.
    RusPro21[QUOTED] likes this.
  2. Dec 12, 2022 at 11:59 AM
    #2942
    Dreyg
    Dreyg New Member
    2022 Tundra TRD PRO replica wheels in 5x150 option for 2007 - 2021 trucks. 18x9 +18mm offset made by AGP Wheels. Lifetime structure warranty fits Oem TRD center caps
  3. Dec 15, 2022 at 12:13 PM
    #2943
    NorCalTRACON
    NorCalTRACON New Member
    21' Tundra TRD OR Crewmax
    Thats an interesting combo. Looks nice
  4. Dec 18, 2022 at 10:41 AM
    #2944
    lesh234
    lesh234 New Member
    Looking for a set of take off black rims/tires around central Kentucky, no shipping
  5. Dec 22, 2022 at 7:43 AM
    #2945
    Tan-dra
    Tan-dra MUD GANG 2006
    2020 Quicksand SR5
    Bilstein 5100, 35’s on 17” wheels
    New Here. Here’s my set up I just had installed the other day. 17x8.5 +0 Kansei Roku wheels with 315/70r17 BFG KO2’s. Bilstein 5100 set at the middle setting, rear is stock height. Minor body mount chop and front bumper shims for clearance63773474-F19A-4FF9-91E1-A0C35BF305D5.jpg 7D5A1D17-0B17-479F-82AD-C1379B7157B2.jpg
  6. Dec 22, 2022 at 9:52 AM
    #2946
    DeanoBambino64
    DeanoBambino64 New Member
    Dean
    Saskatoon Area
    2008 Tundra Crewmax Limited 4X4 5.7L V8, 20"aluminium oem wheels.
    I bought some cheaper Dorman lugs to use on steel wheels from an 07 fitted with winter ice tires. The Dorman chart for torque specs says 2007-2010 is 97 ft/lbs and that steel wheels 2010 onwards are 154 ft/lbs.
    on steel wheels. Anyone with a final word on the correct torque? thanks in advance.
  7. Dec 23, 2022 at 9:48 PM
    #2947
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Finally got some new meats.
  8. Dec 25, 2022 at 8:31 PM
    #2948
    RogueRonin
    RogueRonin New Member
    Swapped my Chambers for MR315’s
  9. Jan 17, 2023 at 5:56 PM
    #2949
    unlimited limited tundra
    unlimited limited tundra New Member
    2018 Tundra Crewmax Limited
    bone stock
    Hi fellow Tundra people. I have a bone stock 2018 Tundra, ready to replace tires. What is the tallest and/or widest tire I can go without needing to trim anything? I would prefer not to trim, but I am open to a leveling kit or a slight lift to clear the tires. Please help, I am driving my wife's car while I do my research. I know, I know, I should have been researching sooner. Oh well. What can anyone tell me that will help me decide.
  10. Jan 18, 2023 at 4:08 AM
    #2950
    mvetrox
    mvetrox 2020 E-Pro BHS
    Tennessee
    2018 Limited
    Stock
    Start on page 1 of this thread. If you keep the stock limited rims you can go as big at 33.5 without rub. I have a stock limited with 285 60 r20. If I did it again I would get 295 55 r20 to get a little more width. The extra height isn't that noticeable. Improved from stock but not lust worthy.
    I should also note I have Michelin Defenders, I tow and prioritize highway performance and hydroplaning resistance. A more aggressive sidewall would enhance the curb appeal for sure.
  11. Jan 18, 2023 at 9:38 PM
    #2951
    bone stock
    Thanks for the quick response. Yeah, I read some, but I haven't found what suits me. I'm okay if I don't go wider, taller is a plus. What I really want is a larger profile/sidewall. I had an '84 Toyota that had 8" of sidewall (great for off-road) and I would like to find something that gets me closer to that.
  12. Jan 22, 2023 at 6:03 AM
    #2952
    mvetrox
    Tennessee
    2018 Limited
    Stock
    Check out @Kmoose35 set up. Its a good start for a limited.
