2017 Platinum 4x4 MGM build
Discussion in '2.5 Gen Builds (2014-2021)' started by PaulROahu, May 19, 2017.
  1. Jun 26, 2017 at 2:25 AM
    PaulROahu
    PaulROahu [OP] New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    You can ceramic coat anything that could use protection from the elements. If you can spread an even coat of surface for 1 minute than go over with a micro fiber and rub it till it's clear. Has a solid feel, wet glass look and slides like silk. A lot better than doing the wax every other month plus this protects better
  2. Jun 26, 2017 at 3:26 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    So I see you have a BullyDog tuner and a pedal commander?
  3. Jun 26, 2017 at 8:13 AM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    I installed the pedal commander the BullyDog tuner is going in late July with Magnuson supercharger and suspension build.
  4. Jun 28, 2017 at 1:12 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    My 1st go at installing my Carbon fiber inserts and was not happy that Still had some Chrome on my cup insert edges
    Eclipsed & Floating likes this.
  5. Jun 28, 2017 at 1:13 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Today custom cut pieces to fill in the chrome, much happier now not getting the glare from my cup holder edges
  6. Jun 28, 2017 at 1:19 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Big mahalos to "Vizsla"/DBaker for an excellent piece of custom work. Fits like a glove and the 5#+ weight fire extinguisher fits right under my seat all the way tucked in a perfect location for easy access. Thanks bud for your work of art for the name of Safety
    Eclipsed & Floating and aperezsh like this.
  7. Jun 28, 2017 at 1:22 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    5# fire extinguisher in front driver seat and 2.5# mini fire extinguisher in my rear driver seat.
    aperezsh likes this.
  8. Jun 28, 2017 at 4:41 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Thought I would be good with a 69"x 12" tool box....not. Had to go with a 69"x 20" to fit all my gear. Plus I like the handles better
    CringyDad and aperezsh like this.
  9. Jun 28, 2017 at 4:43 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    One of the reasons I needed a bigger tool box....
  10. Jun 28, 2017 at 4:45 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    I'm going to need this for when I get my suspension work done next month
  11. Jun 28, 2017 at 4:54 PM
    boloson
    boloson New Member
    Great build. The avs low profile window deflectors fits good? Ive always heard they dont fit the 3rd gens that well. How's the fitment & do u have a part number?
    Klutch air compressor any good? Been looking for 1 myself
  12. Jun 28, 2017 at 5:11 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    In the past I've installed the visors that stick inside the rubber and window, I could hear my motor working hard to role up the last couple inches. So when a friend of mine had the AVS installed on his 2017 4Runner and saw that in attaches to the outside rubber and not on the outside window frame or inside the rubber. I went and ordered them. Very happy with the instal and my window motor works as if no visors are there. Love that's its low profile and aerodynamic.
  13. Jun 28, 2017 at 5:19 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Klutch air compressor just came in today and will try her out soon. I got this cuz it connects straight to battery terminals, quick release connectors, different attachments, higher rate of air pressure and fills up 38" tires quick, as that's the tire size I will be running soon. 22"x 12" or 22"x14" rims yet to be determined.
    Jsena and Eclipsed & Floating like this.
  14. Jun 28, 2017 at 6:15 PM
    boloson
    boloson New Member
    Thanks. 38? Geezuz thats huge. Im jealous not only for the truck but for where u live also. Doesnt it get boring to off road in HI though? Such small islands
  15. Jun 28, 2017 at 6:29 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Not to many off road places, but lots of camping spots, beaches, mountains and trails to explore. For me it's for camping, tail gating and hauling my gear also sometimes for work. Most of the time it's sunny at 80*+ and where I work its beach, surf and bikinis in Waikiki...somebody has to do it ;)
    boloson[QUOTED] and aperezsh like this.
  16. Jul 7, 2017 at 8:09 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Finally after a busy 4th of July weekend had time to instal my Silvania ZEVO 16 color LED interior floor lights. Installed the infared receiver under front passenger dash pannel. Ran front driver side LEDs under the center counsul. Ran the two rear LEDs from front passenger side door pannel and under front passenger seat. Used the longer 36" line for the driver rear seat. Mounted the remote to the rear of shift column on center counsul using Velcro with the infared facing the passenger side, that way I can control my 16 color modes, flash, strobe, fade, smooth and off/on switch with ease.
  17. Jul 22, 2017 at 6:43 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Back from vacation to see this waiting for me: Spyder front headlights, Spyder rear tail lights, Morimoto LED fog lights, LED headlight conversion kit, lower tail gate LED lights for; driving, brake, turn signal, park and reverse. Planning on install tomorrow and the next day.
    Now I can send my stock EOM Platinum head lights to "Retrofit Wholesales" for custom work and will see which one I like better
  18. Jul 26, 2017 at 10:04 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Finally got the last of my LED conversion lights for my rear tail lights. Now I can say I have ALL LED lights from front to rear & exterior to interior.
    Jsena and Ted4311 like this.
  19. Oct 11, 2017 at 11:00 PM
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Finally had some time to replace my 3rd brake light with 2 white LEDs and 1 red LED, then had my rear cowling painted MGM
    Brian0414, ChrisV and Lilly like this.
  20. Oct 11, 2017 at 11:59 PM
    #50
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Man you got a sweet ride brah! Be seeing your neck of the woods in a few weeks! Aloha!
    PaulROahu[OP] likes this.
  21. Oct 12, 2017 at 2:45 AM
    #51
    Wow looks good you have to have the record for most mods the fastest. Lol
    BakNBlk2014 and PaulROahu[OP] like this.
  22. Oct 12, 2017 at 8:18 AM
    #52
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Came home after work to this, Thule truck rack system, wasted no time tore it down to the metals to get them powder coated gloss black and on to my truck. If your asking what happened to my other Trac Rac system...... stupid me only used it 2 times and thought it could fit under the parking structure at work, WRONG tore it right off when I got it stuck under a lower cement beam. Lesson learn stick with the Thule, they can be lowered.
    aperezsh and Jsena like this.
  23. Oct 12, 2017 at 8:23 AM
    #53
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    next up wrap the whole truck in carbon fiber:cool:
  24. Oct 12, 2017 at 8:27 AM
    #54
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Wanna see your pics after instal
  25. Oct 12, 2017 at 8:35 AM
    #55
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Cool ass build thread my friend.. :thumbsup::thumbsup:
  26. Oct 12, 2017 at 9:58 AM
    #56
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Thanks to One of our member “Anthony C” for a great custom “Platinum” floor mat for Huskey Xact floor mat. Love it
    aperezsh and Lilly like this.
  27. Oct 12, 2017 at 10:25 AM
    #57
    Lilly
    Lilly New Member
    Troy
    North Carolina
    2015 White Tundra 1794 Edition
    4-6" RCD Lift System, 20" Moto Metal Rims. PIAA LED Light bar, Tonneau Cover
    Need one for my 1794
  28. Oct 12, 2017 at 10:26 AM
    #58
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Let me guess....”1794”? BTW like your white truck
    Lilly[QUOTED] likes this.
  29. Oct 12, 2017 at 10:27 AM
    #59
    Lilly
    Lilly New Member
    Troy
    North Carolina
    Oh yea!
  30. Oct 12, 2017 at 10:30 AM
    #60
    PaulROahu
    Paul
    Kaneohe, Hawaii
    Think if you order it , you’ll be the 1st “1794” custom floor mat....haha
