Unbelievable lack of customer service
Discussion in 'Off-Topic Discussion' started by Tundra234, Jan 9, 2023.
  1. Jan 9, 2023 at 6:25 AM
    Tundra234 [OP] New Member
    I was just looking for something in the truck and happened to run across the receipt from when I had a screw repair done on one of the tires on the 4runner a couple of weeks ago. WTF...... it stated "Remove tire from wheel and repair with patch. Rebalance not included". What kind of business does not rebalance a tire after remount? I am going to call them out on it and leave a review on their site/google.
    Wallygator likes this.
  2. Jan 9, 2023 at 6:27 AM
    Aurora CO
    Edited. That's messed up........or........ not o_O
  3. Jan 9, 2023 at 6:29 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    i've seen/heard them not because they'll mark where the stem is on the tire, then remount it. if they line it back up, they wont have much issue and charging you for a re-balance would not make you happy. if you didn't notice anything off with the tire on the vehicle after a few weeks, it seems they did a good job and saved you money that could be used for a charitable donation or something. calm down karen
  4. Jan 9, 2023 at 7:38 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    :101010:
  5. Jan 9, 2023 at 7:48 AM
    gosolo
    Ray
    NW Oregon
    Exactly. As long as they didn’t knock any of the existing balancing weights off of the rim when removing or re-mounting the tire and it was back in the same position on the rim, there’s absolutely no reason to rebalance it.
    That’s common practice not malpractice.
    At least it was when I was working in shops years ago.
  6. Jan 9, 2023 at 8:08 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  7. Jan 9, 2023 at 10:02 AM
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    Also, if you want to pay more, there's no reason you can't go get it balanced now.
  8. Jan 9, 2023 at 10:05 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    That's why I love Discount Tire.
    they do exactly what needs to get done. Every time.
    It's hard for me to believe anyone could compete with them on service. or price.
    why one would go anywhere else is ponderous.
    Wallygator, 1lowlife and BeauDacious like this.
  9. Jan 9, 2023 at 10:08 AM
    They really need to build more locations.
    nobodyintexas[QUOTED] likes this.
  10. Jan 9, 2023 at 10:41 AM
    BeauDacious
    BeauDacious 040 > all other colors
    14 DC 4x
    Move to AZ. I have 3 within 2 miles.
  11. Jan 9, 2023 at 10:44 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Won't the patch add weight and then even when installed the same position it would now be unbalanced?
  12. Jan 9, 2023 at 10:45 AM
    BeauDacious
    14 DC 4x
    Patches generally weigh less than an ounce. This tiny weight addition wouldn't be noticed. Not considering to properly apply a patch you remove a small amount of material in the space.
  13. Jan 9, 2023 at 11:03 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    this.
    kinda like a rock in your tread doesn't make your vehicle shake all over. if thats the case, KO2's would never be on the road ha
  14. Jan 9, 2023 at 11:26 AM
    Shamrock92
    Shamrock92 New Member
    How freaking difficult is it to balance a tire ?!? Even for a first day on the job tire tech - it’s what 5 minutes of labor ?
    What cost is there aside from that labor ?
    I mean seriously - if your company is too damn cheap to allow expend the cost of its employees labor for a few minutes - how good is any warranty you write really? I at least get it when companies try to cheap out on repair va replacement for example - the parts aren’t free and someone is paying for them. Repair though is cost of labor only - and when that labor time is minimal - you just do it and make sure there are not further issues.
    There’s a fine line to me between “permissible” and “doing the right thing” - yes. It is permissible to do this - and odds are there are no balance issues to be corrected. BUT - checking it to be 100% sure cost nothing and if there was an issue - it would be caught/corrected before any damage could take place.
    It’s not as if he was asking for anything more than a simple precautionary check - that should have been offered. Took the tech as long to write up their excuse for not doing it as it would have taken to do it and be done likely. That’s the stuff that drives me nuts - techs spending more time getting out of work than just doing their damn job.
    Leo's first and Tundra234[OP] like this.
  15. Jan 9, 2023 at 11:29 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    per google.
    "try the search bar"
  16. Jan 9, 2023 at 11:58 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    A rebalance isn't needed if the tire is remounted in the same position as it was and no weights were removed or added..
    Terndrerrr, GODZILLA, snoope and 5 others like this.
