General Supercharger Thread
  1. Jan 16, 2023 at 2:17 PM
    #5041
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    With grill mocked up
    reywcms, Black@Blue19 and HulkSmurf14 like this.
  2. Jan 16, 2023 at 2:20 PM
    #5042
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Lose the grill, it's hiding the business!
    M3Tundra-JK[QUOTED] likes this.
  3. Jan 17, 2023 at 12:17 PM
    #5043
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I ordered a 12x12 inch section of the MAF screen. I went with the thinner option which I hope is good. If the timing works out I may cut one for my 3.5” intake before switching to the Maggie box just to see if it cleans up my AFR gauge reading out of curiosity. I’ll probably have a bunch left after using it for 2 intakes if anyone else wants some, I think it can be sent in a USPS cardboard envelope. It seemed more cost effective to buy a whole sheet, with shipping it was $40.
    HulkSmurf14, reywcms and M3Tundra-JK like this.
  4. Jan 17, 2023 at 1:01 PM
    #5044
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    HA, they're HATING you on Reddit! Didn't make the connection it was you from here.
  5. Jan 17, 2023 at 1:15 PM
    #5045
    Saltyhero13
    Saltyhero13 Throbbing Member
    "bUt ThE pAiNt WiLl ImPaCt CoLlInG!1! dUrR!1eleventy!"
    :duh: = the typical redditor
    M3Tundra-JK likes this.
  6. Jan 17, 2023 at 2:47 PM
    #5046
    M3Tundra-JK
    Scott
    2005 GX470
    Oh you should go through my history and see how I pissed off the /r/jeep forum lol
  7. Jan 17, 2023 at 2:50 PM
    #5047
    M3Tundra-JK
    Scott
    2005 GX470
    Black@Blue19 and snivilous[OP] like this.
  8. Jan 17, 2023 at 3:00 PM
    #5048
    snivilous
    SW UT
    300k+ Supercharged 2008
    Even jeep guys know jeeps suck :D
  9. Jan 17, 2023 at 3:06 PM
    #5049
    Saltyhero13
    Which leaves me in disbelief that more manufactures haven't jumped into that market. I see the new Bronco is very jeep-like.
  10. Jan 17, 2023 at 5:17 PM
    #5050
    ZPhilip
    Philip
    West Chester, PA
    That would be the ultimate (non-biased) before and after test. Just saying.
  11. Jan 18, 2023 at 6:38 AM
    #5051
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    remind me....what side do you put the wideband exhaust bung on? driver or pass?
    I remember there being an ideal side.
  12. Jan 18, 2023 at 6:41 AM
    #5052
    nobodyintexas
    nobodyintexas What?
    South of Houston
    and then...
    on the boost gauge: did you have to "T" off the boost connection on the Harrop? as I see there is presently a connection on mine. Fuel ref?
    getting my sh1t together.
  13. Jan 18, 2023 at 6:52 AM
    #5053
    snivilous
    SW UT
    Passenger side theoretically runs leaner. I have mine next to the stock sensor which as I recall seemed easier at the time than the driver's side anyways.
    Yea just T into it if it's already going to the FPR.
  14. Jan 18, 2023 at 4:20 PM
    #5054
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    @snivilous what coupler you running? I think mines due for one soon.
  15. Jan 18, 2023 at 4:55 PM
    #5055
    Silver17
    Eastern PA
  16. Jan 18, 2023 at 5:04 PM
    #5056
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  17. Jan 18, 2023 at 6:52 PM
    #5057
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    You cannot order TRX without packages anymore, 2021 was last year you could order a "base" TRX, that also means prices have gone up by a lot.
    Another issue is width, TRX is nearly 10 inches wider, has worse turning circle, it's pretty much a no go for lot of drive throughs and city is pretty much a no go, you will stick out a solid foot when park on the streets, and it's nearly impossible to get past 12mpg , towing is pretty much constantly single digit.
    It also rides stiffer than most think, even in normal mode, compare to even a basic fox 2.5 kit, the fox rides like a Cadillac in comparison,.
    I was seriously ready to order a base model in 2021, it's a wicked truck, but at the end I couldn't pull the trigger, I've had a 2019 rebel, had no issue with it, but I like the Tundra more, someone mention TRX maybe cheaper, TRX puts down mid to high 500 on dyno, some here puts down nearly the same and Im sure it's cheaper to build the engine, a fully built 3ur is about 15k ( no supercharger) and it should have same power as TRX, and probably run same in 1/4 mile.
    Fyi, I tow a lot in summer, 11mpg is pretty much what I get, I'd like more power and that's in the works.
  18. Jan 18, 2023 at 7:14 PM
    #5058
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What’s wrong with wide widths lol
  19. Jan 18, 2023 at 7:16 PM
    #5059
    snivilous
    SW UT
    Hopefully none of you bought that overpriced block. Here is my summary of couplers:
    https://www.tundras.com/threads/general-supercharger-thread.85513/page-121#post-2945473
    TLDR, that above coupler is $150 and essentially identical to $10/$20 couplers.
