What is this wire or cable?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra2010&60, Jan 27, 2023.
  1. Jan 27, 2023 at 4:56 AM
    Tundra2010&60
    Tundra2010&60 [OP] New Member
    Northern Maine
    2021 Tundra LTD/TDR Smoked Mesquite/Black Leather
    Running Boards
    While chasing the wiring for my Fishstick for the Fisher plow yesterday I noticed a wire coming through the firewall something had chewed the insulation off.
    There is a grommet in the firewall the Fishstick cable goes through. Just above that , this is on the driver side, is a single black wire/cable I think had its own light blue plastic grommet going through the wall. The insulation is chewed off for about six inches revealing a rusty piece of cable underneath. Does nnot appear to be copper and feels rigid.
    Any ideas what this is for?
  2. Jan 27, 2023 at 5:09 AM
    Pics would help. Was the truck previously owned? It could be an aftermarket accessory of some sort. It could also be a dealer installed GPS/tracker for anti-theft.
  3. Jan 27, 2023 at 5:16 AM
    Vizsla
    Vizsla 2 = 2.5
    Hood latch release cable.
    Black Wolf and NewImprovedRon like this.
  4. Jan 27, 2023 at 5:33 AM
    I didn't think about that one....too early lol.
    NewImprovedRon likes this.
  5. Jan 27, 2023 at 5:34 AM
    Tundra2010&60
    Northern Maine
    Running Boards
    I am the original owner. Its a 2021.
    I think that might be it that its the hood latch cable.
    So there is no problem if the insulation is chewed off that?
  6. Jan 27, 2023 at 5:38 AM
    No, its just a solid cable for the hood latch. However, if it has been chewed, i would look at all of your wiring in the engine compartment, especially under the engine cover.
  7. Jan 27, 2023 at 5:55 AM
    Tundra2010&60
    Northern Maine
    Running Boards
    Yes I've been looking over all the wiring very closely becasue of this problem I'm having with the plow these last two weeks. I had noticed a red squirrel under my truck a few times last summer and found some pine cone scraps on the plastic cover on the engine. I took care of that critter. Due to the rust I'm thinking it dates back to that.
    I feel lucky he choose that cable out of all the small wiring he could've gotten to.
    Will continue to look over the wiring as I work on the f-ing plow trouble.
    Thanks much.
    Tundra234[QUOTED] likes this.
  8. Jan 28, 2023 at 5:19 AM
    Tundra2010&60
    Northern Maine
    Running Boards
    So does it matter if this cable is covered or not? From testing it with helper I'm assuming there is another wire sliding inside this steel casing to control the latch?
    Was thinking maybe in summer I'll clean off the rust and wrap it w tape or heat shrink it.
    HulkSmurf14 likes this.
  9. Jan 28, 2023 at 5:33 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Squirt some lube and tape it up...braided wire LOVES soaking up moisture so if you don't lube it or protect it, it will break at the worse time...for the winter (rest of this one) you're more then likely good as it is.
    Vizsla likes this.
