General Supercharger Thread
  1. Dec 27, 2022 at 10:02 AM
    #4801
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    This is awesome, though! In all likelyhood I'll buy this and mod it up to the current Stillen intake. I was already thinking to do that, but didn't know that product existed. Should make it a lot easier.
    reywcms[QUOTED] likes this.
  2. Dec 27, 2022 at 10:05 AM
    #4802
    M3Tundra-JK
    Scott
    2005 GX470
    Is the Prospeed a 4.5" INSIDE diameter or OUTSIDE?
  3. Dec 27, 2022 at 10:07 AM
    #4803
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Outside I believe
    M3Tundra-JK[QUOTED] likes this.
  4. Dec 27, 2022 at 10:13 AM
    #4804
    M3Tundra-JK
    Scott
    2005 GX470
  5. Dec 27, 2022 at 10:14 AM
    #4805
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LMAO! did you do the maf housing and canister intake? Or just the maf housing
  6. Dec 27, 2022 at 10:15 AM
    #4806
    M3Tundra-JK
    Scott
    2005 GX470
    Just the maf housing. Will see how well it mocks up with the Stillen tube. Will decide if I cut up Stillen tube later or just replace it altogether.
  7. Dec 27, 2022 at 10:16 AM
    #4807
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Lol sorry man! Sniv will probably be selling his though in the future! Unfortunately not, all I have is the stock airbox which is why I’m maxing out the MAF and need the magnuson box. Seems as though you may be making your own intake anyway though, which I also considered doing.
  8. Dec 27, 2022 at 10:18 AM
    #4808
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I'll be getting rid of mine once I move to that new setup I mentioned. Gold foil included.
  9. Dec 27, 2022 at 10:23 AM
    #4809
    M3Tundra-JK
    Scott
    2005 GX470
    It's a shame prospeed wouldn't sell their MAF tube separately when I asked. As much as they up sale, they missed out on $100!
    snivilous[OP] and reywcms like this.
  10. Dec 27, 2022 at 10:24 AM
    #4810
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    Does anyone know why they have it suck in hot engine air?
  11. Dec 27, 2022 at 10:24 AM
    #4811
    Saltyhero13
    Saltyhero13 Throbbing Member
    4.5" OD.
    MRP and PS are both fairly close ID. Within an 1/16th or less; MRP is larger than the 4.25" they state on the site.
    Unless you get the PS airbox I think you'll have fitment issues since it the PS tube is curved at the filter end.
  12. Dec 27, 2022 at 10:37 AM
    #4812
    Saltyhero13
    From what I understand it is supposed to be installed with a SABM or second fender hole but I don't see how that would fix the situation much the box has about an inch gap from the fender wall. Even if you mod the box it wont be completely airtight. Not a fan of the design, seems more like something done for prototyping not final product. I would wait for the AFE or go with a Stillen + Mods.
    With the PS I was seeing temps 50+ over ambient and would sit there at those temps. With the modded Stillen I usually hover around +28 to +32 over ambient. If I goon around temps rise higher but gradually fall back to the low 30s. Idle and "stop and go" traffic is the only time I'll see higher temps.
  13. Dec 27, 2022 at 10:38 AM
    #4813
    M3Tundra-JK
    Scott
    2005 GX470
    My thought was to cut the Stillen intake tube close to the filter end, then use the rubber coupler to connect to MAF tube. IDK if it'll work....will have to wait till the maf tube arrives. If all else fails I'll just wait till I'll just buy Sniv's or Rey's maggy box
    reywcms likes this.
  14. Dec 27, 2022 at 10:44 AM
    #4814
    Saltyhero13
    Not sure it would work. The Stillen tube necks down to stock intake size rapidly. The MAF section if close to stock diameter and you also have very little room to cut since the vacuum fitting is molded into the plastic. I'll try and post a pic later.
  15. Dec 27, 2022 at 11:04 AM
    #4815
    Saltyhero13
    Not sure that would work since it is tapered. A silicone couple will have a hard time staying connected. I think (not 100% sure) the engine twists towards the driver-side when you accelerate quickly so they will want to separate if not clamped properly; they are pulling away from each other.
    I suspect that is why PS designed the box with so much slop the way they did, it allows some relief for this flexing. If they do separate during acceleration you run the risk of running lean since you are essentially removing the filter and possibly the MAF from the system.
    I also don't think there is a lot of room. For reference the PS intake is about 8" before the curved part where the filter mounts. So from TB+ coupler to Airbox is ~8 inches. In contrast the Stillen is meant for a stock system so it spans 15 inches or so. I learned the hardway trying to get the right fitment and parts and building the proper relief into the system.
