General Supercharger Thread
  1. Jan 27, 2023 at 2:14 PM
    #5251
    AZTundra
    Paul
    Phoenix, AZ
    The other Magnuson log was likely mine before Viktor's tune. It was posted a while back (last December I think). I ran with the Magnuson base tune for ~20K miles and also hope I didn't do any damage. I could actually hear what I thought was pinging under certain conditions (low rpm, then applying moderate throttle) which is what led me to getting a custom tune. I had always wanted to have a custom tune done for it, but other mods always seemed to take priority. Once I saw the before/after data logs it really hit home on how bad the base tune was.
    I'm still just running the Maggy as-is aside from Viktor's tune, stock pulley, the green injectors, and the flex fuel pump. I'm still tempted every day to follow you guys down the rabbit hole of more HP, but I'd need new injectors, pulley, and fuel pump along with a retune and not sure I can justify all that unless someone can talk me into it.
    snivilous[OP] likes this.
  2. Jan 27, 2023 at 2:20 PM
    #5252
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    That makes me feel a little better about not getting the tune. To date, I’ve never heard any signs of pinging or knock. I’m on stock exhaust so I should really hear it if it was audible.
    A tune was also in my plans but it took a whole damn year to buy the parts and make time to install them. Also truck was in body shop for 3 months.
    And you’ve done a good job not buying the parts thus far while still being active on the forum. That’s almost an impossible feat!
  3. Jan 27, 2023 at 2:28 PM
    #5253
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I got a new MAF. No codes yet
    it was dirty.
  4. Jan 27, 2023 at 3:08 PM
    #5254
    trddriver
    trddriver New Member
    '14 1794
    open to discussion
    Not sure if this will help you with your lean-ness, but surely this is lurking in someone's dark thoughts. Screenshot_20230127_160417_Opera.jpg thought this was brought up yesterday and maybe dismissed, but this is 8 grooves, and says fdfi, so maybe this is for you (yes you) :spending:
  5. Jan 27, 2023 at 3:15 PM
    #5255
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    There's the party pulley!
  6. Jan 27, 2023 at 3:57 PM
    #5256
    Saltyhero13
    Saltyhero13 Throbbing Member
    Cleaned mine when I swapped out the oiled K&N and PS Intake. No codes for months.
    Possible my air is very straight now and less festive and flamboyantly dressed.
  7. Jan 27, 2023 at 4:03 PM
    #5257
    Saltyhero13
    Thinking out loud. If we know the needs for a given target HP, any way to calculate FPM? CFM is FPM x Area according to the Google Oracle.
    Probably not so simple.
  8. Jan 27, 2023 at 4:06 PM
    #5258
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    450 pump here with maggy green injectors.
    ssmokedz and V10Ace like this.
  9. Jan 27, 2023 at 4:25 PM
    #5259
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Lol, straight air you say? Did you install an air straightener and not tune it with it installed by chance?
    Using my numbers for the calculation of an 80mm pulley and a 3.875” intake it would be 13,285 ft/min. What does the ft/min do for us?
    VWTim likes this.
  10. Jan 27, 2023 at 4:32 PM
    #5260
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Hmm, looking back at prices I'd probably have bought the ProSpeed fuel rail/line kit and 450lph fuel pump kit. I'll come out about $200 ahead, buying everything separately including the XAT fuel rail. But I'm also having to cut and do the lines myself where it looks like theirs is premade. At least this way I have some customizations I can do. And using their instructions as a secondary guide.
    I would not buy their injectors. Get the Five-O's
    Silver17, reywcms and snivilous[OP] like this.
  11. Jan 27, 2023 at 5:03 PM
    #5261
    Saltyhero13
    RE: Codes. Needing a retune is a possibility I considered.
    The straightener has been installed for a while since I put the Stillen in, but yes it was all put in after the original "Stage 2+" tune. Unless it is "choking" the intake I would think it would probably read lean, not rich, if the MAF is reading more air than actually delivered, no?