  20. Jan 18, 2023 at 7:22 PM
    #5060
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  21. Jan 18, 2023 at 8:12 PM
    #5061
    Downytide
    GTA
    Driving in city = painnnnnn
    But looks damn good thou.
    reywcms[QUOTED] likes this.
  22. Jan 18, 2023 at 8:16 PM
    #5062
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    I prefer a lot of things about the Tundra too, but when I look at the power upgrade options it becomes more difficult to justify. I’m figuring $20-25k for a supercharger and built transmission, maybe a few grand more for tuning and other pieces to be getting in the ballpark power-wise. That’s about half of what it would cost me to get into a TRX after trading in my truck (I have one being offered to me at 10k under MSRP) but it comes with the expectation that everything will work out of the box (as much as you can expect with a Ram).
  23. Jan 18, 2023 at 8:39 PM
    #5063
    Downytide
    GTA
    If it makes financial sense, sure, 25k seems high to be honest, that's about how much I spent with everything so far, regear, suspension, headers, sc kit, valve body etc.
    I recall one member got quote of 35k from prospeed incld built block and harrops, and was told it'll smoke TRX on the 1/4.
    Either way is fun, TRX has launch control which is really cool, and it is a very nice vehicle to be in, interior wise ram is the best in the biz.
    nobodyintexas likes this.
  24. Jan 18, 2023 at 8:49 PM
    #5064
    snivilous
    SW UT
    Idk how hot it is, but it's what I put in 5k ago after the black one started making noise after a few years. Hopefully it's the hotness :D
    Saltyhero13 and reywcms[QUOTED] like this.
  25. Jan 18, 2023 at 9:12 PM
    #5065
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Lol
  26. Jan 18, 2023 at 10:15 PM
    #5066
    Saltyhero13
    Tundra scoots with ~500 WHP ballpark which is a Stage 2/2+ Harrop for ~10K to13K. You can go slightly higher with E85 but thats about 20K. Transmission is good for 700, at-least 600, depending on what day you ask IPT (the valve body folks).
    Main issue is getting traction as most folks are running knobby terrain tires. With those numbers we've got members pushing sub 5s on their trucks and they are lifted, loaded bed, etc set up for truck duty. The fastest truck on here is sub 4s but its a RCSB with an AWD conversion (from the Sequoia) build engine and barebones stripped down etc.
    For day to day driving those are respectable numbers and good day to day manners. Turn of all the nannies and you'll have a hard time keeping it between the lines, wet or dry.
    Tundra makes for a hilariously good sleeper for half the figure you mentioned. TRX is in its own class so it wont be apples to apples.
    Silver17 and nobodyintexas like this.
  27. Jan 19, 2023 at 3:01 AM
    #5067
    nobodyintexas
    nobodyintexas What?
    South of Houston
    This. The interiors are the best.
    TRX is cool. I outgrew cool a couple years ago. I do not prefer the looks of the TRX, nor do I want the offroad capabilities of the TRX.
    and I'm frequently in parking garages and drive downtown Houston when business forces me too.
    These are some of the reasons I don't prefer the TRX. and it's a FIAT.
    now, if you put the TRX drivetrain in a top range Big Horn/Laramie 1500, I'd have a look-see.
    T-Rex266, Saltyhero13 and Silver17 like this.
  28. Jan 19, 2023 at 3:03 AM
    #5068
    nobodyintexas
    nobodyintexas What?
    South of Houston
    For 3rd party verification....The dude fixing my '34 Ford called it a "helluva sleeper"
    Saltyhero13[QUOTED] and Silver17 like this.
  29. Jan 19, 2023 at 3:06 AM
    #5069
    nobodyintexas
    nobodyintexas What?
    South of Houston
    man, I hope these dudes will put my gauges on...
    they are a stone's throw from the Casa.
    http://gforce-tx.com/
    If they will entertain me...I'd like to see another dyno of my truck with boost & AFR on the graph.
    and they have a AFM-1000 Wideband Sensor - whatever that is....
  30. Jan 19, 2023 at 4:55 AM
    #5070
    Silver17
    Eastern PA
    @reywcms I personally would rather spend an extra $130 on a coupler even if it only got an extra 10-15k miles out of it. The PEEK is the recommended go to on the boosted page. If you’re well practiced on changing it out, and don’t mind tinkering all the time I guess use the cheap one? I don’t have the garage space yet personally and would rather spare the busted knuckles. This post on FB I believe is Firemandan’s regarding his coupler experience. (This post was over 2 years ago and I don’t think he has had a coupler issue since). Brian Zacuto owns SCOL and has more experience with these than anyone. https://bccncmilling.com/machining-...n-ptfe-plastics-tips-advantages-applications/
