Dashcam Install
Discussion in '3rd Gen Tundras (2022+)' started by jvperez, Dec 17, 2022.
  1. Dec 17, 2022 at 6:59 AM
    jvperez
    jvperez [OP] New Member
    2023 Tundra SR5 CM LB 4x4
    Hello all,
    Been lurking for a while and finally decided to make an account and post something. I picked up my sr5 on the 3rd, so far loving it. I remember a post with dashcam install discussions but I can't find it anymore. Thought I'd post how I installed my dashcam for any of those still trying to get some ideas. The dashcam I used is the Thinkware U1000 2 channel with the hardwire kit.
    I bought some wire taps off Amazon and tapped into the existing dashcam connector in the headliner. It was a pain to remove that plastic thing on the roof, had to tug on it really hard from the front but eventually it came off. I peeled back the plastic cover on the connector and tapped right into it. Looking at the connector with the pin all by itself to the right this is the order. Leftmost pin = Constant, Middle pin = ACC and rightmost by itself is the ground. I ran the rear camera wire through the headliner using a really long borescope camera from amazon, made it way easier. I mounted it using a quick 2 min part I designed and 3d printed, worked perfectly. Here are some pics.
    Yaboy, Kap1, Durtywrench and 3 others like this.
  2. Dec 17, 2022 at 4:28 PM
    Fxclm5
    Fxclm5 New Member
    Good job, I was going to do the front, but you inspire me to do a rear camera as well, what do you do when the back window rolls down?
  3. Dec 17, 2022 at 4:48 PM
    jvperez
    It's actually held onto the headliner. Kinda wedged between it and the window rubber trim with the piece I made. Window works fine and the camera stays in place.
  4. Dec 17, 2022 at 4:51 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  5. Dec 17, 2022 at 4:51 PM
    Fxclm5
    Fxclm5 New Member
    makes sense, hard to tell in your pic, need to check out the headliner and weather seal and come up with something to mount as well, is your 2 cameras a single unit, or 2 diff units/cameras?
  6. Dec 17, 2022 at 5:06 PM
    jvperez
    Its the thinkware u1000 2 channel. It's two separate cameras connected with a cable between them. The one in the front being the main one that records.
  7. Jan 5, 2023 at 8:33 AM
    John_in_NC
    John_in_NC New Member
    North Carolina
    2022 Black Toyota Platinum
    Side Steps
  8. Jan 5, 2023 at 8:35 AM
    John_in_NC
    North Carolina
    Side Steps
    jkk001 likes this.
  9. Jan 5, 2023 at 8:40 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  10. Jan 5, 2023 at 9:29 AM
    eddiefromcali
    Eddie
    100% Stock
    Works good and no shake. The window seal holds it in place nice and tight
    John_in_NC[QUOTED] likes this.
  11. Jan 5, 2023 at 10:55 AM
    John_in_NC
    North Carolina
    Side Steps
    Awesome, glad someone used it. I like the idea and as my back window is tinted I can't, or won't use a suction cup mount for the Garmin.
  12. Jan 5, 2023 at 1:37 PM
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    I installed this same front and rear U1000 last month as well. I bought this bracket and could not for the life of me figure out how it worked. I ended up using a blank binder clip and it worked perfectly.
  13. Jan 5, 2023 at 4:55 PM
    SecrITSociety
    SecrITSociety New Member
    Orlando, FL
    2023 Platinum Tundra / Blueprint / 4x4
    Works great, had it in my 07 Tundra and will reuse it for my 23.
    Would suggest getting the 1" version, the 2" is a bit much IMO
    SC4333 likes this.
  14. Jan 6, 2023 at 4:54 AM
    1sttoyotundra
    1sttoyotundra New Member
    2023 Capstone
    I've looked pretty much everywhere and couldn't find an answer. My Tundra came with the OEM dashcam, however I want to add a rear one. Has anyone tried to add one to the OEM dashcam? Or is the OEM single channel? I'd hate to remove it, but with the number of miles I drive, a rear one is a must.
    thanks
  15. Jan 6, 2023 at 5:10 AM
    John_in_NC
    North Carolina
    Side Steps
    I was going to ask which one you used. I was thinking the 2" might work best for a Garmin Dashcam 47, but I will take your word on the 1" model.
    Thanks again
  16. Jan 6, 2023 at 5:19 PM
    SecrITSociety
    Orlando, FL
    No prob, I'll be reinstalling mine this weekend (mirror mount is due Saturday) so I'll snap a few pics in the event it helps
  17. Jan 8, 2023 at 11:49 AM
    SecrITSociety
    Orlando, FL
    As promised, here are pictures of the rear mount, I have the larger one at the moment, guess I should order the smaller one now while I run some wires
    John_in_NC and eddiefromcali like this.
