Rough county flare
Discussion in '3rd Gen Tundras (2022+)' started by Tom, Jan 14, 2023.
  1. Jan 22, 2023 at 8:36 AM
    #61
    Tundra009
    Tundra009 New Member
    Concord, CA
    I'll take another one later
  2. Jan 22, 2023 at 9:29 AM
    #62
    Timmy23
    Timmy23 New Member
    OR
    23 SR5 CM TRD OR MGM Tundra
    3” lift kit, 35’s, WW flares, tonneau etc.
    Side views of 35x12.5 R20 on Fuel 10” wide. Plus 1 offset.
  3. Jan 22, 2023 at 9:44 AM
    #63
    bigjuice
    bigjuice Researching and collecting parts…
    WA State
    2022 MGM Crew Max SR5
    Thanks gents…much appreciated
    Medic343 likes this.
  4. Jan 23, 2023 at 2:33 PM
    #64
    WoodfordAZ
    WoodfordAZ New Member
    Alex
    2022 White Tundra SR5 TRD
    Installed yesterday. Pretty simple. The hardest part (for me) was getting the rubber trim uniform the entire length of the flare.
    For reference, I am running 17x8.5 +35mm Method 706 with 315/70-17 Wildpeaks. With my color scheme of just white and black, I think it looks perfect and have zero plans to ever paint match. My factory flares were flat black anyway, and if I get enough "Arizona pinstriping" (or worse) on these, I'll just throw on another set.
    tundznoff, wayoflife and PBNB like this.
  5. Feb 22, 2023 at 10:33 AM
    #65
    BMP
    BMP New Member
    2023 Tundra SR5 SX MGM CM 4X4
    Anyone installed the Sports on an SR yet?
    Brad
  6. Feb 22, 2023 at 6:58 PM
    #66
    Timmy23
    Timmy23 New Member
    OR
    Ain’t nothin to it, but to do it. :)
    Rockgate likes this.
  7. Mar 3, 2023 at 4:58 AM
    #67
    BMP
    BMP New Member
    How close are you guys to rubbing with the Sports and front wheels at full lock? Going to try and run a 2-3" lift, 35x12.5018's on an 18X9 with 18mm offset.
    Brad
  8. Apr 13, 2023 at 7:49 PM
    #68
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    mine showed up last week, getting painted WCP first week in May... cant wait
  9. Apr 13, 2023 at 7:59 PM
    #69
    Tundralicious
    Tundralicious New Member
    Toytoy
    2020 Tundra TRD Sport Premium
    Stock for now
    I have the same setup as you do except I have 33 nitto recons. Did the Fender Flares helped a lot to keep the truck clean? With 2" offset, a puddle makes it look like you went mudding hahaha
  10. Apr 13, 2023 at 8:00 PM
    #70
    Tundralicious
    Toytoy
    Stock for now
    Do they help keep the truck clean or are mostly for the look?
  11. Apr 13, 2023 at 11:41 PM
    #71
    Timmy23
    Timmy23 New Member
    OR
    My truck stays fairly clean with the flares compared to before I installed them.
    About the same as any other truck I’ve had.
  12. Apr 14, 2023 at 8:18 AM
    #72
    pawner
    pawner New Member
    Chattanooga, TN
    2022 Tundra Limited with Leer 100XR
    I love the way these look. Had to drill out some new holes in them to fit my aftermarket REKGEN mudflaps on. Was a simple install other than that.
    Living on a gravel road, have already seen the reduction in dirt getting on the side of the truck along with the mud flaps.
    Durtywrench and Mattedfred like this.
  13. Apr 15, 2023 at 8:47 PM
    #73
    WrapCO
    WrapCO New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    To be honest, I wish they were better. But they definitely help. Still get plenty of spray.
  14. Apr 16, 2023 at 9:51 AM
    #74
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    2022 Limited Crewmax L
    MBM - TRD Offroad
    Did anyone get a painted set to match the Toyota color codes? I am wondering how close the RC painting is to the factory paint. Im my case, I would be looking at the MBM matched flares. Just don't want to waste the extra cost if it isn't a good match.
  15. Apr 16, 2023 at 2:52 PM
    #75
    DexterL
    DexterL New Member
    question, how did you line up your cut from the c4 bumper with the new flares? Just tried to put one on to check before paint and I’m scared to hack into it
  16. Apr 18, 2023 at 7:54 PM
    #76
    23LUNATRD
    23LUNATRD New Member
    23 Tundra SR5 TRD Off-road LunaRock
    Installed the RC Sport flares yesterday, so far I'm a fan 20230417_194259.jpg 20230417_194211.jpg 20230417_194245.jpg
    Before
    Jarrow, Black widow TRD and PBNB like this.
  17. Apr 18, 2023 at 8:28 PM
    #77
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    Looks great! Do you run spacers behind those wheels?
    Are those the base black flares or are they painted, they look like they are coated with a semi gloss?
