When you can’t find that pesky oil leak.....
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Apr 13, 2021.
  1. Mar 7, 2022 at 3:08 PM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I hope that the o ring is your leak. It was on mine.
    Since the oil pan is glued on, that seems unlikely culprit.
  2. Mar 7, 2022 at 3:31 PM
    Diablo675
    Diablo675 New Member
    2001 Tundra
    Tuff Country lift, headers, new Jeep seats, custom made console, many more.
    I think that the figure 8 O-ring is the problem. The leak got worse after moving the adapter around and reassembling it without replacing the O-ring. I am fairly sure that the new one will fix it. I mean, that O-ring is 21 years old and then I disturbed it by rotating it.
  3. Mar 7, 2022 at 3:57 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I think at 21 years, you got your monies worth.
  4. Jan 23, 2023 at 12:48 PM
    adanielfish
    adanielfish New Member
    Hello Diablo 675.
    I need to understand more on how to get to the last bolt. did you completely loosen the ac compressor (not the hoses) and move it out of the way of the one bolt that is behind the ac compressor?
  5. Jan 23, 2023 at 1:22 PM
    The repair for this problem is covered on the awesome Toyota Maintenance YouTube channel:
    https://www.youtube.com/watch?v=eeWAQzcqhPo
    w666 and NewImprovedRon like this.
  6. Jan 23, 2023 at 1:38 PM
    adanielfish
    hello shifty - yeah started this double oring gasket replacement based off this video. The sequoia must be slightly different than the Tundra. there is a bot behind the ac compressor on my Tundra configuration.
    Thanks.
    shifty` likes this.
  7. Jan 25, 2023 at 2:52 PM
    tdrich7
    tdrich7 New Member
    2006 Tundra DC 4wd SR5
    Anyone know how much more involved that makes this compared to the above video? I was just told my truck has this same issue.
  8. Jan 25, 2023 at 3:31 PM
    adanielfish
    I talked with Diablo675 again and it will take some doing but he has mentioned a couple of times to me now that it is well worth it. I have 285,000k on my 06 DC & just changed the valve cover gaskets & that did not completely solve the oil leak problem. I can see and am 99% sure it is this little figure 8 o-ring @ the oil filter adapter.
    I'm going to tackle mine in the next month and will keep you posted.
    tdrich7 likes this.
  9. Jan 27, 2023 at 7:35 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Update.
    Still no drips after the oring repair.
    bmf4069, w666 and shifty` like this.
  10. Feb 18, 2023 at 5:40 PM
    adanielfish
    Well I tackled that job today. Took 3+ hours. It definitely was the culprit..... No Drips! my driveway has taken a beating for the last year, but no oil now.
    When Diablo675 talk about loosening the AC compressor, its not only the compressor in the way, it's the bracket for the AC compressor.
    This job was well worth it.
    Please reply with any questions while my mind is fresh.
    shifty` likes this.
  11. Mar 5, 2023 at 9:08 AM
    So @adanielfish asking for @68BelowZero due to his frustration over here. I'm replying here in this thread to try and keep the info consolidated.
    If I'm reading your reply right, it looks like you not only had to loosen the A/C compressor, but also the A/C compressor bracket in order to get the filter cooler/housing off, correct? Can you go into a little more detail about that process, what the "Aha!" was that finally let you pull the housing out?
  12. Mar 5, 2023 at 10:21 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I’m glad my post has helped some people. I sure have learned a lot from you fine folks.
  13. Mar 5, 2023 at 11:44 AM
    adanielfish
    That is correct. You loosen the AC compressor and move it to the side. Once it's moved to the side, there is a fairly large bracket that holds the compressor - If I remember correctly, there are two bolts holding this on. Once you get this ac bracket off, you have complete access to the last bolt that is holding the oil filter adapter. I did not have to unhook the cooling lines that went to the adapter, and was able to put the double o-ring gasket in with the lines still hooked up.
    I used some really long 1/2" socket extensions to get to all of this with swivel adapters for my impact.
    You will get access to a lot of the bolts from the drive side wheel well (you will need to remove the wheel well shield).
    Like I said, it took me all of 3 hours, but is totally doable and if you have a leak there, this is the fix.
    I still have NO LEAK!!!
    please let me know how this goes for you and please don't hesitate to ping me again.
    Thanks
    shifty` likes this.
  14. Apr 5, 2023 at 8:29 PM
    Cajunman007
    Cajunman007 New Member
    Shane
    Lafayette, LA
    02 Tundra Access Cab 4x4 4.7
    It has been an adventure today for me. 2 of the bolts had rounded heads, then the top left bolt is blocked by an ac line. Still have yet to get that last bolt. Had to quit for the day before I got my Sig out! And 2 of the bolts weren't even tight!
  15. Jul 1, 2023 at 12:05 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Thank you for this thread. I think that where my leak is coming from.
