  1. Jan 28, 2023 at 3:49 PM
    kieljon
    kieljon New Member
    Southeast US
    2005 Double cab 4x4 TRD
    Forgive my ignorance, but if I want to run TRD wheels on my tundra do I use lugcentric or hubcentric lugs? Will I need a hub ring? Thanks for any input! I'm still learning here...
  2. Jan 28, 2023 at 4:13 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Meet up with @2006Tundra and he set me up with his old window trim. No more clapped out Chrome.
    Voss, 912, KNABORES and 9 others like this.
  3. Jan 28, 2023 at 7:53 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Did a little more planning for whatever truck I buy. I'm bidding on a body on Tuesday, but more importantly I think I've come to some decisions for the motor. At a minimum, I will be putting H beam rods in this, and I might build the whole bottom end. The rods look too damn weak for me to just ignore them when I could spend $700 for some peace of mind. Instead of the 8, 250cc injectors and the auxiliary 650cc, I will be putting 440cc RX8 injectors in it, with a 320lph AEM fuel pump instead of the Walbro 255 I have been running. I'm gonna buy ARP hardware for everything. Although I will not be putting the blower on immediately. I plan to run the truck na while I fab up an internal air-water intercooler, probably mimicking the LSA blower. Probably gonna have it sent off as well to be ported, rebuilt, and have the rotors thermal coated. Anyways, would you guys either spend $1700 to get rid of the main failure point, along with freshening the motor up, or spend $3700 and remove nearly all possibility for failure? Oh and for you VVTi guys, what's your experience with either bypassing or completely deleting the SAIS? If I can't get rid of it I'm gonna have to remote mount it because its too fat in the valley for the blower to fit.
    rock climber, des2mtn, lsaami and 3 others like this.
  4. Jan 28, 2023 at 8:30 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    @daveeasa as promised.
    You can see the new door has the little spring steel clip that would grab a bar in the updated pocket the same way the lock would on the old one. Can also see my little stack of RE magnets on the mounting bolt that has been holding mine shut 2.5 years now.
    bmf4069, daveeasa and oscardog86 like this.
  5. Jan 28, 2023 at 8:39 PM
    I ended up going with one of these as a gift to mysef in December, which doesn't require pre-charge. It's a cap that leeches power off the dying battery.
    I've had to use it twice now, once on a battery that registered 8v on initial hookup. It took about 4 mins for that battery on a Yaris, which was 4yo, to finally get up to 100% on the charge, but it was no fuss, no hassle, got to 100%, did its countdown, and when it got to zero, we turned the key and BAM! Fired right up. I love this thing so far. Smaller than jumper cables and doesn't require a 2nd party to work. A little spendy, but it's one of the best purchases I've made in a while.
  6. Jan 28, 2023 at 9:17 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Thats good to know as i bought one a couple years ago but havent had to use it yet. I like that it uses your own dying battery to work.
    shifty`[QUOTED] likes this.
  7. Jan 29, 2023 at 5:51 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Wow - the wood paneling Tundra was a very rare option. :)
    Nicely done, no sign anyone was doing anything there.
    NickB_01TRD[QUOTED] and txagg like this.
  8. Jan 29, 2023 at 6:12 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    As happens in the north - these p.s. lines rust & leak. Which is more valuable to you right now - time or money?
    Once you have 1 leak you will soon have more leaks, you will be chasing weakest link (rustiest section).
    I just had it done. Got the Toyota kit, replaced it all. Saw what came out - so much worse than it looked from above.
    There is also a line on top of the rack that is just as rusty. It IS available as it's own line - they will try to sell you the whole rack, you can get just the line.
    My vote is just replace them all. In north country, anything else is just dragging out the inevitable.
    ...with Toyota parts that fit right & we know will last another 20 years.
  9. Jan 29, 2023 at 7:02 AM
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    You will need lug centric lugs. No hub ring needed.
  10. Jan 29, 2023 at 7:52 AM
    kieljon
    kieljon New Member
    Southeast US
    Thanks for the input!
  11. Jan 29, 2023 at 8:11 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Found a headlight relay kit in my parts bin that I forgot about. Installed that this morning. Cant tell any difference from photos, nor in person.
    Before relay
    After
    And I need to work on cable management. Here is my battery, lol
  12. Jan 29, 2023 at 11:42 AM
    Casper421
    In the woods
    06 DC
    Gave the Wildpeak at3’s another good test in the new dusting and ice this morning. Very impressed! Seems odd, not a lot of people on the roads today.
    585BB773-EC1B-43D0-9F96-589C143D42C8.jpg B8CDB759-F5F3-4AA0-8E37-581403F79789.jpg B1BD61FA-C307-4005-9B3F-81A8CAA62E7F.jpg FF043309-C52B-41BF-97F0-63D7FD7E9626.jpg
    G_unit3000, 912, 805Tundra and 11 others like this.
  13. Jan 29, 2023 at 11:45 AM
    Awesome!
    Do you have the entire back seat out or just folded down?
  14. Jan 29, 2023 at 11:47 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Still have that 8" Pioneer sub? I have the same one in my truck. Curious to hear your thoughts.
