General Supercharger Thread
  1. Dec 23, 2022 at 11:55 AM
    #4741
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Assuming you have a magnuson? Bang for your buck dollar per horsepower wise I say you can’t go wrong either way getting a smaller pulley. You could probably gain around 30-40hp from the pulley and a retune, but then you may also need more fuel to support it so then you may get into needing bigger injectors and a pump. If you have a Harrop the supplied pump is sufficient for just a step down in pulley size, you’ll just need injectors. Headers you end up probably doubling the expense to get an additional 20-40hp. All depends how much you want to spend and how much more power you want.
    If it’s a magnuson I’d count on $1500ish for a pulley, injectors, fuel pump and tune for 20-40hp gain. Longtubes may get you the same amount of gain for more money (whatever they cost+install). If a Harrop it’s a no brainer, just pulley down and get injectors. and tune it at a minimum.
    I did see that one! The truck I’m thinking of is actually a different one though. But you’re right both are in the 715whp range with harrops. The one I’m thinking of I know has TRD duals, not sure what that white one has for exhaust.
    DDOC1840[QUOTED] and M3Tundra-JK like this.
  2. Dec 23, 2022 at 12:47 PM
    #4742
    Saltyhero13
    Saltyhero13 Throbbing Member
    You and your build will be missed.
  3. Dec 23, 2022 at 2:25 PM
    #4743
    DDOC1840
    DDOC1840 New Member
    2017 tundra platinum
    Magnuson supercharged Elka suspension SPC UCA’s RAS HD Diamond back cover w/ Yakima HD Rack All led lights and fogs diode dyn Coachbuilder TRD Pro kit set to 3” OZ rally raid wheels - satin black 2018+ OEM smoked headlights 295/70R18 Baja boss AT Ceramic coated
    I have the Magnuson. Any ideas on pulley suppliers or upgrade kits to avoid a DIY error?
  4. Dec 23, 2022 at 2:56 PM
    #4744
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
  5. Dec 23, 2022 at 4:28 PM
    #4745
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I hit 11.3 psi on my AEM boost gauge today, stock manifolds, 2.3 pulley on a Maggie with a PS intake and RFC throttle body.
  6. Dec 23, 2022 at 4:42 PM
    #4746
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Does it spike to the 11.3 or was it holding there?
    Fastlane47[QUOTED] likes this.
  7. Dec 23, 2022 at 4:43 PM
    #4747
    Fastlane47
    Maryland
    2018 Platinum
    Had a spike to 12.1 held at 11.3
    Mdl, ZPhilip and HulkSmurf14 like this.
  8. Dec 23, 2022 at 4:52 PM
    #4748
    Silver17
    Eastern PA
    I guess this cold air helps! It’s 7 degrees where I’m at.
  9. Dec 23, 2022 at 4:54 PM
    #4749
    Fastlane47
    Maryland
    2018 Platinum
    It was 40 outside when I made the run, it's 6 here now, lol, I won't take it out when it's this cold
    M3Tundra-JK and Silver17 like this.
  10. Dec 23, 2022 at 4:57 PM
    #4750
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Those are "going" temps! Just need to make sure the transmission is ready to shift! Awesome news on your boost!!
    Fastlane47 likes this.
  11. Dec 23, 2022 at 4:58 PM
    #4751
    Fastlane47
    Maryland
    2018 Platinum
    Yes, with the Valve body it's ready to go.
    HulkSmurf14 likes this.
  12. Dec 23, 2022 at 5:43 PM
    #4752
    snivilous
    SW UT
    300k+ Supercharged 2008
    Thats interesting. Today I measured 4.3psi @ 10,000ft and it matched up to my projections really well, as does my testing at 2500ft. I would've expected 9psi assuming my 2.3" projections are at all accurate (big if) so I wonder if your mods have allowed the extra 2psi. Do you know how much psi it made on the stock pulley?
  13. Dec 23, 2022 at 5:46 PM
    #4753
    Fastlane47
    Maryland
    2018 Platinum
    I don't, I wish I did. They claim the intake will give an extra 2 psi.
    snivilous[OP] likes this.
