Powertrax grip pro
Discussion in 'General Tundra Discussion' started by CORIHOR, Nov 9, 2020.
  1. Jan 5, 2023 at 7:38 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    What rear springs? I ask because I can tail the ever-livin’ shit out of mine without any noticeable axle wrap or wheel hop.
    5.29, Powertrax, 34” tires, and Deaver springs.
    If you’re stuck with OEM springs, yeah. I can see problems. What’s the cost of traction bars compared to quality springs?
  2. Jan 5, 2023 at 8:06 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    This would depend on tire size and other factor. 4.88s or 5.29 I currently run stock gears and I’m on 37s.
  3. Jan 6, 2023 at 10:46 AM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    Like @reywcms said, tire size will dictate what gearing changes you make. I'm on 5.29s and 37s but not supercharged. Keith from Dirty Deeds has made the argument that if you're SC'ing and running larger wheels, 4.88s is best due to the quick spooling a SC offers. Taller gears = better lower end torque (among the usual no gear hunting/highway riding at higher than optimal RPMs) but you'll lose top end speed as a result. I cap at about 88mph on highways due to my 5.29s and no tuning/ECU changes. If you're supercharged, you're obviously gaining a ton of torque/hp throughout the throttle range so the need for 5.29s for optimal "get up and go" with larger/heavier tires is negated. Hence, 4.88s.
  4. Jan 6, 2023 at 11:06 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If SC’d it might be worth it for 37s. I can safely say after discussion with other members referencing dragy data that my truck runs every bit as good on stock gears and 33s as other supercharged trucks with 5.29s and 35s, which despite the larger tire size comes out to an effective gear ratio much lower than mine (roughly .66 shaft rpm per axle rpm lower). The SC definitely reduces the necessity for a regear IMO.
    Saltyhero13 and Ckatz53 like this.
  5. Jan 7, 2023 at 10:44 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    I’d argue that gearing is important, regardless of power levels. You’re 100% of the time going to be better off to operate within the optimal rpm range. Why not take advantage of all that extra S/C power by letting it rip??
  6. Jan 8, 2023 at 12:10 AM
    BabyBlackYota
    BabyBlackYota New Member
    Alex
    Longview TX
    2015 Black Tundra SR5 offroad
    AFE cold air intake, Outlaw Catback Dual Exhaust, ProRunner Fender Flares, DAPTISED 37x12.5x20’s, (soon to be 38x13.5x17) Zone 5 bracket lift kit /with pro comp spindles and outer tie rods grip pro lsd rear, Revolution 5.29 gears Deaver U748 springs Camburg shackles Fox 2.5 Coilovers 7” BDS Icon Billet adj/UCA’s
    I have the deaver U748 1.5 shackles my rear shocks suck need to upgrade also have 37’s on 20x12’s with -44 offset witch are horrible for suspension and bearings I have a set of 17’s I’m about to put on 37x13.5’s to help balance out center of gravity or wtv trying to decide witch traction bars to go with but yea after dap tune and long tubes exhaust I get bad wheel hop on pavement when turning off traction control ( press down then hold then hold again just off that brake module thing that fucks up your drifting )
  7. Jan 8, 2023 at 12:15 AM
    BabyBlackYota
    Alex
    Longview TX
    Some pics caused by my wheel hop I felt it when it happened at first I thought it was just my Yoda gettin it but noticed after my donut was messed up real quick lol
  8. Jan 8, 2023 at 10:28 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    Oh my! You’re a lot rougher on your toys than I am…. Not sure if you need more parts, or more discipline!!! Lol.
    BabyBlackYota likes this.