  13. Jan 22, 2023 at 2:35 PM
    #2953
    Caleb4.7
    Caleb4.7 New Member
    Caleb
    2003 Tundra 4.7 access cab sr5
    Leveling kit, 4 runner rims
    Has anyone ran 275/55/r20’s on a 2 inch level first gen? I’m wanting to run that size without major rubbing or having to run spacers, any thoughts?
  14. Jan 23, 2023 at 11:26 PM
    #2954
    rollin-on-dubs
    rollin-on-dubs New Member
    Chuck
    Middle TN
    2014 CrewMax Platinum
    Toytec Boss Suspension SPC Light Racing UCA's Coach Builder 3" Rear Shackles 20x9 Fuel Boost 275/60/20 Nitto Terra Grappler G2 Locker-Down Center Console Safe Morimoto XB LED Fog Lights Ellis Precision Shift Knob Ellis Precision Battery Hold Down
    How have the Toyo AT3 been working out for you? Did you have to do a BMC to clear them?
  15. Jan 23, 2023 at 11:28 PM
    #2955
    rollin-on-dubs
    Chuck
    Middle TN
    Looks good!
    dhalsey[QUOTED] likes this.
  16. Jan 23, 2023 at 11:37 PM
    #2956
    rollin-on-dubs
    Chuck
    Middle TN
    You still liking the AT3s? Did you have to do a BMC or other trimming to fit them?
  17. Jan 25, 2023 at 5:40 AM
    #2957
    Ghostface
    Ghostface New Member
    Awesome setup!! Do you have anymore pictures? Would love to see more to get a better idea of this setup.
    Tan-dra[QUOTED] likes this.
  18. Jan 27, 2023 at 10:20 AM
    #2958
    ffdawson
    ffdawson #DBB
    NorCal
    Sandra, Sandy for short
    Rad ass parts, big tires.
    Nice rig! welcome to the forum.
    Tan-dra[QUOTED] and dhalsey like this.
  19. Jan 28, 2023 at 1:54 PM
    #2959
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    So if I wanted to go with a 35 x 12.5 tire on the factory rims, it's 100% that you'll have to do a bmc? When my 33s wear out I'm looking to do the 35s on my 2021 SR5 with the SX package 18" rims and BDS/Fox 3" suspension lift with BDS UCAs. Seems to have a lot of room with the current 33" setup, although the tires I have now are not very wide (275/70R18)
  20. Jan 28, 2023 at 5:09 PM
    #2960
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I assume the rims of the SX pkg are in the realm of +60 offset like the rest of the Toyota rims. If you are gonna put 35s on that offset you might want to consider spacers in the 1.25" range.( @Ckatz53 before the 37s) That will help with some of the clearance issues.on the skid and the steerIng components. remove the front spats and push the fender plastics forward to gain some room up front and/or add bumper shims. Then ask a good alignment shop to push your caster up as high as they can get it to help clear the body mount. But in the end I would expect that it will still be very likely that a BMC will be necessary. All of these trucks have their own personality and the clearances are pretty tight. The more you read into this the more you find everybody has to find their own combo. The good news is none of it is terribly difficult or expensive.
    Ckatz53 likes this.
  21. Jan 28, 2023 at 6:44 PM
    #2961
    rocsteady
    Dave
    New Jersey
    Very good,. Doesn't sound too bad at all. Thank you for the response.
    Pillslinger[QUOTED] likes this.
  22. Jan 30, 2023 at 9:34 PM
    #2962
    08TRDOFFROAD
    08TRDOFFROAD New Member
    Daniel
    2021 Tundra 4wd Platinum
    2" level kit, 18x9 SCS Ray10's, 295/70/18 Falken Wildpeaks
    Hey all,
    I picked up a certified used 21' Platinum w/2.5" level kit up front in May. It needs new tires and I want to upgrade the rims while I'm at it.
