General Supercharger Thread
  1. Jan 4, 2023 at 7:18 AM
    #4891
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    My thought is basically cause F paying PS $700 for an underdeveloped box when i can make my own, better, and cheaper (or same price after buying the Stillen box and custom tube). If more power, cool. But mostly I think it's the maf tripping issue. I'd be curious to see what the costs are to port out the magnusun intake opening since it looks like there's plenty of room for it.
    Silver17[QUOTED] and Saltyhero13 like this.
  2. Jan 4, 2023 at 7:25 AM
    #4892
    Saltyhero13
    Saltyhero13 Throbbing Member
  3. Jan 4, 2023 at 7:30 AM
    #4893
    M3Tundra-JK
    Scott
    2005 GX470
    More curious about this little guy. If I can get MRP to install both line fittings that'd be ideal. Just couldn't tell what that is used for/if it's used on the s/c'd applications
  4. Jan 4, 2023 at 7:32 AM
    #4894
    Saltyhero13
    If you could I would probably wait for AFE to come out with their box. You'll easily exceed 700 on parts if you run into any fitment issues.
    M3Tundra-JK[QUOTED] likes this.
  5. Jan 4, 2023 at 7:33 AM
    #4895
    Saltyhero13
    Not sure but great question. Would have to review install instructions on Harrop to see where that gets fitted.
  6. Jan 4, 2023 at 7:35 AM
    #4896
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    On the Harrop they have you run that to the boost port to boost reference the fuel pressure regulator. Not sure where that goes as per the magnuson install. You may benefit from running it the same way? Harrop also provides a different FPR with the kit though that I think it’s main function is to run a higher pressure.
  7. Jan 4, 2023 at 7:39 AM
    #4897
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    For the maggy it goes to the fpr. Haven’t seen a size for it listed in the install manuals of TRD intake or maggy lol
    Saltyhero13 and M3Tundra-JK like this.
  8. Jan 4, 2023 at 7:41 AM
    #4898
    M3Tundra-JK
    Scott
    2005 GX470
    I kinda thought so. Did the same to boost reference the Taco but did require some tuning adjustments.
    lol i don't disagree! I tend to get ahead of myself until I see final costs. I'm also impatient without knowing when the AFE will come out. I need to learn, one s/c project at a time. I haven't even installed anything yet lol
  9. Jan 4, 2023 at 7:59 AM
    #4899
    Saltyhero13
    I hear you. Plus plans may change if you see a better way of getting the project done. At one point I was looking at offset couplers reducing from 4.5 to TB.
    Unless the AFE has SABM or a front facing inlet Stillen will likely be the better option. The inlet is roughly the size of a 3 inch SABM cut.
  10. Jan 4, 2023 at 8:04 AM
    #4900
    M3Tundra-JK
    Scott
    2005 GX470
    Just linked this on the other thread, but ya AFE would definitely be the way to go. You can see how much better/larger the SABM is that they make. And the fender hole area seals up completely tight. Could even enlarge the fender side
    https://www.tacomaworld.com/threads...ricks-and-mods.518932/page-1942#post-26263576
  11. Jan 4, 2023 at 8:14 AM
    #4901
    Saltyhero13
    The enlargement alone wont be enough but I see it has an option for a front facing inlet. Finding room for the front inlet will be interesting.
  12. Jan 4, 2023 at 9:02 AM
    #4902
    Silver17
    Eastern PA
    ZPhilip, nags, reywcms and 2 others like this.
  13. Jan 4, 2023 at 12:02 PM
    #4903
    Saltyhero13
    I think there is a restriction at the top end from what I recall.
    Some discussion here:
    https://www.tundratalk.net/threads/...-the-lexus-lc500-rc-f-onto-the-tundra.759032/
    Silver17[QUOTED] and V10Ace like this.
  14. Jan 4, 2023 at 12:15 PM
    #4904
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
  15. Jan 4, 2023 at 12:23 PM
    #4905
    Silver17
    Eastern PA
    Makes sense as far as the TB being the restriction, but that just seems to clear up the fact that the boost and power gains are from the larger TB which was already the restriction Versus the 4” intake tube. You’re just increasing the most restrictive part of the intake diameter from 3” to 3.3” with the RCF TB. I’d for sure do it if it were not so expensive. Maybe something to save up for later.
    reywcms likes this.