  16. Dec 27, 2022 at 12:27 PM
    #4816
    snivilous
    SW UT
    300k+ Supercharged 2008
    My ViktorG tune was $300. That's about the price im expecting to charge the guy in salt lake city for a remote tune.
    Though to be fair I (or Viktor for that matter) are not tuning houses that just dyno stuff all day long. Though I'd like to think our tunes are 90% of a fancy place.
  17. Dec 27, 2022 at 12:37 PM
    #4817
    snivilous
    SW UT
    I was worried about this. None of the PS pictures show the bottom of the intake so I bought it on the assumption it was a fully contained box and as you pointed out, it's really more like a rain shield than anything. For $700 it's a complete rip off. I was thinking of welding their parts together and then adding a floor to it. I'm also concerned since it's all metal it'll get really hot vs the plastic Magnuson intake, so was thinking of ways to try and insulate the box.
    As usual PS fails to impress and seems to only cater to building engines and for the DIY guys you can suck on $700 undeveloped parts.
    Silver17, M3Tundra-JK and reywcms like this.
  18. Dec 27, 2022 at 12:45 PM
    #4818
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Couldn't agree more
  19. Dec 27, 2022 at 1:02 PM
    #4819
    Saltyhero13
    I'll post some pic of the build quality but I think it is a rip off. The tube is well built the box not so much.
    You can build a better airbox for a third of the cost if even that much. If folks want a larger intake tube the MRP air tube with the MAF is of excellent build quality and you can get a no-weld vacuum fitting from Vibrant performance (the middle sized one worked on the Harrop). The only issue I see is there is a slight angle from the TB to the airbox; depending on where it is placed and how the tube interfaces with the box.
  20. Dec 27, 2022 at 1:05 PM
    #4820
    snivilous
    SW UT
    I already have the stupid thing sitting on the kitchen table and just been lazy about installing it since I havent hit the 5V limit yet anyways :D
    reywcms and Saltyhero13[QUOTED] like this.
  21. Dec 27, 2022 at 1:12 PM
    #4821
    Saltyhero13
    That would be the only point for the thing.
    GLWS?
    I hear gold wrapping it will bring all the ponies to the yard.
    :boink:
  22. Dec 27, 2022 at 1:18 PM
    #4822
    snivilous
    SW UT
    In my data logging its at 4.97V, so one argument is do it since I'll inevitably trigger it one day. Other argument is get part of the $700 back and keep the superior albeit smaller Magnuson intake and if it trips the code it's once in a blue moon so who gives a shit.
    Which spelling it out the choice is rather obvious :D
  23. Dec 27, 2022 at 1:19 PM
    #4823
    M3Tundra-JK
    Scott
    2005 GX470
    I'm guessing the answer is no, but since I've seen it on other forums, is there an alternate maf that goes beyond 5v?
  24. Dec 27, 2022 at 1:20 PM
    #4824
    Silver17
    Eastern PA
    I was turned off of the PS intake due to the price from the very beginning. I lost all interest when @Saltyhero13 gave it a bit of a review and reported the fender gaps and higher IATs. I felt bad that it costs all that money just to hack it up to try and make it better anyway. Other than the oversized tube it didn’t seem to have much going for it, and being able to buy a 4.5” tube from that Other vendor and piece it together with some couplers makes it hard to justify. A box totally sealed from the engine bay heat is the only way to go. @snivilous Chances are the code won’t even trip with the magnuson. It has to be pulling over 5v for longer than 3 consecutive seconds, and I don’t even do that with my 3.5” intake. The tuning may not be as dialed in at high RPMs, but clearly mine is running just fine.
    I should note I don’t fault anyone for using the PS intake. Despite the price and higher IATs it’s probably the cleanest looking solution to a 4.5” intake to fix any tuning related issues to the MAF voltage ceiling.
  25. Dec 27, 2022 at 1:29 PM
    #4825
    snivilous
    SW UT
    I did not know that! I'd say definitely no reason to use it then.
    Anyone want a PS intake for a fat discount? :D
  26. Dec 27, 2022 at 1:34 PM
    #4826
    Silver17
    Eastern PA
    That’s how I’ve been interpreting it anyway!
  27. Dec 27, 2022 at 2:31 PM
    #4827
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I'm running the PS intake with two holes in the fender, going directly into the air filter, also running a RCF throttle body. I feel like I picked up 2 psi in boost, holding at 11 on the highway.
  28. Dec 28, 2022 at 5:59 PM
    #4828
    M3Tundra-JK
    Scott
    2005 GX470
  29. Dec 28, 2022 at 6:25 PM
    #4829
    Saltyhero13
    Crazy good.
  30. Dec 28, 2022 at 6:26 PM
    #4830
    Silver17
    Eastern PA
    Amazing delta. Curious about the AFR.
    snivilous[OP] and Fastlane47 like this.
