Wires to disable TPMS?
Discussion in 'Wheels & Tires' started by kriptnite, Jul 25, 2017.
  1. Jul 25, 2017 at 5:18 PM
    kriptnite
    kriptnite [OP] New Member
    Aaron
    2007 tundra sr5
    New to this site, on the tpms disable do you hook the yellow and green together or do you cut the green wire and tie to the yellow,any info would be great thx in advance
  2. Jul 25, 2017 at 5:48 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Neither:
    ColoradoTJ and Bob like this.
  3. Jul 25, 2017 at 9:19 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I'm not usually one to say "why would you do that?", but why would you do that?
    NewImprovedRon likes this.
  4. Jul 25, 2017 at 11:02 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    A pressure gage is cheaper than hundreds of dollars in sensors that the federal government mandated being installed because Ford Explorer owners weren't responsible enough maintain their tire pressure.
  5. Jul 26, 2017 at 2:46 AM
    TTund16
    TTund16 New Member
    be careful!
    fyi, some places won't work on your tires if your car has a dysfunctional TPMS. it may vary from state to state or even store to store ... idk
    I will need new tires before winter and asked a hypothetical question at Costco if they can remove the sensors if the battery is low or if the sensors are gone bad ... they said they will not change the tires and have to get the TPMS functional if the car came with TPMS!
    i need to let some air out and test the damn thing. if a warning light is on at -%15 (or better) below the reset mark (e.g. warning at 30psi from original 35psi) then i will be happy otherwise its just another gadget! i can look at my tires and if they are %15 low i can tell. However, it can come in handy while driving since u can't stop every 10 minutes and kick the tires ... lol
    if I recall correctly in some cars you have to replace the entire sensor and can't access the battery (again may vary depending on cars) and I haven't done any research ....
  6. Jul 26, 2017 at 3:06 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    I work in a shop, if we remove a sensor we risk getting fined $10,000 per sensor removed.
    Supposedly some states already check tpms operation as part of yearly inpection.
    I know it seems like a dumb system but it's very usefull. I'm a tech and I like having it on my vehicles. Wife doesn't look at tires.
  7. Jul 26, 2017 at 3:12 AM
    Tundraplatinum
    2016 Platinum CM
    This happened to me about 3 weeks ago. I just got done working on other people's cars for 12 hours crazy busy day. Run the he'll out of there jump in my tundra pull 3 feet out of my parking spot and boom tpms light. Jump out right rear tire is almost flat. Had a big bolt in my tire pulled it in shop patched tire then got to go home.
    Not like tpms saved my life or anything but possibly saved me from ruining a $200 tire by driving on it low
  8. Jul 26, 2017 at 3:14 AM
    TTund16
    TTund16 New Member
    so you got the warning light when almost flat! i was hoping for the %15 lol
  9. Jul 26, 2017 at 3:19 AM
    Tundraplatinum
    2016 Platinum CM
    Truck was sitting all day going flat I wasn't driving, if your driving light comes on at 26 I think
  10. Jul 26, 2017 at 3:22 AM
    TTund16
    TTund16 New Member
    did u have it originally at 32 psi?
    warning at 26 psi is not bad either, i suppose i can live with that! :D
  11. Jul 26, 2017 at 3:44 AM
    Tundraplatinum
    2016 Platinum CM
    I usually run my tires 38 psi. the system is set off of the posted pressure in the door jamb
  12. Jul 26, 2017 at 6:06 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    My daily running pressure is less than the door and I have no TPMS light.
    My TPMS light usually pops on if I go wheeling and air down to 25 or less.
  13. Jul 26, 2017 at 6:59 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that you air your tires to where you want them, then set the TPMS with the button on the lower dash. There's more info in your owners manual.
  14. Jul 26, 2017 at 3:03 PM
    Tundraplatinum
    2016 Platinum CM
    Light wont come on until one tire is down to 26psi 27 or more no light
  15. Jul 26, 2017 at 3:18 PM
    LML 3500HD
    I don't have TPMS on my 16', and love it.
    I dread every time the temps get cold out in my Lexus. My TPMS system is always going off even when I'm good on pressure.
