  1. Jan 1, 2023 at 7:26 PM
    centex
    centex New Member
    Ordered a new exhaust tip. Current one is a bit rusty and is about 4” to far tucked under the bumper. I prefer it a bit farther out. Also got my weather pack connectors in so I can start tying in the fogs and reverse lights in the bumpers.
    Tripleconpanna likes this.
  2. Jan 1, 2023 at 8:38 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Didn’t do shit to mine.
    But helped my little brother put a new radio and backup camera in his 2005 DC.
    So it was still a good day of Tundra mods
  3. Jan 1, 2023 at 8:50 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Swapped out the worn out boots on my SPC ball joints on my UCAs. Ended up being a pretty easy, but messy, job.
  4. Jan 1, 2023 at 9:14 PM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    I have the same setup- how many miles did you get before they needed swapping.
  5. Jan 1, 2023 at 9:20 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I got them secondhand. The driver side was fine and probably could have left it, but the passenger side was losing grease pretty bad and was probably torn. It doesn’t sound like they need to get changed often.
    Blowdart and Shaff777[QUOTED] like this.
  6. Jan 2, 2023 at 6:56 AM
    Matt56258
    Matt56258 New Member
    Matthew
    Savannah GA
    2021 Tundra Platinum MGM
    TRD grille, TRD dual exhaust
    Nothing too fancy, got to use the new bike rack to take the truck out for camping. Camped in the new year.
  7. Jan 2, 2023 at 7:04 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Looks awesome! What bed cover and rack are you using? This is something I’d be looking for in the near future.
    JeremyTRD likes this.
  8. Jan 2, 2023 at 7:09 AM
    Matt56258
    Matthew
    Savannah GA
    The bedcover is the RetraxPro. Cross bars and raved rack are Yakima. The bike rack is the Yakima Swing mount. I was very skeptical of the swing mount until this trip. Definitely works as advertised and it’s very stout.
    Next up on my mods list is lights (ditch lights and light bar). I have those already, waiting on switchpro and mounting tray to be delivered before I start all the wiring.
  9. Jan 2, 2023 at 7:10 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Drove home from hunting last night. There are so many fuel economy threads, I decided the last couple days to see just how well I can do. What is pictured below is normal for me if I keep it under the speed limit and stay off cruise control through the Tennessee hills. This means I stay in a right lane and my speed will fluctuate (I’ll let it drop a few mph instead of shift down to 5th or 4th like cruise control would do immediately). I’m using tires that are 8.4% larger (LT285/75R18 vs 275/65R18) in diameter and 25 lb heavier than stock. This 8.4% number appears to be consistent with the difference between my dash and GPS. I run 40 psi in my tires. I also have a static load in the bed of around 300 lb with my retractable bed cover, 2nd battery, and Plano trunk full of recovery tools. Corrected for tire size and assuming my GPS is accurate, this is 19.4 mpg. Better than the 18.5 I posted before. I still average around 16 on the entire tank due to how much city driving I do. I have zero complaints with fuel economy.
  10. Jan 2, 2023 at 8:19 AM
    ssmokedz
    Shelton CT
    Do it! You wont regret it!
    Jcmf52 and PlaysARobin[QUOTED] like this.
  11. Jan 2, 2023 at 11:40 AM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
  12. Jan 2, 2023 at 11:58 AM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    Installed the SSO Slimline Hybrid. Of
    course no install goes as planned when I begin a project. Still have some modifications to make so the winch clutch can be turned completely, but overall I’m ok with the outcome.
  13. Jan 2, 2023 at 12:30 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    Where do you get these? I'm assuming they're to give you a place for wiring once you start adding a lot of extra electrical components.
    bulldog93 and PlaysARobin like this.
  14. Jan 2, 2023 at 12:40 PM
    PermaFrostTRD
    Northern NY
    I guess it’s time for a 4Knines back seat cover. I think the wife was saying something without saying something with this pic.
    GAknight, Henry1jg, Gaston and 13 others like this.
  15. Jan 2, 2023 at 12:41 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Might be the angle of the photo but is the passenger side not as flush as the driver side?
    bulldog93 likes this.
  16. Jan 2, 2023 at 1:28 PM
    colenation
    Cole
    Alabama
    In person it definitely it is more flush than the photo displays. It also sits slightly closer to the drivers side and could also have to do with how I was able to align the plastic bumper back on.
    Please don’t activate my OCD. I did the best I could:(.
  17. Jan 2, 2023 at 1:58 PM
    trucknut
    trucknut New Member
    Just those damn phone cameras. I'm sure I wouldn't have thought that if I saw it in person. Love the look of the SSO
  18. Jan 2, 2023 at 2:55 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I’m looking and looking to see what your seeing. But, I don’t see it. :notsure: It looks perfect to me.
    bulldog93 and RainMan_PNW like this.
