  1. Dec 21, 2022 at 4:33 PM
    daveeasa
    Sorry guys, for being a whiney little B on this one, my fault entirely, rushing to get out on the road, didn't pay attention.
    oscardog86, Jack McCarthy and Tundra2 like this.
  2. Dec 21, 2022 at 4:38 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Look, Dave... I hope I'm not overstepping anything by saying this, but you just moved, you've got a business, and little ones to care for while also taking care of you. You've a lot on your plate/mind. No worries Man. This place is great to vent to. Believe me... I know that all too well.
    Anyways, I'm just glad that you got it all squared away.
  3. Dec 21, 2022 at 5:11 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Scan gauge will not cause an airbag light
  4. Dec 21, 2022 at 5:12 PM
    empty_lord
    05 rollover special
    Did they tell you the code? 90% chance it’s just a spiral cable..
  5. Dec 21, 2022 at 5:17 PM
    Pinching a cable can absolutely cause any number of things to happen. All you gotta do is feed power, ground, or interference somewhere it's not supposed to be and the end result can be wildly variable. Computer is a computer is a computer.
    oscardog86 and Jack McCarthy like this.
  6. Dec 21, 2022 at 5:18 PM
  7. Dec 21, 2022 at 5:21 PM
    daveeasa
    Via TS I got 2 VSC codes and probs w SRS and Cruise systems. I tagged you in that post, I think it was the lunch table thread. But, I mean, you have a busted door, kinda more of a stresser than some lights on some guys' dash a ways away. And, like my bro in law said, I've never ever been in a vehicle where the airbags deployed and I don't really intend to. So, it was just something to get dealt with before I went too long b/c kids, safety, wives, etc. And the VSC kinda had me a little concerned. Plus I needed an oil change and I really wanted a full multipoint inspection since the last one I still had valve cover gaskets.
    Anyway, I'm happy that I don't have to undo the integration relay work, that was a chore. Just had to loosen a bolt and now it should be 100% good to go.
  8. Dec 21, 2022 at 5:58 PM
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Yokohama Geolander AT 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate.
    New rubber!!! Yokohama Geolander AT 285/70/17 standard load.
  9. Dec 21, 2022 at 6:25 PM
    It's crazy how many different all terrain tires there are now. I've been researching different ones even though my BFG's should last at least 2-3 more years.
    Speaking of that, I owe them an apology. Earlier this year I mentioned mine were showing signs of dry rot. I was wrong. I looked at them closer in the sunlight outside my garage and they are fine. It's just weirdness with the rubber and how they are made. It's not the same as the dry rot issues I had with Michelin tires on our RAV4. Michelin let me prorate their replacement under warranty.
    I have no clue what tire I will get next. I wouldn't mind trying something new.
    oscardog86 and Tundra2 like this.
  10. Dec 21, 2022 at 6:27 PM
    empty_lord
    05 rollover special
    Got a link so I can see the codes? I’m just busy with everything so I’m behind
    shifty` likes this.
  11. Dec 21, 2022 at 7:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Waiting on the lunchtable to be reopened like...
    NUDRAT, Sunnier, bmf4069 and 3 others like this.
  12. Dec 21, 2022 at 7:32 PM
    daveeasa
    But I assume gone with the scangauge f up out of the picture. Which was entirely my fault. Pinched the odb cable replacing the integration relay. I knew wrenching in a Costco parking lot was a risk but I had to drive at night.
    new scangauge cable ordered.
    oscardog86 likes this.
  13. Dec 21, 2022 at 7:34 PM
    daveeasa
    I mean, I’ll take a $20 cable and $160 Toyota diag fee over a busted door any day. Count my blessings. I’m humble enough to know how easy it is to make a rookie mistake.
  14. Dec 21, 2022 at 8:06 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Haha, was totally hoping this post was going to go something more like:
    Look Dave, you SAID you would give me the SC so please honor that and ship it my way.
    but in a KY jelly @Tundra2 accent
  15. Dec 21, 2022 at 8:20 PM
    I expected @daveeasa’s response in a very polite way to @Tundra2…
    Tundra2, bmf4069, FirstGenVol and 3 others like this.
