Interior work to route cable for rear dash cam
Discussion in '3rd Gen Tundras (2022+)' started by raylo, Jan 28, 2023.
  1. Jan 28, 2023 at 5:27 AM
    raylo
    raylo [OP] not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Anyone here installed a rear dash cam and can point to a link or have some pro tips as to how to route the cable, what interior pieces need to be removed, how the clips work in the 3rd gen Tundra, etc. I see several threads about dash cams in general but nothing specific for this aspect.
  2. Jan 28, 2023 at 6:28 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    My dash cam came with a rear camera and cable, but I didn't want to open up a can of worms by lowering the headliner and I didn't see any other way to do it, so I left it off. I'll be watching this thread to see if anyone has a better answer.
  3. Jan 28, 2023 at 6:49 AM
    raylo
    Frederick, MD
    IIRC that's how I did it on my Tacoma... but maybe not really lowering it so much but pressing the cable under the edge. But's been awhile and I don't remember. But after having a rear cam I am going to feel naked driving around out there without one.
  4. Jan 28, 2023 at 7:16 AM
    yamabob
    yamabob New Member
    Chicagoland
    2018 Limited
    I have a Blackvue camera on my 2018. I just tucked the cable into the plastic trim at the headliner. It's been fine.
    devron11 and raylo[OP] like this.
  5. Jan 28, 2023 at 7:17 AM
    raylo
    Frederick, MD
    I'll have to look at the trim on the 3rd gen to see if that looks doable.
  6. Jan 28, 2023 at 9:27 AM
    madwheeling
    madwheeling New Member
    Michigan
    2022 Tunda
    I was able to get it tucked behind the edge headliner and only had to remove the C pillar trim and drop the front part of the headliner. I had to do the front headliner to wire in the dash cam anyways.
    raylo[OP] likes this.
  7. Jan 28, 2023 at 10:30 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
  8. Jan 29, 2023 at 7:33 AM
    raylo
    Frederick, MD
    Got a Viofo A229 duo 2K coming. I had the 129 Pro Duo in my Tacoma and it worked great. I am going to try to make this work with the Dongar adapter for the existing socket in the overhead for now. Maybe do the hardwire kit and battery later if I decide I really want to use parking mode.
  9. Jan 29, 2023 at 10:39 AM
    jvperez
    jvperez New Member
    2023 Tundra SR5 CM LB 4x4
    I installed the thinkware u1000 with the rear cam. I just used a long borescope and made my way through the headliner to the rear passenger corner, once there just used the borescope as a fishing tape and used it to pull the cable. Took a bit to get the borescope there but it was easier than dropping the headliner.
  10. Jan 29, 2023 at 10:51 AM
    raylo
    Frederick, MD
    That's a good idea. I have these super thin and flexy fiberglass fish rods that might work, and not damage the headliner like a coat hanger wire could.
  11. Jan 29, 2023 at 11:23 AM
    Maharisc
    Maharisc w/Patty
    Karl
    I used to make the adapters as a hobby until Dongar spun up on them, see pic below. The connector can be pinned to either Hot or Ignition. Another Dashcam thread on that somewhere here. Then I cut off the Dc-Dc convertor and put on the Vantrue N4 hardware kit since my truck sits for a week most day. That is the way to go.