    I have been eyeing the Method 305's in 18x9 +25mm offset, 6" backspacing. What I am trying to determine is if these will have the extra poke I am after. Or if I should bump down to rhe 17x8.5 0 offset, 4.765 backspacing. Ideally, I would like to have the tires flush with the flares or slightly past after installing some Bushwacker flares. I read through several pages of this thread and just can't seem to find any setups with similar specs to verify how the fitment will actually look with the 18s.
    Any help to wrap my head around exactly how the specs of the Methods will move the wheel in relation to the factory 20s on it now would be great, or if these won't give me the look I am after what offset/backspacing I should be looking for to get the look I am after.
  23. Jan 31, 2023 at 4:16 AM
    #2963
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Awesome rig man! I’m sorry if I missed it but what did you have to cut to fit those bad boys?
  24. Jan 31, 2023 at 5:25 AM
    #2964
    Pillslinger
    Rollin
    SWMO
    https://www.tundras.com/threads/anyone-running-17-rims-on-your-2-5-gen.23617/
    Thread devoted to 17's multiple offsets lots of pics.
    mZiggy likes this.
  25. Feb 2, 2023 at 10:31 AM
    #2965
    17inferno
    17inferno New Member
    295/70/18 Michelin Defenders on the new SCS F5 wheels, matte jette black. Around 2.5 inches up front, and no lift on the rear at the moment. Light rub on front spats full reverse, no where else, even romping on the trails.
  26. Feb 3, 2023 at 2:37 PM
    #2966
    Tan-dra
    2020 Quicksand SR5
    Thank you! sorry for the delayed response. Here are a few more pics of the setupBE422322-6BFC-4144-AEE7-7FFCB721A232.jpg7EF763E4-1C20-427F-AD2C-5549615EFAE5.jpg
  27. Feb 3, 2023 at 4:40 PM
    #2967
    JimboSlice413
    Bakersfield
    • I didn't like the look of them initially but they look much better in person. They're extremely quite, probably the quietest all-terrain I've used.
    • Wet weather was surprising. We finally got some rain down here in SoCal (it dumped on us for weeks) and even under heavy acceleration, they didn't break traction. I didn't floor it but I did put some weight on the pedal.
    • Mud is great, dirt is great. Haven't had a chance to use them in the sand.
    • Despite being a 295/70 swap, and Toyo listing the two as having the same OD, they do rub in reverse on the cab mounts. My AT2's did not.
    I really like them but had I known about the size difference, I may have tried a different set of tires.
  28. Feb 8, 2023 at 8:43 AM
    #2968
    RedSam
    RedSam New Member
    2022 Black Tundra SR5
    Is anyone here running 20" +12 with the Falken Wildpeak 265/60/20 or similar - ive read on here tires have a big part of how much poke you end up with. im looking at some Black Rhinos for my 22. I want a little poke to widen the stance & balance out the huge hood but not a ton so it's chewing up the paint.
    Sorry if this is a stupid question- I'm new to the rim game & there are so many variables - I'm trying not to make an expensive mistake if possible.
    Thanks so much for any help - what a Great Forum the knowledge on here is Amazing!
  29. Feb 8, 2023 at 10:37 PM
    #2969
    cs808
    cs808 New Member
    Utah
    2021 Sr5 crewmax, grey
    Nfab Rdms front bumper OME BP51 suspension and heavy duty leaf springs RCI engine and mid plates CBI rock sliders Method wheels/BF Goodrich T/A Ko2’s TRD pro grille, hood bulge, and sensor
    18” Method 701’s with BFG K02’s, size 305/70/R18 on 2.5” lift. I chose the 701’s for moderate offset. And I chose the tire size because I wanted to get as close as I could to 35 inch while keeping as narrow as possible.
  30. Feb 9, 2023 at 5:56 AM
    #2970
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Hi Chris, Curious what size tire did you have before jumping up? And feel much power loss? I’m still deciding what tire size I will add to my wheels in the spring. I know there is not much to choose from this tire size as brand size. Thanks.