  16. Dec 21, 2022 at 8:27 PM
    empty_lord
    05 rollover special
    The abs codes shouldn’t cause an airbag light. ABS codes like that one both rears usually ends up being a bad harness on the axle
    CodyP likes this.
  17. Dec 21, 2022 at 8:30 PM
    daveeasa
    I may still ship it. Gonna sleep on it. Ordered the new cable though because the old one is just not worth using. It’s clearly compromised.
    I don’t know that I really need a SG. And maybe if I do another one I go SG3. Dunno really. Glad the solution makes sense. Stoked to see shifty’s powers of deduction pass a test. Even a guy who knows not to f up can f up.
    I don’t know that the SG is that important to me. I’d much rather have steering wheel audio controls.
  18. Dec 21, 2022 at 8:30 PM
    Does anyone here bleed their brake proportioning valve?
    I need to find the Russell speedbleeder equivalent part number for that one bleeder.
    Right now I have the 7mm x 1.0 x 34mm for the 13WL fronts ordered and 10mm x1.0 x 35mm for the rears.
    NUDRAT likes this.
  19. Dec 21, 2022 at 8:32 PM
    daveeasa
    Occams razor right? This all showed up after I swapped the integration relay. I pinched the SG2 cable. Hence some intermittent shorted pins causing chaos. My mistake entirely. No problems with the truck at all. All good once the cable is unplugged.
  20. Dec 21, 2022 at 8:32 PM
    daveeasa
    Jason did mine. I’m not sure how. I only know I love that man.
  21. Dec 21, 2022 at 8:32 PM
    empty_lord
    05 rollover special
    Weird. Carry on.
  22. Dec 21, 2022 at 8:33 PM
    empty_lord
    05 rollover special
    Only time that one really needs to be touched is if the rear lines lose their fluid for whatever reason
  23. Dec 21, 2022 at 8:34 PM
    That’s good to know. I can’t remember if i did it in the past.
    empty_lord[QUOTED] likes this.
  24. Dec 21, 2022 at 8:35 PM
    daveeasa
    I mean, my ego takes a hit and so does the wallet but it’s recoverable. Glad to find a definitive root cause for the most part. Worse to not trust yourself or your gear.
  25. Dec 21, 2022 at 8:38 PM
    Don’t take it to heart, and do trust your gear and yourself! That’s not something easily double checked. Just slow down and be tactical with your actions!
    Sunnier and des2mtn like this.
  26. Dec 21, 2022 at 8:42 PM
    daveeasa
    I was doing the math in my head while wrenching in the Costco parking lot. Had to get to Mr Marv after 6 and to my friend’s before 10. A fairly tight window. And not sure at all that the new part would solve the problem with my headlights. It was around 2-4pm IIRC.
    mostly I was scared of breaking the truck to the point that it wouldn’t be safe to drive. All of my real tools already at the new house. Needed to safely limp home.
    I debated a bunch about just hard wiring to the battery and pulling the fuse when not in use. But I figured best to try a real fix while it had a shot.
  27. Dec 21, 2022 at 8:49 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I did after I pulled my axles and swapped 3rd members.
    Even though I capped the brake lines with vacuum caps to prevent it from losing too much fluid.
  28. Dec 21, 2022 at 9:03 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I always bleed the prop. As much as I hate bleeding brakes...
    FrenchToasty and Jack McCarthy like this.
  29. Dec 21, 2022 at 11:47 PM
    empty_lord
    05 rollover special
    My door fiasco hurt me a lot.
    And it’s going to cost me a lot. Lol
    [​IMG] [​IMG]
  30. Dec 22, 2022 at 3:35 AM
    Anyone need a topper near Indiana?
    oscardog86, txagg and KNABORES like this.
