X2 27F battery
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oz_zy, Jan 30, 2023.
  1. Jan 30, 2023 at 2:17 PM
    Oz_zy
    Oz_zy [OP] Member
    2016 magnetic grey tundra tss off-road
    Morimoto headlights+tailights +3rd brake light Morimoto xb led fog light Db custom tundra grill with led 3 inch lift with elka 2.5 ifp suspension with bds uca. Jba lth with full 3 inch midpipes w/factory cats along with full 3 inch true dual stainless steel exhaust with x pipe with 2 corsa pro series mufflers And s&b intake
    Anyone have any experience or input on this battery? I am looking for my 2016 tundra
    Moe2o4 likes this.
  2. Jan 30, 2023 at 2:25 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Love mine, had one in my tacoma for 6 years and 0 issues with it and ended up getting a Tundra and put one in my 2020 Tundra last year when I got it and it's been fantastic!
    Just make sure you get this fuse and pop it in the box to get the alternator to charge the new battery properly!
    Littelfuse 02400104P 1A Mini Diode Automotive Fuse-4Pack https://www.amazon.com/dp/B015YSU24G
  3. Jan 30, 2023 at 2:42 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I've been using one for 2 years, including one Phoenix summer. No issues and I'm happy with it so far. I went with the Ford diode, doesn't need any trimming. I do plan it into an AGM charger/desulfation every few months to be safe.
    Oz_zy[OP] likes this.
  4. Jan 30, 2023 at 3:16 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Been n my Sequoia for over a year. Pheonix did not kill it last summer & it's been in the 30s for a week in the morning, no issues. Search coupons/honey cash back. There are lots of monies to be saved there.
  5. Jan 30, 2023 at 3:20 PM
    Oz_zy
    Oz_zy [OP] Member
    Did you diode fuse
  6. Jan 30, 2023 at 3:21 PM
    e30cabrio
    Yes, the cheap GM one from Amazon
    WillTunBlack20 likes this.
  7. Jan 30, 2023 at 3:21 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Be prepared to 'top it off' with an AGM charger every once a month or so.
    Especially if you don't drive it much daily.
    As others stated the AGM battery likes a higher voltage charge than the stock charging system provides.
    Search the forum and you can find the diode swap info or order the HBK fuse from Australia (when he gets them back in stock)..
    The HBK fuse is nice because it contains a resettable fuse that still protects the system.
    MK2 Micro blade 7.5A (Electronic fuse version) | HKB Electronics
    I had a bad experience with my X2, but I think I got a lemon.
    It died completely twice in 6 months, and that was with the HKB fuse that provides a higher voltage charge.
    Batteries Plus wouldn't keep its warranty promises.
    But I'm pretty sure I'm the exception, a lot of guys are happy with theirs. :thumbsup:
    That stated you cant go wrong with an MTP Interstate 27F..:D
    MTP-27F battery | Interstate Batteries
  8. Jan 30, 2023 at 3:23 PM
    e30cabrio
    I have the HBK, only raised my volts by .2 (to 13.6) the GM brings me to 14.1
    WillTunBlack20 and texasrho83 like this.
  9. Jan 30, 2023 at 3:34 PM
    Oz_zy
    Oz_zy [OP] Member
    Well I've had this one for a solid 5 years and never had to charge20230129_144814.jpg 20230129_144839.jpg
  10. Jan 30, 2023 at 6:20 PM
    farleymcjohnson
    farleymcjohnson New Member
    Eric
    Cokato MN
    2017 Super White Limited Double Cab
    ARE Topper Prinsu Cab and Topper Rack
    I bought the X2 27F this summer, I was just in Brainerd MN last weekend for the Ice Fishing Extravaganza. -18F overnight lows. Truck started in the morning, it groaned a little and was just a little bit slow to start, but started right up where friends trucks didnt.
    Also I have the cheap diode from Amazon and it runs about 14.4 volts give or take .1 or .2
  11. Jan 30, 2023 at 6:40 PM
    Markysharky
    Markysharky New Member
    I used to work at the BP in Mesa. X2 batteries rarely came in for warranty. The most usual issue was people with power draining accessories when the vehicle was turned off and stored. They are made by north star and are the “best” agm made, a good swap for a conventional battery if the group size is the same.
  12. Jan 30, 2023 at 6:42 PM
    Black
    2014 Tundra Limited CrewMax
    I had an X2 on my Expedition for years before I traded it for my Tundra.
    I have had an X2 in the wife’s Suburban for 3 years now.
    No diodes and has never been on a charger. Never had a single issue we see below 0 temperatures and temps above 100.
  13. Jan 30, 2023 at 6:50 PM
    AZBoatHauler
    So.Arizona
    I’m on year 4. Love it. I did add a voltage booster since I was only getting around 13.4v without one.