  16. Apr 22, 2024 at 12:04 AM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    Thank you! Exactly what I needed, was going to re-due oil pan gasket,then saw the cross member and was considering backing out, went to do the oil filter and saw the oil build up on top of oil cooler and thought oil cooler hose must be leaking, all were clean but one, but got too dark to trace any farther, this I exactly what's going on. Getting ready to do timing belt,water pump, valve cover gaskets, cam seals ( I don't understand why they are there or what they do, but that doesn't change the fact they need to be re-glued,( not glue, glue but 103 or right stuff)
  17. Apr 27, 2024 at 1:57 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I just did this and replaced the oil filter o-ring as well it’s right there
    15692-50020
    Oil cooler figure 8 Seal
    90301-67004
    (Oil filter o-ring)
  18. Apr 28, 2024 at 9:48 AM
    USERidiculousNAME
    Josh
    New Orleans
  19. Apr 28, 2024 at 9:49 AM
    USERidiculousNAME
    Josh
    New Orleans
    Just ordered fig 8 forgot the o-ring thanks
  20. May 3, 2024 at 1:51 AM
    #50
    Eddie's XSP X
    Eddie's XSP X New Member
    Eddie
    Savannah, Georgia
    2016 Tundra CM XSP X/ 2005 Tundra Double cab limited
    24 inch Niche wheels with Nitto off road tires
    Just wanted to add to the problems and solutions to the hidden oil leak from the figure 8 gasket and possibly the oil filter housing. All the research you guys have looked up was spot on. Never would have known without you guys help. Wanted to add to clarify some confusion. The task is simple just time consuming and messy.
    Sequoia's are different than the Tundras. Tundra are a little more involved. I've taken a picture of what the a/c bracket looks like so you can vision what's needed to gain access to the hidden 3rd nut. You don't have to touch the a/c compressor itself mount bolts at all only the a/c bracket. There are 3 14mm bolts that hold the bracket to block. The rear you can access from under the truck and loosen but all the way but leave a few threads in. The other 2 completely remove. I did the top second and removed the bottom to keep it from dropping. I got about 12 zip ties wrapped 2 around the compressor and tied them up to the radiator mount bracket and tightened them until it held the compressor up enough to gain access to the nut and remove the filter housing.
    I was working by myself that compressor weighs a bit. Here is a picture of the bracket the compressor sits on. I replaced the hoses that goes to the block from the coolers. They were the originals. The front looked good the rear was on its way out with all the oil that was dripping over the years. I inverted the picture to how it sits in the truck. Hope this help clarify and make it easier for the next.
    Teutonics likes this.
  21. May 3, 2024 at 6:14 AM
    #51
    Eddie's XSP X likes this.
  22. May 3, 2024 at 6:51 AM
    #52
    Eddie's XSP X
    Eddie
    Savannah, Georgia
  23. May 3, 2024 at 6:55 AM
    #53
    Eddie's XSP X
    Eddie
    Savannah, Georgia
    I know the chemical your talking about. I've used it years ago when I used to buy acura legend for 500.00 because of blown head gaskets. But used this to smooth shifts after a transmission flush. Stuff works wonders. Maybe if it had low miles?
  24. May 3, 2024 at 7:01 AM
    #54
    They say (maybe even guarantee?) it won't over-swell gaskets like some of the other miracle-in-a-bottle temporary fixes do. "gasket rejuvenator" is ultimately how they're branding it. Worked to shore up my dry ass valve cover gaskets, only to find one final small leak was due to piss poor FIPG.
  25. May 3, 2024 at 7:12 AM
    #55
    Eddie's XSP X
    Eddie
    Savannah, Georgia
    Good idea I may have to get me a bottle today. They say advance have it but early 2000's Napa was the only place I could find it at.
  26. May 3, 2024 at 7:19 AM
    #56
    My two local Advance stores usually have it on the back wall, in between the Seafoam and CRC MAF cleaner. I usually order online and use coupon RMN15 to get 15% off for in-store pickup. It's already cheaper to buy it full price there than to order on scAmazon, the coupon is icing on the cake.
  27. May 3, 2024 at 7:34 AM
    #57
    Eddie's XSP X
    Eddie
    Savannah, Georgia
    Ok got you thanks!! Going to get some today. My buddy asked for a good product to use for his dodge truck and I totally forgot to mention this one. Your the man!!
  28. May 3, 2024 at 1:53 PM
    #58
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    shifty`[QUOTED] likes this.
  29. May 3, 2024 at 4:50 PM
    #59
    Took about 200-300 miles of driving before I saw full effect.
  30. Jun 8, 2024 at 8:14 PM
    #60
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD 4.7L AX
    Tackled this job today, and this right here is the answer!
    Recap: Remove the two large bolts at the front of the compressor bracket and loosen (a lot!) the one large bolt at the back of the bracket (do not remove the compressor from the bracket with the four smaller bolts, it's not necessary). It was still very difficult to get the oil cooler bracket off, but after loosening the rear bolt to the point I thought it might fall out gave enough room to remove the oil cooler from the block. Thanks OP!
    (unfortunately I don't think this was where my oil leak was though. :-( )