  16. Jan 4, 2023 at 12:27 PM
    #4906
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    https://www.prospeedautosports.com/...ake-and-rcf-throttle-body-adapter-kit-testing
  17. Jan 4, 2023 at 12:35 PM
    #4907
    Silver17
    Eastern PA
    V10Ace[QUOTED] likes this.
  18. Jan 4, 2023 at 12:57 PM
    #4908
    Silver17
    Eastern PA
    Also have to wonder how much of those test results of theirs would still hold true on a truck with stock manifolds. If you’re not moving the exhaust gases out of the cylinders at a rate that is well matched to the better flowing intake, does that extra flow on the Intake side still translate to more power?
    V10Ace likes this.
  19. Jan 4, 2023 at 2:18 PM
    #4909
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    What do you think the drivetrain loss is at the hubs?
  20. Jan 4, 2023 at 2:22 PM
    #4910
    snivilous
    SW UT
    300k+ Supercharged 2008
    From the dynos posted here, stock Tundra makes about 300whp. So about 20%.
    Saltyhero13 likes this.
  21. Jan 4, 2023 at 2:37 PM
    #4911
    Silver17
    Eastern PA
    Are you questioning the % loss of a hub dyno vs a chassis dyno? I’d say ballpark that a hub dyno may show a 13-15% loss for what would be a 20% loss on a chassis dyno. In that one YouTube video I shared a few pages back the same car on a chassis dyno made 223hp, but on a hub dyno it made 265. Even with the small and relatively lightweight wheels/tires on that Porsche it lost 21hp per wheel on the chassis dyno. Big and heavy wheels and tires will be an even bigger loss on a chassis dyno.
  22. Jan 4, 2023 at 2:51 PM
    #4912
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    Ya hubs because I’ll hopefully be able to use a hub dyno tomorrow or Friday.. trying to get the most accurate crank number.
    Silver17[QUOTED] and M3Tundra-JK like this.
  23. Jan 4, 2023 at 6:38 PM
    #4913
    M3Tundra-JK
    Scott
    2005 GX470
    Took some measurements and it looks like both the stillen and throttle body angle upwards at a total of around 40*. Hopefully the hump connection on maf/airbox side gives it that extra little bend needed and i can use a 45* 4.5" reducer to the tb. Ooorrr loosen the screws holding down the airbix a tad?
  24. Jan 4, 2023 at 7:20 PM
    #4914
    Saltyhero13
    Humps are only good for 10 to 15 degrees from what I understand.
    If it is around 40 you'll likely benefit from the 45 degree reducer you have in your parts. I tried using two 45 degree elbows, even when I cut them down to just the elbows and leaving enough material to clamp I was over length by 5 or 6 inches; the only option would have been to have a shorter filter which I don't think they make. Your part is a two in one reducer and elbow so it may actually save you space. You might even be able to go adapter -> hump -> MAF -> reducer elbow -> TB and put your fitting on the MAF tube after the MAF sensor.
    Another option could be to redesign the adapter to the Stillen box and give it some angle and/or extend it.
  25. Jan 4, 2023 at 7:25 PM
    #4915
    Saltyhero13
    Interesting, I think the Harrop has to be ported.
  26. Jan 5, 2023 at 7:21 AM
    #4916
    nags
    nags New Member
    What I was told as well from David directly during my install.
  27. Jan 5, 2023 at 7:48 AM
    #4917
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Saw this and thought it was good
    kbark, nobodyintexas, Jcmf52 and 8 others like this.
  28. Jan 5, 2023 at 12:05 PM
    #4918
    Silver17
    Eastern PA
  29. Jan 5, 2023 at 7:53 PM
    #4919
    M3Tundra-JK
    Scott
    2005 GX470
    kbark, Saltyhero13, nags and 6 others like this.
  30. Jan 5, 2023 at 7:54 PM
    #4920
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Why would it blow up? Lol a good tune and it’ll run forever if maintained. Plenty of supercharged rigs with tons of miles.
    Congrats on the rig!