    I am looking at matching some to my Midnight Black Metallic truck but still considering the base blacks ones.
  18. Apr 19, 2023 at 3:36 AM
    #78
    23LUNATRD
    That is correct, I'm running Spidertrax 1" spacers behind the factory 18" TRD OR wheels. Tires are Nitto Recon Grapplers 295/70/18.
    The flares were ordered as matte black, but I agree it's more of a satin then matte.
    Overall installation was simple. The only part that was truly time consuming and a pain was installing the wiper style seal along the top edge of the flare.
  19. May 4, 2023 at 9:29 AM
    #79
    DexterL
    DexterL New Member
    WCP color matched rough country sport flares. Thanks @WrapCO for saving me!
    35x12.5x17 with 12mm offset wheels
    KNABORES and PBNB like this.
  20. May 4, 2023 at 5:39 PM
    #80
    WrapCO
    WrapCO New Member
    Eagle , CO
    SICK! Stoked it worked out :D. I appreciate ya, it looks great.
    DexterL[QUOTED] likes this.
  21. May 4, 2023 at 6:59 PM
    #81
    pawner
    pawner New Member
    Chattanooga, TN
    I assume you ended up trimming the front fenders? I plan on getting the same bumper and was wondering how I'd go about it. Did you end up putting in extra screws or clips to add more points of attachment after trimming?
    Either way, looks really clean!
  22. May 5, 2023 at 6:55 AM
    #82
    DexterL
    DexterL New Member
    kind of a funny story, I got my set and measured them out- went to cut one and had to trim it a bit and completely botched the cut, then I did the same thing on the other side. I had reached out to @WrapCO about how he did it, but got impatient waiting 20 minutes and went for it and screwed up the fronts. Luckily he was taking his off and sold me the kit super cheap… his cuts were perfect and I actually had to retrim my plastics to align with the flares and looks much cleaner now.
    No extra screws or anything to keep them on, they are rock solid. The 2 clips that go on the top of the front flares really hold them on. I’m picking up some longer screws today so I can remount my Rexgen universal mud flaps with the flares.
    100% recommend having them color matched, looks factory clean- wife hasn’t even noticed!
    that being said, I have a set of used rear flares and a set of fronts that have been cut for a c4 bumper- but about 1/4in too short if anyone wants them!
    Texan-1794 likes this.
  23. May 5, 2023 at 7:11 PM
    #83
    pawner
    pawner New Member
    Chattanooga, TN
    Got it, glad it worked out for you. I don't have the rekgen universal flaps but the 3rd gen specific ones, and it was a bit of struggle for me to get them mounted with the rough countries, but ended up working out at the end. Longer screws would have definitely helped!
  24. May 6, 2023 at 9:42 AM
    #84
    PBNB
    PBNB TRD Crew
    Peter
    Vancouver, BC
    MBM - TRD Offroad
    After waiting for my Pro flares and was about to give up and order these, Sparks sent my flares! I like the Pro flares but they don't look to have the same coverage as these Sport flares. I still have some front tire poke :(
    My offset is not crazy at nearly +20 but my tires are a bit wider being a 295/60 so the tire is creating the added poke.
    Looking forward to seeing some painted Sport flares to see how the color match works on the metallics...
  25. May 6, 2023 at 12:06 PM
    #85
    DexterL
    DexterL New Member
    just posted photos of mine, will grab some better ones once the sun starts shining again
    PBNB[QUOTED] likes this.
  26. May 7, 2023 at 1:17 AM
    #86
    FREEDOMcomesatacost
    FREEDOMcomesatacost Go ahead, pull my finger…
    Just call me Easy
    Louisiana
    2022 SR5 Crewmax supersonic red
    Too much to list…
    I love the way they look painted or left black (left mine black as matched the color scheme i have going on):
    Jarrow, Black widow TRD and Timmy23 like this.
  27. May 7, 2023 at 1:49 AM
    #87
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    To reduce or prevent rubbing in damaging your paint, you could apply 3M protective film tape where the fender flares rest up against the body panels. It does come in rolls 1/2 inch wide.
  28. May 7, 2023 at 9:02 AM
    #88
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Any issues with rubbing if you go off-roading? Truck looks freaking awesome!!
  29. May 7, 2023 at 9:08 AM
    #89
    23LUNATRD
    I haven't had many opportunities to take it off-road since I've installed these. The limited opportunities I've had I experienced zero rubbing or interference.
  30. May 8, 2023 at 5:02 AM
    #90
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    If applicable, do you remove the factory flares to put these on? Anyone have factory painted flares they want to get rid of? I want to color match them with wrap and it doesn't doesn't stick to the bare plastic.
    Edit: I read through and see the sport ones go over the factory flares. This may be the way I go instead of factories color matched. I like the way these go around the full arch. I have factory mudflaps to I guess that'll be something to deal with.
