Spark plug tube seal part# question
Discussion in '1st Gen Tundras (2000-2006)' started by wildduk, Dec 10, 2022.
  1. Dec 10, 2022 at 6:34 AM
    wildduk
    wildduk [OP] New Member
    Atlanta
    2006 DC 2WD
    2006 Tundra. 4.7l double cab
    I’m coming up with 2 part numbers for the tube seals.
    11193-70010
    11193-50010
    Requires 8, all the same part. Not a L & R
    Anyone know?
    thanks
  2. Dec 10, 2022 at 9:24 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Looks like 05+ is 11193-50010
    11193-70010 is for 00-04
    shifty` likes this.
  3. Dec 11, 2022 at 2:42 PM
    wildduk
    Atlanta
    2006 DC 2WD
    Thanks for that.
    I also want to replace the 16 ish or so seal washers that go with the bolts for the valve covers.....
    Any idea on those? I've searched numerous sites and cant find them...
    Thx
  4. Dec 11, 2022 at 2:49 PM
    bfunke
    bfunke Tundra Curmudgeon
    Bolts come with attached seals 90080-10330
  5. Dec 11, 2022 at 6:07 PM
    growit
    growit New Member
    2006 Dbcb SR5
    Are the tube seals leaking?
    I've have a 2006 dbcb with 320k miles with original tube seals. I recently replaced the spark plugs and everything was dry.
  6. Dec 11, 2022 at 6:35 PM
  7. Dec 23, 2022 at 5:09 AM
    wildduk
    Atlanta
    2006 DC 2WD
    Not leaking but the valve cover gaskets are…..Replacing them and it’s only a few more bucks to replace tube seals. They get hard and brittle and easy to do when valve cover is removed. Gonna do new plugs too.
    125k on the truck
    KNABORES likes this.
  8. Dec 23, 2022 at 5:35 AM
    At 125k (that’s pretty low miles) you may or may not like what you find under the valve covers. We’d love to see pics of the heads, for reference.
    This post should help with stuff like getting the plug tube seals out, they can be a pain in the ass, and where to FIPG, etc. linking it in case it helps, it links out to lots of other info about the job: https://www.tundras.com/threads/valve-covers-fix-or-leave.105385/#post-2712883
    For some reason on mobile the 1st link in that post is showing what I found under my valve covers, you may need to scroll down for clearer instructions on how to fully pry out the spark plug tube seals. It was THE most tedious part of the job.
    Oh, and you can use doubled-up zip ties to help pull all the fuel lines etc. out of your way on the driver’s side for clearance. I don’t think I linked to pics of that (edit: here), but you may see what I mean when you get in there. Driver’s side is the worst, I tackled it first so the back half of the job would be all downhill. And most trucks I’ve seen, the driver head is always more caramelized than the passenger.
  9. Dec 23, 2022 at 6:04 AM
    wildduk
    Atlanta
    2006 DC 2WD
    Shifty,
    These part numbers are also showing up correct for the L & R valve covers.
    11214-50011. Left
    11213-50031. Right
    they are not what you listed but they show up as correct ‍♂️
    I’m about to order but now not sure which ones are correct. They both say fit the 2006 Tundra 4.7L when you plug into website….
  10. Dec 23, 2022 at 2:24 PM
    (actually, read my next reply also :D)
    Per Toyota's Parts website, your two numbers here are the correct part numbers for 2000-2004 V8/4.7L, my part numbers are for 2003-2006. Here's a snippet from Toyota Parts site to back this up, taken from your LEFT part number:
  11. Dec 23, 2022 at 2:27 PM
    So, I looked up my part number for the left side, and it appears Toyota also lists my part number as compatible for '03+ trucks (just not compatible w/'00-'02). If you're in question, call a Toyota dealership and tell them you're confused and need to know which part number fits your truck.
    (I updated my other post to reflect this info, hopefully kills some confusion for folks later. Looks like there's some weird 2-year overlap for 03/04 trucks with the gaskets)