  15. Jan 29, 2023 at 12:26 PM
    Casper421
    In the woods
    06 DC
    It’s completely out and I built a platform that I used for the fridge but just for the dogs now.
    Sure do. It’s alright for the price and space available. I just wanted some slight bass and it gives enough. Still kickin after 4 years so I’m happy.
  16. Jan 29, 2023 at 1:22 PM
    oscardog86
    Southern California
    Looks like a fun time, and thats good to know how well the tires did! Those dogs look happy and worn out too
  17. Jan 29, 2023 at 1:47 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    happy bday ghostly! What happened to the SC tundra? Did i miss story time somewhere?
    txagg likes this.
  18. Jan 29, 2023 at 1:55 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
    Thanks man. I took a corner and hit something at the wrong angle. Only enough damage to crunch my fender but it tore up my front crossmember.
    _6a3D3-seQX5vfAxmgz6r_rtNl-lZAM6n-WWurGZ_83d892f6edf71054634324eba45d0eb716c407e6.jpg
    figured it was just the tie rod end at first so I took the effort to source a fender. As yall can see, didn't even bend my door or the bumper, but the steering rack mounts ripped from the frame. It's fine though, I'll make this motor live again in a 2nd gen body. Gonna aim for 600+whp. Main issue that I have right now is that the truck I'm bidding for on tuesday is red, but I'll have to deal with it lol.
    bmf4069, Filthyphil, NUDRAT and 2 others like this.
  19. Jan 29, 2023 at 2:03 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Supercharged engine outlasting the chassis, gotta admit i didnt see that coming.
    FrenchToasty, shifty`, txagg and 3 others like this.
  20. Jan 29, 2023 at 2:56 PM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    OH DAAAANG!!!
  21. Jan 29, 2023 at 5:14 PM
    daveeasa
    Did truck stuff today. 1500 lbs so I may have been at max payload w two of us and the shell and winch on top. Here is a halfway loaded photo. Stuffed as much as i possibly could.
    robabeatle, bmf4069, txagg and 5 others like this.
  22. Jan 29, 2023 at 7:24 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yeah to most I'm sure that just looks like a regular bedside. To me just a relief to finally have it look like it should.
    NUDRAT[QUOTED] and txagg like this.
  23. Jan 29, 2023 at 11:14 PM
    Jake92
    Jake92 New Member
    2000 Toyota Tundra SR5 4x4 TRD
    So I have repaired my front grill and put new headlights on the old girl. With 355,xxx miles and counting she still runs good. Next is a new stereo and wheels and tires
    whittkl4, RUSTYNUTS, NUDRAT and 8 others like this.
  24. Jan 30, 2023 at 4:53 AM
    Fog lights?
    RUSTYNUTS, 2006Tundra and shifty` like this.
  25. Jan 30, 2023 at 6:57 AM
    Jake92
    Jake92 New Member
    Fog lights are next
    daveeasa likes this.
  26. Jan 30, 2023 at 12:13 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    The nuts fit fine even though they are quite a bit shorter than the originals. That quoted part # is the same as what I purchased. I also added a set of black OEM wheel locks for another $40 (PT276-35200-02).
    kieljon[QUOTED] likes this.
  27. Jan 30, 2023 at 12:28 PM
    growit
    growit New Member
    2006 Dbcb SR5
    I used the Surong line about a year ago and it's been fine.
    txagg and shifty` like this.
  28. Jan 30, 2023 at 2:06 PM
    This is one of the two, maybe three guys on here who weren't so lucky w/Surong. https://www.tundras.com/posts/2562391
    I'll be interested to see how @Jake92 pans out with his.
    oscardog86 likes this.
  29. Jan 30, 2023 at 2:14 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Ordered Value Cover Gaskets and Bolts - 2006 Double Cab 4.7 2UZ
    Part Numbers ordered/Used below
    90080-10330 - 18 QTY
    $ 1.27 VALVE COVER BOLTS (FOR CYLINDER HEAD COVER)
    11214-0F010 - 1 QTY
    $ 20.47 Engine Valve Cover Gasket
    11213-0F010 - 1 QTY
    00295-00103 - 1 QTY
    $ 14.65 Toyota Formed-in-Place Gaskets-Oil Pan
    11193-50010 - 8 QTY
    $ 3.06 GASKET SPARK PLUG TUBE; SPARK PLUG TUBE, LEFT.
    805Tundra, bmf4069, RUSTYNUTS and 3 others like this.
  30. Jan 30, 2023 at 3:02 PM
    When you get to the job, zip ties are your friend. Look for things you can zip-tie up and out of the way (fuel lines, PS hoses), and know there are some things (like PS res) you can unbolt to move out of the way. Hardest part of the job for me was - other than cleanup of the covers - Removing the spark plug gaskets. I have pics of my frustration on that if you want.
    Driver's side is the worst as far as obstacles go. Trying to shift the valve cover into place w/o the gasket falling off, and squarely so you don't smear the FIPG in the corners, with all the crap in the way ... harder than it sounds.
    You'll see what I mean...
    bmf4069, RUSTYNUTS, NUDRAT and 4 others like this.
