So has anyone actually solved the bed bounce/embarrassing highway ride?
Discussion in 'Suspension' started by FredB32, Jan 7, 2022.
  1. Jan 14, 2022 at 2:50 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    I guess I should have said that the bucking on concrete highways is pickup truck problem. Just about every pickup I've riden in had it to some degree.
    Every pickup is going to have some bed bounce and frame twist too though. I think the tundra is worse than average because the frame is boxed only from the cab forward and I think the rear section is far more flimsy than the front section. Combine that with a very heavy front half of the truck and a heavy rear axle; the bed ends up getting thrown around a lot. There's no weight and stiffness in the rear part of the frame to control it better.
  2. Jan 14, 2022 at 5:12 PM
    Black
    2014 Tundra Limited CrewMax
    I have the Falcon Leveling system with Coachbuilder +1 shackles and bed bounce is pretty much gone now.
    A couple of long weird bridges on one route I take frequently still cause it very slightly but worlds better than with the stock suspension.
    Gertimus, Coachbuilder1 and Skew12 like this.
  3. Jan 14, 2022 at 7:55 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I too have the bed bounce. 19’ with Toytec Boss coils on the front and shocks on the rear. CB shackles on the rear as well. I also just put on JBA UCA - I drove my dad’s Chevy 2500 for a couple days and it had a similar harmonic bounce as my truck but the bounce didn’t seem to be as bad. My truck is super smooth on blacktop and even some concrete stretches but some stretches of concrete the bounce is fairly pronounced.
    Skew12 likes this.
  4. Jan 15, 2022 at 4:51 PM
    FredB32
    FredB32 [OP] New Member
    Fred
    2011 TRD RW
    So I got around to picking up those 2019 Sport shocks that... That'll be Step 1 to trying to smooth out the ride. Next up would be the CB +1 shackles.
    There's also someone local selling Camburg UCAs... Any chance they'd provide any improvements for $500?
    Question: the shocks didn't come with the bushings, and the originals from 2011 look pretty well toasted...any recommendations for an upgrade to the shock bushings I should get to install while I'm at it? For clarification, it's the vertical bushings on top. The pressed in bushings on the bottom eye are there.
  5. Jan 15, 2022 at 5:23 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    I just installed JBA arms. Overall performance improvement and seemed to tighten up the steering (I assume with the added caster) but didn’t improve the bounce for me. I also have Toytec rear shocks and CB shackles.
    Skew12 likes this.
  6. Jan 17, 2022 at 4:12 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    If you're still feel some feedback after installing our +1"s give me a call and will gladly help. we can adjust torque spec on the lower shackle bolts allowing a slightly less aggressive pivot and will normally eliminate any bound up energy that may be felt. David 801.635.4872
    FredB32[OP] likes this.
  7. Jan 17, 2022 at 4:13 PM
    Coachbuilder1
    Salt Lake City UT
    Thats a nice system, We've had excellent result with the Falcons paired up with our shackles.
  8. Jan 17, 2022 at 5:12 PM
    Black
    Falcons are hands down the best kit under $2k by an absolute long shot.
    Coachbuilder1[QUOTED] likes this.
  9. Jan 17, 2022 at 5:19 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    Yes still have some pretty severe bounce on certain stretches of highway. I’ll be glad to give it a try.
  10. Feb 1, 2022 at 12:45 PM
    FredB32
    Fred
    2011 TRD RW
    Keeping this alive a little bit: I filmed this on my way home from a quick beer run this weekend, on some concrete highway sections. There's a bottle of Buffalo Trace in the bag, and it was sitting perfectly to be able to hear how much bouncing/vibration is coming through on roads like this in the cab: https://www.instagram.com/tv/CZctQ1DqnLE/
    Skew12 likes this.
  11. Feb 1, 2022 at 1:07 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    been in the tundra game since 08 when i bought my truck new. folks that are saying they've never had it may not know exactly what the issue is but (it's a known thing just google it and) every tundra has some level as well as other trucks. in many cases it's more pronounced on certain roads at certain speeds in particular concrete highways versus black paved ones.
    there was a tsb back in 08 to change out body mount bushings. i had that done and it helped but was still there. the only thing that has addressed it for me is some weight in the back and upgraded suspension but mostly it was the weight in the back. i'm running a full size spare swing out and left my oem spare under the truck. i can honestly say the majority of it is gone but there's still very little weight in the back so some remains. minimal tho.
    Peeeheeuuu and Skew12 like this.
  12. Dec 12, 2022 at 10:03 AM
    Bob the builder
    Bob the builder New Member
    2015 Tundra 1794
    My 2015 Tundra 1794 has 107,000 miles and has always had a smooth ride on asphalt and dirt roads… but on concrete freeway it is absolutely horrible. When on the freeway I wonder why I keep it… only because I forget about it after I exit the truck. The only time it rides decent on the freeway is when it is loaded with people and gear in the bed.
    hagrid likes this.
  13. Dec 12, 2022 at 10:18 AM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
  14. Dec 12, 2022 at 10:20 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Which engine oil you using?
  15. Dec 12, 2022 at 10:23 AM
    W3agle
    W3agle New Member
    San Diego, CA
    2016 White Tundra SR5 TRD Off-Road
    I have added ~500-1000lbs in my bed depending on how loaded up it is and I never experience bounce any more. It was bad stock though.
  16. Oct 12, 2024 at 7:33 AM
    ToyotaWay
    ToyotaWay New Member
    What cover are you using and do you have a DoubleCab?
    I've been considering a cover and have a very bouncy 2013 Tundra DoubleCab so, maybe I can kill 2 birds with 1 stone.