  18. Jan 19, 2023 at 6:24 AM
    John_in_NC
    North Carolina
    Side Steps
    Thanks! I wondered how hard it would be fab one-up myself, but then I don't have any breaks and have no inclination to make a DYI one.. So I guess I answered my own question. :)
  19. Jan 19, 2023 at 6:25 AM
    John_in_NC
    North Carolina
    Side Steps
    I know the different trim packages have different mirrors, I did not find a mirror mount for my V1 RD that would work with my truck.
  20. Jan 19, 2023 at 6:33 AM
    SecrITSociety
    Orlando, FL
    I went with a Blendmount for my Blackvue DR-900 which works well, just need to find/create a harness that ties into the existing wiring above the sunglass holder.
    Here's some pics I shared from another thread: https://www.tundras.com/threads/rad...view-mirror-instructions.118274/#post-3042959
  21. Feb 24, 2023 at 4:18 PM
    TheGreenGoblin
    TheGreenGoblin I'm not fat...I'm cultivating mass.
    2023 Tundra SR5 TRD Sport CrewMax 4x4
    *Bakflip MX4 Tonneau Cover *Go Rhino RB20 Running Boards *Go Rhino RB20 Hitch Step *TRD Front Skid Plate *Talon's Cat Shield *OEM Mudguards *OEM bed step *OEM bed extender and bed mat *Lower Door Moldings *EGR SUPERGUARD Bug Shield *SunTek Full Front PPF Wrap *Miyabi Ceramic Coating *Tufskinz decals and door sill protectors
    Did you use the integrated USB, add a fuse, or go the harness route?
  22. Feb 24, 2023 at 6:02 PM
    jvperez
    I used some wire taps into the connector in the headliner.
  23. Feb 24, 2023 at 7:14 PM
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    I'm trying to come up with a plug-in-play kit, similar/identical to what @Maharisc did in this post, ordered the 12v to 5v USB and connectors with wires, I'll see if I can come up with a price for members on here!
  24. Mar 21, 2023 at 1:59 AM
    WawaLunar
    WawaLunar New Member
    2021 TRD Pro Lunar Rock
    Can I ask what fuse did you put the add a fuse into for constant power ? I'm also not sure what fuse to use for the dashcam. The company I bought it from sent me a few different types but said to use a fuse from the glove box. I haven't seen any unused fuses in my glove box though.
  25. Mar 21, 2023 at 5:34 AM
    tinman831
    tinman831 New Member
    DFW
    2023 Windchill Pearl 1794
    What camera wiring kit do you have? You can use an add a fuse kit to tap into one of the existing fuse slots. There are several that are constant. Someone else posted they used AMP1 for constant and that’s what I ended up using.
    WawaLunar[QUOTED] likes this.
  26. Mar 21, 2023 at 6:10 AM
    WawaLunar
    Thank you.
    I have the kit that came with the thinkware u1000 camera and thinkware extended battery pack. Needs to be hardwired. I bought it from blackbox my car. They weren't really of help when I asked them questions about the fuses.
  27. Mar 21, 2023 at 7:28 AM
    GWill
    Willis
    2020 MGM TRD Pro
    I plugged the add a fuse into one of my auxiliary ports I believe. I’ll take a look when I have a chance. I had to pull a spare fuse out of the fuse box under the hood because the ones they send you don’t fit the add a fuse.
  28. Mar 21, 2023 at 7:29 AM
    GWill
    Willis
    2020 MGM TRD Pro
    Also, I’m 2.5 Gen so it may not be the same fuse spot as a 3rd Gen. But it might help you figure it out
    WawaLunar likes this.
  29. Mar 21, 2023 at 8:32 AM
    WawaLunar
    Ah, maybe that's what they meant to say. That would be appreciated, thank you
    Me too. 2021 Pro
  30. May 17, 2023 at 9:57 PM
    P1NDLESK1N
    P1NDLESK1N New Member
    2023 Solar Octane Toyota Tundra TRD Pro
    I installed my Viofo A139 Pro over the weekend, wish I took some pictures during. Instead of the USB cable I wanted to use their HK3-C hardwire kit that needs battery, switched, and ground.
    I found out Subaru uses a the same 5 pin connection that Toyota uses up in the headliner for a mirror harness #H501SSG010. I cut off the other plug, removed the 2 extra wires, and spliced the remaining 3 to the hardwire kit making it a nice and easy install.
    Indy Tundra Guy likes this.