    Another possibility is the ID diamater of the MPR is significantly smaller than the ID of the PS intake. I'll have to measure the thickness of the 4inch OD tube I have from MPR to see the difference. From what I recall it was less than 1/32 difference, but it may be even smaller.
    I'll keep it simple for starters and replace the MAF since the oil filter was causing me to throw codes originally. Cleaning the MAF worked for about a year. Might be due for a new sensor.
    RE: CFM. The article you linked earlier is giving a general rule of thumb to calculate HP needs in terms of CFM. 1.5 CFM per 1 HP. 1000 HP requires 1500 CFM. If we know target HP needs for CFM we can figure out TB size. How? If CFM = FPM * Area we can calculate Area (for the TB) if we know FPM. Can we calculate FPM somehow? That is what I am asking.
  12. Jan 27, 2023 at 7:02 PM
    #5262
    Silver17
    Eastern PA
    I was using this calculator which you can calculate LFM (Linear Feet Per Minute) from CFM if that’s what you mean. Im not sure where that comes into to play but you can mess around with it and see if you can calculate what you’re after. We already know the stock throttle body is 76mm so the area is probably slightly less than 7 square inches. The 82mm RCF TB should be slightly less than 8.18 square inches. https://blackhawksupply.com/pages/airflow-calculator
    Saltyhero13[QUOTED] likes this.
  13. Jan 28, 2023 at 10:30 AM
    #5263
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Pump's out.. They're going to replace this plastic crap with fuel rated rubber hose and see what that gets us.
  14. Jan 28, 2023 at 10:49 AM
    #5264
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Nice, those "hoses" remind me of big gulp straws that sound like elk bugles when you blow thru them! Ahhh, memory lane...actual rubber hose will be better...glad they're acknowledging your despair!
  15. Jan 28, 2023 at 10:51 AM
    #5265
    trddriver
    '14 1794
    open to discussion
    @V10Ace is the kean condition something that is constant? I had a few things go awry with an aeromotive 340 in my M5.
    In the end I had two problems:
    1 the pump would completely die for about 25 min, I was able to correlate this to volum if fuel in tank, only happened on half tank or less, and after running for a good while, so pump was overheating. 3 pumps all did this, and the were all purchased from jegs. I don't know if it was a bad batch, Chinese knockoff, or what, but OEM pump was reinstalled with no issues since (many many miles).
    2 the check valves were faulty on 2 of the three pumps after a while.. So I'd crank like a carb car, where that was never the case with good fuel pump. I could blow backwards through the outlet when they were pulled. As before this was not an issue when Bosch pump reinstalled.
    So.... Do you notice symptoms worse when lower fuel, out of curiosity? I really don't see how that plastic tube would make you run lean unless it is supplying to your system and perhaps leaking or a restrictive ID hose. Not saying they're wrong, just seems the more likely culprit would be pump related without other obvious flaws, and that is considering they've checked fuel pressure during load (ie the tune is proper and fuel supply is deficient). Only saying what I would ask if my truck.
    Anyhow, I'll shut up and let the pros do their thing.
  16. Jan 28, 2023 at 10:51 AM
    #5266
    snivilous
    SW UT
    300k+ Supercharged 2008
    12 minutes and 45 seconds later and we are back to a 2.30" pulley! I'll run this for the next two weeks since I'm driving to LA this weekend and then back near Barstow with a trailer for an off-road event next week.
    Silver17, Wynnded, reywcms and 6 others like this.
  17. Jan 28, 2023 at 10:52 AM
    #5267
    trddriver
    '14 1794
    open to discussion
    OK, who was holding the stopwatch? Lol
    Looks good.. Enjoy your trip!
    snivilous[QUOTED][OP] likes this.