  14. Jan 30, 2023 at 6:57 PM
    AZTundra
    Paul
    Phoenix, AZ
    Just went with an X2 myself recently. First one died after 12 months, but batteries plus gave me a replacement. I use the HKB also for what it's worth. The X2 batteries are now a 4yr replacement instead of 5 years like they used to be.
    iHacker and Oz_zy[OP] like this.
  15. Jan 30, 2023 at 7:08 PM
    Oz_zy
    Oz_zy [OP] Member
    Do you have a link on where you purchased the HKB?
    AZTundra[QUOTED] likes this.
  16. Jan 30, 2023 at 7:18 PM
    AZTundra
    Paul
    Phoenix, AZ
    https://www.hkbelect.com/
    It comes from Australia and took a couple weeks to arrive.
  17. Jan 30, 2023 at 7:19 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    The Power X2 is a great addition for your Tundra, I have a X2 24F in my 2017 Pro and it’s been there for about 6 months no diodes or power booster fuse not on a trickle charger either and haven’t had any issues. We had below 0 F temperatures here in the last 2 months and the truck start right away.
    Also I have a Duralast Platinum AGM 24F in my wife’s 2016 Acura MDX for the last 2.5 years and trust me this SUV is one of the worst battery killers due to all the technology in it never been on a trickle charger or used a diode or power booster fuse and the battery exceed all my expectations, this is the 3rd battery in all its life and the other 2 only lasted for about 2 years each.
    Y0TA PR0 and RitcheyRch like this.
  18. Jan 30, 2023 at 7:52 PM
    bfunke
    bfunke Tundra Curmudgeon
    Good battery but very expensive. Also you can buy the GM diode for 5 bucks at O’Reilly
    flynbyu2 likes this.
  19. Jan 30, 2023 at 7:54 PM
    AZTundra
    Paul
    Phoenix, AZ
    Here is the GM part number for anyone that needs it. I ran this until my HKB arrived.
  20. Jan 30, 2023 at 9:10 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Good for you.
    There are multiple threads and posts of members that have to 'top off' their AGMs almost monthly.
    I read thru them all before buying my X2.
    So happy to see you are the exception..:thumbsup:
    As I stated, I must have gotten a lemon.
    The first time it died after 3 months, they gave me a loaner and kept the battery for 3 days.
    They told me if it happened again, they would exchange it, no testing, no waiting, no questions.
    The second time it happened, 2 months later, they wanted to retest it.
    They had no loaner batteries and I can't do without my truck for 3 days.
    That same manager wouldn't honor his word of replacement.
    So fuck him and fuck Batteries Plus.
    I traded that $300 X2 in for a $25 core charge for an Interstate and never looked back.
    Never had an issue with the Interstate, never an issue with the battery before I bought the X2.
    Just my personal experience and the OP did ask for X2 experiences.
    I wasn't going to drag the entire story out (again) until you 2 felt the need to quote me.
    Thanks..:rolleyes:
  21. Jan 31, 2023 at 2:38 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    What's interesting is I am stock with stock battery and I regularly see my voltage go to 14.2.
    coTony and Sierradevil like this.
  22. Feb 1, 2023 at 9:58 AM
    Oz_zy
    Oz_zy [OP] Member
    Would I still need to use a diode fuse if I go with the 24F instead of the 27F?
    Moe2o4[QUOTED] likes this.
  23. Feb 1, 2023 at 9:59 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Yes doesn't matter what size your going from a stock battery to AGM!
  24. Feb 1, 2023 at 10:05 AM
    Oz_zy
    Oz_zy [OP] Member
    Do you have link for tge diode?
  25. Feb 1, 2023 at 10:07 AM
    Oz_zy
    Oz_zy [OP] Member
    Did you have any issue with that diode fuse?
    Right now I am debating on which to go between that one or the gm diode
  26. Feb 1, 2023 at 10:13 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Nope been in the truck for a year no and no issued whatsoever. Voltage sits around 14.5 and I'm always monitoring it with my UltraGauge!
    Oz_zy[QUOTED][OP] likes this.
  27. Feb 1, 2023 at 10:18 AM
    VWTim
    Corvallis, OR
    Ford Part # 4F2Z 14A604 AA
  28. Feb 1, 2023 at 10:19 AM
    AZBoatHauler
    So.Arizona
    You just replaced the Alt s fuse with the diode? The HKB has matching amperage rating.
  29. Feb 1, 2023 at 10:20 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Yep just pop the OEM fuse out and make sure you have the arrow facing the front of the truck, if you have the fuse backwards the battery light will come on and you just have to switch it around and it's all good!
    AZBoatHauler[QUOTED] likes this.
  30. Feb 1, 2023 at 10:20 AM
    Oz_zy
    Oz_zy [OP] Member
    The battery on my truck is agm but I have never put any diode fuse and it always comes to 14.1
    NewImprovedRon likes this.