  17. Jan 9, 2023 at 11:59 AM
    Backslider
    Tooele, UT
    I would bet that the patch weighs less than 1/4 of an ounce.. It's like having a small rock stuck in your tread.
  18. Jan 9, 2023 at 12:07 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Can OP update when available with video of speaking with the manager and/or google review left behind as a learning experience for the rest of us?
    :popcorn:
  19. Jan 9, 2023 at 12:18 PM
    War Machine
    War Machine SSEM # 5 3MW
  20. Jan 9, 2023 at 1:13 PM
    Shamrock92
    Rely on Google all you like - I will stick to my personal experience and knowledge knowing that if someone is taking 30 minutes to 2 hours to balance a wheel - it’s only because they tossed the wheel on the balancer and then went to lunch while it was spinning there.
    What your quoting is the entire damn appointment - from customer dropping keys at service - tech pulling the car back into a bay and getting a wheel off - then placing the wheel on the balancer/performing any other services needed (likely your not just getting a single wheel balance checked - most likely at minimum your getting all 4 checked and rotated at minimum).
    So yea - if your talking a 4 tire rotation with each balanced - 30-45 minutes is possible - but tech time is closer to 15-20 minutes work - divide that by 4 - and you get the actual time needed to balance a single damn tire.
    If some kid making 12.50 an hour at Walmart can do it - it can’t be too difficult.
    Seriously - I’m far from an expert on auto repair - but if someone told me it would take them possibly a couple hours to balance a single damn tire because the machine takes that long to get a reading on the spinning wheel - I’m going elsewhere because that person has absolutely zero idea what they are doing. Even larger/heavier all terrain tires which are tougher to balance shouldn’t take near that long per tire. Maybe 10-15 minutes of out of balance - but to simply CONFIRM balance - I’m sticking to 5 minutes - including time to remount the wheel/tire.
  21. Jan 9, 2023 at 1:26 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    easy greasy.
    i know it don't take forever. i've watched someone do it while i was 5' from them. agreed that it doesn't take too long, but did take about 10 mins mount to dismount from the machine.
    my sarcasm font doesn't show up automatically. but, add up all the 10 mins you've saved in a day slinging people in and out without doing un-necessary stuff and you've saved/made a bit of money. would it be good, sure. i believe this is getting a little derailed from OP complaining about a service not getting done that wasn't paid for, asked for, noticed, etc.
    now....still waiting on OP to return to update us on how hot his keyboard got leaving that google review.
  22. Jan 9, 2023 at 1:42 PM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    A few weeks ago I was at the dealership and asked them to fix a slow leak, which turned out to be a screw. They did not rebalance the wheel, nor did they charge me a penny to fix it.
    Fotnot likes this.
  23. Jan 9, 2023 at 1:54 PM
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    Should I be getting wheels that I've plugged leaks in rebalanced?
    GODZILLA and TaquitoBandito like this.
  24. Jan 9, 2023 at 1:56 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    Was it a few weeks ago?
    Are they out of balance?
    Did you pay for a rebalance?
    If you answered no to any, then leave a Google review on their page.:evil:
    MrMitch96, GODZILLA, Y0TA PR0 and 8 others like this.
  25. Jan 9, 2023 at 2:03 PM
    TaquitoBandito
    Joel (AKA Bif)
    Depends on the Lunar phase, time of day, high tide, low tide, humidity level, etc of when you plugged them.
  26. Jan 9, 2023 at 2:05 PM
    TaquitoBandito
    Joel (AKA Bif)
    He did it himself so I fully expect @Cpl_Punishment to leave himself a negative review for being lazy.
  27. Jan 9, 2023 at 2:07 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    i've left myself a bad review on my OnlyFans page. can't get better unless someone tells you.
    ElNopal, hagrid, GODZILLA and 6 others like this.
  28. Jan 9, 2023 at 2:10 PM
    TaquitoBandito
    Joel (AKA Bif)
    Makes sense. :fistbump:
  29. Jan 9, 2023 at 2:12 PM
    Going tomorrow to have 5 TPMS sensors put on my son's Rav4. 3 are bad but might as well do all 5.
    Wonder if the are going to re-balance them?
  30. Jan 9, 2023 at 2:15 PM
    TaquitoBandito
    Joel (AKA Bif)
    THEY FUCKING BETTER!
    GODZILLA, Wallygator, Fotnot and 6 others like this.