  14. Dec 23, 2022 at 5:56 PM
    #4754
    Saltyhero13
    Boost solstice is here
  15. Dec 23, 2022 at 8:17 PM
    #4755
    Jcmf52
    Jcmf52 New Member
    Rob
    2018-1794 S/C
    Shorty antenna Trifold hard top tonneau cover Center console safe Center console tray Rhino liner TRD air filter TRD rear sway bar TRD front sway bar Center console wireless charger kit Remote start Black 4x4 emblem swap
    Mine started a similar sound recently as temps dropped.
    did not go away as engine warmed up but actually has gotten more frequent and longer. Sounds like belt tensioner or replace belt? This belt was installed with S/C about 2 months ago and would hope belt would last longer…
    https://youtube.com/shorts/g3oPfxTtPkI?feature=share
  16. Dec 24, 2022 at 5:48 AM
    #4756
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    To me, that sounds different. Mine sounds like a resonance at specific RPMs, yours a "honk" like there's a resistance to air flow or like blowing across the top of a beer bottle.
    We get a couple more of these together and we'll have a band.
  17. Dec 25, 2022 at 12:50 PM
    #4757
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    Progressive didn't cover freaking ANYTHING.
    well.. they DID credit me 345 bucks for the 2k+ in aftermarket wheels and tires, 300 dollar running boards, and roughly 4k in suspension parts I had to leave on it.
    The SC stuff I luckily was able to swap out almost everything for stock parts I'd kept.
    They kept calling me to give get it "to evaluate it" and I kept dodging then t until I had put it back as much to stock as I could.
  18. Dec 25, 2022 at 12:56 PM
    #4758
    M3Tundra-JK
    Scott
    2005 GX470
    Oh, your profile pic just gave me another idea! I still have some rattle can red enamel left. Gonna do the TRD emblem in red
  19. Dec 25, 2022 at 1:24 PM
    #4759
    4firemandan
    SWFL
    Nice. my suggestion is spray it into a cap and then use a brush. I painted my black that way with high temp gloss black. Just keep dabbing out on slowly.
    the red is KBS in Torch Red... which ironically is a Ford color and ended up being the exact paint code of the new truck!
    HulkSmurf14 and M3Tundra-JK like this.
  20. Dec 25, 2022 at 3:38 PM
    #4760
    HulkSmurf14
    2014 Tundra Limited
    If it didn't get too hot, which it does unfortunately, I'd dip it like a Maker's Mark bottle!!
  21. Dec 25, 2022 at 5:04 PM
    #4761
    M3Tundra-JK
    Scott
    2005 GX470
    Just bought my 4 credits for HPTuners, I have the MPVI2+ Pro, and sent an email over to OTT.
    I never ran gauges on the Taco, like I KNOW I should have. What are the preferred gauges and wideband O2 sensors? Will get those ordered next. Looking to start the install in next few weeks
    reywcms and snivilous[OP] like this.
  22. Dec 25, 2022 at 5:06 PM
    #4762
    M3Tundra-JK
    Scott
    2005 GX470
  23. Dec 25, 2022 at 7:30 PM
    #4763
    snivilous
    SW UT
    Innovate PSB-1 wideband/boost gauge imo
  24. Dec 25, 2022 at 7:59 PM
    #4764
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    They will want the AEM one that will log on Hp tuners
  25. Dec 25, 2022 at 9:05 PM
    #4765
    M3Tundra-JK
    Scott
    2005 GX470
  26. Dec 25, 2022 at 9:07 PM
    #4766
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    M3Tundra-JK[QUOTED] likes this.
  27. Dec 25, 2022 at 10:00 PM
    #4767
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
  28. Dec 26, 2022 at 11:08 AM
    #4768
    M3Tundra-JK
    Scott
    2005 GX470
    Actually I'm kinda leaning this way since it'd be cheaper than getting two seperate AEM gauges. Plus I do have that standalone data logger for my MPVI2+ Pro already, wouldn't really need the ODBII adapter the AEM has
    snivilous[QUOTED][OP] likes this.
  29. Dec 26, 2022 at 11:13 AM
    #4769
    Silver17
    Eastern PA
    You get that thing running well yet on the 75mm? Also @reywcms any Whipple updates?
    reywcms and HulkSmurf14 like this.
  30. Dec 26, 2022 at 11:18 AM
    #4770
    M3Tundra-JK
    Scott
    2005 GX470
    Gonna see if I can get my friend to help design and 3D print a pod for the gauge here in the center dash.