  19. Jan 2, 2023 at 3:09 PM
    RainMan_PNW
    Casey
    Clark County, WA
    bulldog93 and colenation[QUOTED] like this.
  20. Jan 2, 2023 at 3:12 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Putting the factory parts back on was a bitch with this thing!
    RobertD likes this.
  21. Jan 2, 2023 at 4:15 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Fox Performance Elite 2.5 DSC at 3" with Coachbuilder 1/4" shim on driver side JBA UCAs Fox Performance Elite 2.5 DSC rear shocks Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Prinsu Cab Rack 2024 Four Wheel Camper Project M Camper Mods: Goal Zero Yeti 4000 house battery 200w solar IceCo fridge Truma Propane Heater
    Found a drivers side grab handle from a 2nd gen at pick n pull for $15! After some cleaning it looks great. Gonna put it on when/if it stops raining
    rebmo, GAknight, FISHN43 and 22 others like this.
  22. Jan 2, 2023 at 5:01 PM
    colenation
    Cole
    Alabama
    Yes, that part was not fun. The factory bumper being more flimsy due to the cut out got me for a while. I had to touch up my cuts a few times because I didn’t cut enough the first go round and the trim wouldn’t seat well. All in all, it’s not perfect but works and looks good to me. I’ll tackle the clutch lever when I get my bracket for the control box.
  23. Jan 2, 2023 at 6:23 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Moved Tundra into the garage. Noticed my headliner was wet on one side. Turns out I didn't do a good job sealing the Front Runner rack on install. It actually rains where I live now...as in days in a row (compared to the desert). Correcting the issue tomorow.
  24. Jan 2, 2023 at 6:52 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Wanted the phone/waze up closer to my line of sight so installed the Rago fabrication dash plate with some ICS fab accessories today
  25. Jan 2, 2023 at 7:07 PM
    Overlandequipped.com I have the same setup. I bought the bracket from them but got the Blue Sea CB and Blue Sea fuse block from Amazon. Overland does sell it as a kit if you want a one stop shop.
    Mount https://overlandequipped.com/collec...use-block-bracket-for-2007-2021-toyota-tundra
    Full kit https://overlandequipped.com/collec...xiliary-power-kit-for-2007-2021-toyota-tundra
  26. Jan 2, 2023 at 8:33 PM
    dherring256
    dherring256 New(ish) Member
    2018 MGM SR5
    Fuzzy Dice
  27. Jan 2, 2023 at 9:27 PM
    Skolberg
    Skolberg New Member
    Chase
    2014 TRD PLATINUM
    nice work and awesome looking rig. What did that Trd suspension run you?
    RRR1C0 and TSands83[QUOTED] like this.
  28. Jan 2, 2023 at 9:36 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Wire for my ditch lights were too long. Shorten it up and created a split. A lot better than before :rofl:
  29. Jan 2, 2023 at 10:14 PM
    RainMan_PNW
    Casey
    Clark County, WA
    What are you going to do for your control box?
  30. Jan 2, 2023 at 11:18 PM
    TSands83
    TSands83 USAF Jet Engine Mechanic
    OKC, OK
    2015 Attitude Black Tundra Platinum CM 4x4
    Black TRD Pro headlights, iHacker LED Plug N Play harness, black LED fog lights, TRD Pro grille, TRD skid plate, TRD front and rear sway bars, TRD Pro Fox shocks, TRD intake, TRD dual exhaust, Lexus/Toyota aluminum oil filter cap, Stahlbus oil drain valve, black Fuel Offroad Pump 20x9+20 wheels, color matched mirror caps and door handles, stubby antenna, black tube steps, driver side assist handle, Rago dash plate with ICS backing plate, SR black interior door handles, SR black dash center panel, Tacoma/4Runner left and SR right black steering wheel switches, black steering wheel emblem, black TRD shift knob, AJT Designs shifter and cup holder bezels and HVAC control knobs, Husky floor mats, Trail Edition bed storage boxes, bed LED strip lighting, bed mat, Charvonia Design Billet Tie-down Anchors, 38 gallon fuel tank, RCI fuel tank skid plate, AVS window deflectors/visors, Recon taillights, Recon smoked 3rd brake light, GTR Lighting interior and exterior bulbs, Morimoto mirror puddle lamps, center console wireless charging tray, RAM Mounts Quick Grip wireless charger, Alpine iLX-F509/DVE-5300/KCX-630HD/DVR-C320R, Maestro RR, Garmin Drivesmart 65 & Traffic, Llumar FormulaOne Stratos Nano-Ceramic Window Tint. More to come...
    Thanks. Too much, I'm afraid...but still worth it. Wasn't lucky enough to pick up a used set. Got it all new (shocks, speed sensor bracket, cushions, and hardware) for about $3050 shipped. Did all the work myself except the alignment & zero point calibration...$70 for that.
