Brand new Tundra with major paint bubbles under clear coat
Discussion in '3rd Gen Tundras (2022+)' started by waves, Nov 22, 2022.
  1. Dec 11, 2022 at 8:41 AM
    #61
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Interesting. I did not know that was a common thing, or a thing at all frankly (heat lamps/heat). I can understand that it's possible that heat would re"set" the clear coat to the paint. I have no idea what "clear coat" really is also, but OK, I'm on board with this as a reasonable method. But....if that's the case, then why is this not standard fare for known problem areas of the vehicle? Seems that it's also possible for there to be some de-lamination to be present that is not visible initially or as obvious as the bubbles in the above pictures. Also seems that the adhesive of the protective plastic needs to be improved to keep this clear coat problem from happening. IMHO
    Russ_S likes this.
  2. Dec 11, 2022 at 8:51 AM
    #62
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Anything needing a paint fix or correction that’s brand new I would sell or do buy back. Aftermarket would never be the same
  3. Dec 11, 2022 at 8:55 AM
    #63
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Wonder if its also specific to a color (MGM) as both the OP and the other member have MGM paint...
  4. Dec 11, 2022 at 9:13 AM
    #64
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    It is a known thing. When I picked mine up and they talked about the pre delivery inspection, it was brought up when I asked about the lamps. They said it's a routine process for them because they see it every week. They said that's really the only thing they use the lamps for.
  5. Dec 11, 2022 at 9:15 AM
    #65
    I don't think it's color specific. I've seen other colored vehicles across multiple brands in other forums. I think it's more evident on darker vehicles than for instance a white vehicle.
    Russ_S likes this.
  6. Dec 11, 2022 at 9:31 AM
    #66
    DrZoidberg
    Dave
    Tesla MYP
    Probably the only positive of the single stage super white on the TRD pro and sr5. No separate clear coat.
  7. Dec 11, 2022 at 9:59 AM
    #67
    usfdrohead
    usfdrohead New Member
    You got hosed. Defective paint and you spent 3 grand more than you wanted to to rectify their mistake.
    Kap1, Terndrerrr and JLS in WA like this.
  8. Dec 11, 2022 at 10:04 AM
    #68
    YOTA_IL
    YOTA_IL New Member
    HEAT GUN!!!!!!!!! For the millionth time people.
  9. Dec 11, 2022 at 11:39 AM
    #69
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Heat gun did nothing to remove the spots.
    Henry1jg, PomDad and Russ_S like this.
  10. Dec 11, 2022 at 12:18 PM
    #70
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    No real downside other that keeping the paint clean during its curing time. That's not to say you shouldn't drive it but I'd avoid taking it out during a huge rain storm or taking it up to the mountains wheeling. And of course no sealant or wax for 45 days. Also keep in mind that clearcoat will be a bit soft during the curing process and is subject to marring, scratching and pitting so be careful when washing and drying.
  11. Dec 11, 2022 at 1:53 PM
    #71
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Why would u care?? You won't keep it lol
  12. Dec 11, 2022 at 1:54 PM
    #72
    Hadelson
    Hadelson New Member
    I am going to have them repaint the damaged panels. I had a 22 TRD OR and this one; 23 TRD Pro is a just a better all around Tundra. The performance and ride is a huge improvement over the Off Road. (Of Course my opinion).
    I went through it inside and out and there is a big improvement in finish and fit (Exception the damaged Paint) Had a very good outcome with this Toyota Regional Body works facility repainting a 2014 Camry due to paint issues.
    I will try and coordinate having the work completed in the spring when winter ends.
    Edit: 12/12 added pictures. Truck is dirty. You can barely notice in bright sunlight. In off light conditions you can see.
  13. Dec 11, 2022 at 2:03 PM
    #73
    DrZoidberg
    Dave
    Tesla MYP
    Flipping days are over I’m afraid
  14. Dec 11, 2022 at 2:11 PM
    #74
    DrZoidberg
    Dave
    Tesla MYP
    Which off road the SR5 or limited
  15. Dec 11, 2022 at 2:20 PM
    #75
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    Op, In had similar issues w/my wife's 2021 Highlander. Not sure of what they did but they removed the marks. Factory paint is FULLY cured when it leaves the paint the booth. It is "baked" at 600 degrees. It is safe to wax/polish your new car as soon as you get it. I have owned over 15 brand new vehicles and the very first thing I do is wax. If you have a vehicle re-painted they cannot bake the paint. You should not wax for at least 60-90 days depending on the paint used. Ask your painter how long to wait. Fresh (non baked) paint needs to vent to release solvents. Sealing those solvents in with wax can cause problems w/a new re-paint job I am no paint expert but have done extensive research on this very subject. Google is your friend.
    Henry1jg likes this.
  16. Dec 11, 2022 at 2:32 PM
    #76
    Russ_S
    Russ_S New Member
    Central New York
    2023 Tundra 1794 TRD Off Road
    If I had never known that would be one thing. Seeing this on the new 70,000 truck that I hope to keep for 10 or more years is very disappointing. I could never trust it and would always be fearful that there would be problems down the road in cold weather or other conditions. Regardless of heat lamps, heat gun, hair dryer. It's not something I want to deal with. If it can't be delivered without major paint problems, I don't want it. BTW, the pictures I posted were of a smoked mesquite 1794, so not just MGM.
