Automatic Tailgate switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ozcomm, Dec 31, 2022.
  1. Dec 31, 2022 at 11:40 AM
    Ozcomm
    Ozcomm [OP] New Member
    Dean
    2021 TRD Pro
    Has anyone installed the automatic tailgate switch?
  2. Dec 31, 2022 at 12:08 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Do you mean the tailgate power lock? If so, plenty have, including myself. It's an easy install. I used the OEM one.
    Ginsterkev and MedCityMoto like this.
  3. Dec 31, 2022 at 12:11 PM
    Taco-Spike
    Two Trucks
    You mean to open it?
  4. Dec 31, 2022 at 12:21 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I went with the Pop & Lock solution but it's essentially identical - very easy install, biggest pain is just crawling around under the truck to run the wiring up and ziptying it to the truck harness.
    Saltyhero13 likes this.
  5. Dec 31, 2022 at 1:49 PM
    clarkritchie
    clarkritchie New Member
    Pushing a button to open the tailgate sounds like something Ford would do.
    biebs96 likes this.
  6. Dec 31, 2022 at 2:33 PM
    MedCityMoto
    Only if it happens when you're driving down the road in excess of 65mph with anything in the bed!
  7. Dec 31, 2022 at 3:56 PM
    French Avocado
    Utah / Wyo
    OEM is fast, easy and quality.
  8. Dec 31, 2022 at 7:01 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Installed the oem one today. Very straight forward. Worst part for me was getting the panel back on for the passenger side hookups
    Ginsterkev likes this.
  9. Dec 31, 2022 at 8:25 PM
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    Couldn't agree with that statement more lol
    Clemsonman14[QUOTED] likes this.
  10. Jan 10, 2023 at 7:51 PM
    BLUES BRUTHA
    BLUES BRUTHA New Member
    2021 CrewMax TSS SR5
    Hey guys! New to the forum and here is my first post so hope I did it right. Last weekend I was installing the oem power tail gate lock on my 2021 Tundra SR5 TSS package. After watching a YouTube video (because mine did not include instructions) I got the actuator installed. When I went to pull the floor grommet there was already a wire in the grommet coming from somewhere else.
    What the hell is that going to and any tips on moving forward?
  11. Jan 11, 2023 at 1:35 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Do you have auto running boards at all because I do and I also have a wire somewhere in there
  12. Jan 11, 2023 at 3:04 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Maybe a constant 12v source is what I think but it didn't prevent me from putting in the oem tail gate lock
  13. Jan 11, 2023 at 7:58 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Bed lights will typically be wired through there as well. Can you just follow the wire?
  14. Jan 13, 2023 at 4:33 AM
    BLUES BRUTHA
    After combing through the forums I believe it is the oem bed lights that came with the truck. The wire loom is attached to the grommet in the floor just like the one that comes with the power tailgate lock.
    Option A: Should I just cut the one out of the floor, cut a side slit out of the new grommet, install the new grommet around bed lights loom, and "pookie" around it with some RTV silicone? I really don't want to fish the bed lights through the new grommet. Would it hold and be water tight?
    Option B: Or should I leave existing grommet in the floor, poke a hole in it and fish tailgate loom through it, try to get it in the best "4 o'clock" position possible, then "pookie" around the hole in the old grommet.
    Your thoughts? And pookie is a Texas term I believe.
  15. Jan 13, 2023 at 4:55 AM
    centex
    centex New Member
    Chevy to. Asinine design.
