General Supercharger Thread
  1. Dec 31, 2022 at 3:01 PM
    #4861
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    For easy finding again, thanks @Saltyhero13
  2. Dec 31, 2022 at 3:05 PM
    #4862
    Saltyhero13
    Saltyhero13 Throbbing Member
    no worries. If you plan on keeping the Stillen you can come up with a better more permanent solution to mating the tube to the box. I pieced mine together that way in case I needed to return especially if it didn't lower my IATs. Not sure if it introduced a constraint to the system since I never dynoed the truck after switching it from PS to Stillen.
    M3Tundra-JK[QUOTED] likes this.
  3. Dec 31, 2022 at 3:52 PM
    #4863
    M3Tundra-JK
    Scott
    2005 GX470
    I'm trying to get my friend to 3D print a copy of the Stillen tube end that connects to the filter, and reduce it down to 4.5" on the other side. And for the TB side use this silicone 45* bent 4.5-3.5" reducer https://www.siliconeintakes.com/bending-reducer/reducer-elbow-p-8.html
    ZPhilip and reywcms like this.
  4. Dec 31, 2022 at 4:00 PM
    #4864
    Saltyhero13
    The angle on the bend reducer will most likely be too much but it may work on the stock position. When you get your blower installed the geometry may change.
  5. Dec 31, 2022 at 4:02 PM
    #4865
    Saltyhero13
    I was impressed with the build quality from the company, if I ever need to get another MAF tube I know where I am shopping.
    Oh and my air is straighter now XD
  6. Dec 31, 2022 at 4:06 PM
    #4866
    M3Tundra-JK
    Scott
    2005 GX470
    Friend said no issues designing the adapter but his printer is down, just have to order the print instead. I'll probably start there and wait to finish the other end later
    Saltyhero13[QUOTED] likes this.
  7. Dec 31, 2022 at 4:13 PM
    #4867
    Saltyhero13
    Cool, can't wait to see how it comes out!
  8. Dec 31, 2022 at 4:41 PM
    #4868
    M3Tundra-JK
    Scott
    2005 GX470
    Ya this should be pretty simple to print
  9. Jan 1, 2023 at 2:08 AM
    #4869
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    Happy new years gents
  10. Jan 2, 2023 at 12:23 PM
    #4870
    M3Tundra-JK
    Scott
    2005 GX470
    Stillen adapter. Uses stillen filter with 5 7/8" filter, reduced down to 4.5". It's smooth on the inside, no sharp edges. Then couple that to the 4.5" maf tube. My friends printer is down. Any suggestions on where to get it printed?
  11. Jan 2, 2023 at 12:37 PM
    #4871
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’ve seen a few on the Google. You send the file they quote and print
  12. Jan 2, 2023 at 12:46 PM
    #4872
    M3Tundra-JK
    Scott
    2005 GX470
    Do you know what temp that area of the engine gets up to? Need to figure out what material to print it in
  13. Jan 2, 2023 at 1:00 PM
    #4873
    snivilous
    SW UT
    300k+ Supercharged 2008
    There's probably a local place, could even ask on Facebook or your friends if they know anyone with a printer. I have a $300 Ender sitting on my desk, as do a lot of people. There's also online places like Protolabs that have fancy machines and a lot more material options.
    For temperature I've seen MAF readings of 200F sitting in the drive through when it's 100+ out. So I'd pick something that can handle a lot of heat.
  14. Jan 2, 2023 at 4:19 PM
    #4874
    M3Tundra-JK
    Scott
    2005 GX470
  15. Jan 2, 2023 at 4:20 PM
    #4875
    M3Tundra-JK
    Scott
    2005 GX470
    found a local place that has a ton of material. Sent off the file, should get quote tomorrow
    Silver17, reywcms and snivilous[OP] like this.
  16. Jan 2, 2023 at 4:24 PM
    #4876
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Nice! This might be able to be integrated into the maggy box with some work of course then one could run a cone filter.
    Silver17 and M3Tundra-JK[QUOTED] like this.
  17. Jan 2, 2023 at 5:08 PM
    #4877
    M3Tundra-JK
    Scott
    2005 GX470
    We could certainly modify the file easily enough make it work. Doing the rest of the tube is gonna require some work.
    Hopefully the lengths all come out correct. Wish it could all be one tube but this is how it's planned
    1. Air filter
    2. new 4.5" reducer adapter
    3. 4.5" ID / 3" long hump coupler
    4. 4.5" OD / 6" long maf tube
    5. 4.5" ID / 3" long hump coupler
    6. 4.5" OD / ??" long tube
    7. 4.5" ID to 3.75" ID / 3" long reducer.
    * Only reason I did the 3.75" Throttle Body side was because the reducer was $20 cheaper that the 3.5". Also the 3.5" to 4.5" only came in the longer 4" long version. If it doesn't clamp well enough I'll fork out the extra cash for the other version. All HPS silicone brand connectors
    ** Alternately I may be able to do a longer silicone reducer tube between the MAF tube and the the TB. Put the vacuum lines in the maf tube
    reywcms[QUOTED] and HulkSmurf14 like this.
  18. Jan 2, 2023 at 6:16 PM
    #4878
    Saltyhero13
    I suspect you'll have less ground to cover since you're mating to the airbox with an external adapter so your parts list may be shorter.
    You may not need #5 and #6 and may be able to get away with a longer #3 4.5 coupler though I only remember seeing longer straight couplers. You'll definitely want at least one hump coupler to deal with any angles and engine twist. It all depends on where you are putting your vacuum line too. I didn't want to risk messing up the beautiful MAF tube and it was cheaper to get 3inch 4.5inch OD connector/couplers pipes.
    You'll need a vacuum fitting if you don't have one; Vibrant sell a "no weld" solution that seems to be holding up.