  17. Dec 11, 2022 at 2:56 PM
    #77
    Hadelson
    Hadelson New Member
    Limited
  18. Dec 11, 2022 at 3:47 PM
    #78
    DrZoidberg
    Dave
    Tesla MYP
    Someone just posted to tundra FB page. Is this a production batch issue?
  19. Dec 11, 2022 at 4:23 PM
    #79
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    THIS THIS THIS
    316KS_Runner and Russ_S[QUOTED] like this.
  20. Dec 12, 2022 at 8:20 AM
    #80
    Russ_S
    Russ_S New Member
    Central New York
    During the call in which we declined the truck with this issue, our salesmen from the local dealer shared what he was told by their service manager. They said it is moisture in the clearcoat that get's trapped by the film. It is common, and only occurs during the colder months and it can be addressed easily. I said in this case it wasn't addressed before I saw it and I don't have faith in the truck and am working on getting a refund of our deposit. They don't have an issue giving a full refund...just need credit card details.
    I've heard back from two local body shops now and both say if it is clear coat separation, it is a huge issue and to run away from this truck. I likely will never know if it is because they only went on the images I shared and didn't see it for themselves. I also shared the images with a detailer I've used, and he said he doesn't see any major issue...and he is calling me later today to discuss it more.
    At this point...the truck is marked as available. Walking away might be the best decision I've ever made. Worst case, it isn't an issue and I need to wait another 6-12 months for another truck.
  21. Dec 12, 2022 at 1:20 PM
    #81
    Russ_S
    Russ_S New Member
    Central New York
    So, seems like this is a known issue. After I declined the truck they shared the Toyota TSB. Oh well. If it is this and not clearcoat separation, not a long term concern. Back in the queue I go...maybe for the next one the fit and finish will get better! Either way, wasn't pleased with the dealer. They scratched the truck in multiple spots removing the protective film.
  22. Dec 12, 2022 at 2:25 PM
    #82
    DrZoidberg
    Dave
    Tesla MYP
    That user yelling “HEAT GUN” finna drag y’all :popcorn:
  23. Dec 23, 2022 at 1:56 PM
    #83
    waves
    waves [OP] New Member
    I really don't understand how the heat gun method would bond the clear coat to the paint. Yes the moisture will be gone but the bond is not going to be there and 2-3 years down the road, the clear coat will start to peel. I had this happen on a repainted bumper. So my advice, take it back and get another one that doesn't have this issue. FYI, they sold the one I returned in less than a week after listing it as certified pre-owned. Listed at $4k over MSRP.
  24. Dec 23, 2022 at 3:08 PM
    #84
    GatorBodine
    GatorBodine New Member
    You did the right thing, heat gun is/was the wrong choice. That technique is absurd for a real long term fix without future paint problems
  25. Dec 24, 2022 at 5:24 AM
    #85
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    In your second pic it does look like you can see the edge of the ppf install
    I do alot of tinting but little to no ppf but a lot of my 4 runner customers ask me to remove the hood piece when they purchase new
    Road condom for road herpes…
    I hope they get a qualified installer to get ya straight & cover the bill!
  26. Dec 24, 2022 at 12:18 PM
    #86
    Foques
    Foques New Member
    my brother is dealing with this on his sienna right now.. and local dealeship is being a bunch of dicks about it.
  27. Dec 24, 2022 at 1:08 PM
    #87
    GatorBodine
    What year model of Toyotas is this affecting? I've had 3, 22' model years this year and have not seen this.....
  28. Dec 24, 2022 at 8:25 PM
    #88
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    In what world does it seem reasonable or acceptable for the buyer of a brand new vehicle to use a heat gun to “fix” a paint issue?
    It’s those type of buyers that enable dealerships to treat customers they way they do because they feel they can get away with it. “If you don’t buy it, they next guy will. Blah, blah, blah. Dealers prey on the weak, uninformed buyer. Additionally, manufacturers can’t correct flawed processes if buyers just “use a heat gun”.
    Russ_S and Leo's first like this.
  29. Dec 24, 2022 at 8:46 PM
    #89
    18" TRD Off Road Wheels
    Read the bulletin @Russ_S posted (quoted above yours)
    Depends on if you believe the bulletin. If it's not clearcoat separation and just staining as they say, then what long term issue do you expect? You have to decide if you trust Toyota or if you think you know more than they do about their paint. Anyone in this situation would have to evaluate that for themselves.
    Show the bulletin to you brother and have him take it to a dealership he trusts. He can also show the bulletin to the dealership that is being dicks and lodge a complaint. Only do that if you never plan to go back there.
    Bulletin Russ posted (quoted at top of comment) states it is 2010-2022 models
    The dealership should have already treated it before delivery. See the bulletin above.
    Russ_S[QUOTED] likes this.
  30. Dec 24, 2022 at 10:49 PM
    #90
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    3 pages on paint bubbles....sheeeshhhhh give it a break.