  18. Jan 28, 2023 at 10:53 AM
    #5268
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    We haven't driven the truck much as we're trying to establish an initial tune under normal driving and now WOT. They suspect when the pump ramps up and needs to deliver more fuel that there's a leak happening and causing blow by. Tank is half full
    Regulator is at 60psi per Prospeed. We are unable to see what happens to the gauge under load as we aren't on a dyno. We tried a go pro under the hood and driving around but can't see the gauge
  19. Jan 28, 2023 at 11:00 AM
    #5269
    M3Tundra-JK
    Scott
    2005 GX470
    Which pump did they replace it with? Curious if that's the original white hose or not also. You have to make a cut with a razor blade to get the old one off, and there's a special tool to use to get those types of hoses on without the hose clamp. Also didn't see any splices in the blue/grey wires
    V10Ace[QUOTED] likes this.
  20. Jan 28, 2023 at 11:05 AM
    #5270
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Walbro 450. PS sent us a connector splice kit with it.. waiting to hear back more at this point.
  21. Jan 28, 2023 at 11:05 AM
    #5271
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    That is actually PTFE tubing, it's preferred over fuel-safe rubber for in tank plumbing as it's ethanol safe. Your connection looks good, see a little bulge from the barb fitting under the clamp, shouldn't be leaking past that.
    I actually tested mine, I put the assembly in a 5 gal bucket of gas and pumped it through my regulator and back into the bucket, cranked it up to 80PSI with no leaks from fittings. I had two 2x4s across the top of the bucket with the assembly hanging between it, zip tied down for safety of course, and return going back through the top as it would have in the truck
    Here's mine:
    rockmup, reywcms, trddriver and 3 others like this.
  22. Jan 28, 2023 at 11:09 AM
    #5272
    M3Tundra-JK
    Scott
    2005 GX470
    Ah nice. I ordered my 450 pump through Figs Engineering in Denver, who goes through ProSpeed. But all I got was a pump and no install kit...
    HulkSmurf14 and V10Ace[QUOTED] like this.
  23. Jan 28, 2023 at 11:14 AM
    #5273
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Being as I'm not the one doing the actual work, is there only one way the pump drops in? Troubleshooting different reasons why we aren't getting enough fuel... there's no leaks outside the tank that we can find.
  24. Jan 28, 2023 at 11:16 AM
    #5274
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The 450 replaced the plastic assembly that the old pump houses, it basically just sits in the bottom of the basket, here is a shot of my pumps, the white cover to the right would snap over it and the lines go through the cover:
    M3Tundra-JK and V10Ace[QUOTED] like this.
  25. Jan 28, 2023 at 11:18 AM
    #5275
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    The shop I'm going through knows what they're doing and and is reputable in the area for Toyota builds. I'm the guinea pig with the PS stuff for them, however. It looks to me like a hard to F up kinda thing lol
  26. Jan 28, 2023 at 11:20 AM
    #5276
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yeah, it's not rocket surgery :) Two wires and one high-pressure hose connection...did they receive instructions to add holes to the basket? So the pump could draw more in? The stock hole is limiting.
    V10Ace[QUOTED] and trddriver like this.
  27. Jan 28, 2023 at 11:23 AM
    #5277
    M3Tundra-JK
    Scott
    2005 GX470
    They can remove that tiny black hose with the tiny grey connector at the top. It doesn't do anything anymore. It also connects down to a blue thingie that slips over the bottom fuel inlet. Doubt it makes any difference, really, but it's unnecessary after removing the factory pump housing
  28. Jan 28, 2023 at 11:30 AM
    #5278
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Tossing your questions at them. Thank you guys!
  29. Jan 28, 2023 at 11:30 AM
    #5279
    trddriver
    '14 1794
    open to discussion
    Exactly. This is why I'd push for the loaded fuel pressure readings to confirm pump is viable... Dyno, sure, right there on the asphalt ;) can even tap into your underhood and extend temporarily to the front window or any other good place to view when loading it.
  30. Jan 28, 2023 at 11:31 AM
    #5280
    M3Tundra-JK
    Scott
    2005 GX470
    Here's mine, and picks of the tiny line to remove
    I'm trying to finish up the tank stuff today and get it reinstalled tomorrow
    V10Ace likes this.