    For #6 the shortest I found is 3 inch with the raised clamp ribs. It was such a tight fit that I didn't really need the ribbed ends but it will keep it from coming apart.
  19. Jan 3, 2023 at 1:00 PM
    #4879
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The intake I purchased off fastlane had the SABM airbox 3” flange installed but I needed the 3” flange for the fender side as well as the tubing and clamps. I got decent quality parts off Amazon for $16 and it’s essentially the same exact thing. Had I needed the airbox flange it would have totaled $24. Certainly better than paying $90 for the Gtek SABM kit! This should work out perfectly and won’t look quite as rigged together as some pvc pipe. Is there anything you can’t find on Amazon in a pinch? Oh, I also inquired with DAP about some tune tweaking for the 4” tube. Hope to hear back soon. I’m curious if there will be any actual gains, or just peace of mind on the MAF voltage front.
  20. Jan 3, 2023 at 1:20 PM
    #4880
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Way easier piecing it together for sure!
    Just be sure it's mounted low enough in the box where the hardware won't interfere with the filter sitting flat. I used black rtv and hardware to seal it up. Old pics attached
    HulkSmurf14 and Silver17[QUOTED] like this.
  21. Jan 3, 2023 at 1:25 PM
    #4881
    Silver17
    Eastern PA
    Yours looks good. I was questioning if I should pass the pipe side through the hole from the wheel well and screw it on from that side, or just screw the flange on in the engine bay side. I guess it’s cleaner to stick the tube through the hole like you did, and fasten it from the fender side.
    reywcms[QUOTED] likes this.
  22. Jan 3, 2023 at 1:37 PM
    #4882
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yea it's cleaner in the engine bay this way I think. But all that will be coming out since for me it rubs during hard travel. lol
  23. Jan 4, 2023 at 5:59 AM
    #4883
    M3Tundra-JK
    Scott
    2005 GX470
    @Saltyhero13 So MRP said that they can make me a custom length MAF tube for around $173! Big win in the design phase of a new 4.5" tube. My next question to them is going to be about welding in that 5/8" vacuum line fitting. My question is about that third super tiny vacuum line that runs to the air box. I couldn't see it in your picture, if that was connected or not. I'm assuming it is still used?
    The first go at ordering a printed Stillen box air filter/tube adapter costs came in at $68 shipped. New tube would require one hump connector (HPS $35) and one 4.5" to 3.5" reducer (HPS $75). I only went with HPS because of name brand and good heat resistance. I'm sure we could find cheaper replacements. But that would put the total cost of a 4.5" tube at around $350
    ssmokedz, HulkSmurf14 and Saltyhero13 like this.
  24. Jan 4, 2023 at 6:12 AM
    #4884
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    HulkSmurf14 likes this.
  25. Jan 4, 2023 at 6:14 AM
    #4885
    M3Tundra-JK
    Scott
    2005 GX470
    Hmm, good to know. Do you know the dimensions of the smaller one? If anyone else is interested in ordering the tube, I think it might bring the cost down some. Will be probably a week before I get my printed part in and can take a measurement for the tube to send them
  26. Jan 4, 2023 at 6:16 AM
    #4886
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Unfortunately I don’t and can’t look since I don’t have my truck. Let me see if I can find it somewhere.
  27. Jan 4, 2023 at 6:36 AM
    #4887
    Saltyhero13
    That is great to hear! I think they offer larger OD tubes too which can open up options later. I really like their product. I noticed my air is straighter too (I have the option with the mesh):rofl: All jokes aside they make nice kit.
    RE: Custom tube. I would consider fitting the other parts first before committing to a length. Also do you have the throttle body installed? If I recall correctly the 4.5 to 3.25 fit better.
    I think in your case overall fitment will be better with at least one hump coupler if not two. So Stillen adapter -> hump -> MAF -> hump -> coupler pipe -> reducer -> TB. I suspect that may be too long for your set up so you may be able to get away without the hump and coupler pipe after the MAF or stuff the coupler pipe into the hump and reducer.
    Also are you installing a Maggie or Harrop? I forgot which. I think the Maggie intake points up at an angle like the stock set up, Harrop is flat.
    RE: Vacuum line I was waiting for parts to ship in the picture you referenced and was showing fitment of everything else. I ended up using the Vibrant no weld option on the coupler pipe right before the TB. I can snap a picture later.
    M3Tundra-JK[QUOTED] and reywcms like this.
  28. Jan 4, 2023 at 6:42 AM
    #4888
    M3Tundra-JK
    Scott
    2005 GX470
    Cool cool. definitely waiting on my other parts to arrive before ordering the custom length tube since that isn't refundable! They did say I could return the tube I already ordered.
    I'm running the Maggy, so good to know. Oh it's 3.25" on the TB side? Then I'll be returning that HPS reducer to Amazon and ordering a new on. will see what the options are for any angled silicon connectors/reducers
  29. Jan 4, 2023 at 6:56 AM
    #4889
    Saltyhero13
    On the Harrop the 4.5 to 3.5 was too big using the larger Lexus TB, 3.25 is a tight fit but it will get on there. I forget what the OD of the TB is but ~85mm or so sounds about right, 3.25 is about ~83mm. Good quality silicone shouldn't split.
  30. Jan 4, 2023 at 7:05 AM
    #4890
    Silver17
    Eastern PA
    Is the desire for the 4.5” tube solely for the MAF voltage issue, or is the thought that the 4.5” should make more power? Just curious if there is a consensus. The stock TB is 3”, and even the RCF TB is 3.3”, so flow wise I’d have to assume that would be the main restriction anyway as far as making power, even as compared to a stock 3.5” intake tube? I just don’t want to miss out on any easy power by going with a 4” tube.
