LSD or not?
Discussion in '1st Gen Tundras (2000-2006)' started by Doughnut, Dec 8, 2022.
  1. Dec 8, 2022 at 1:44 PM
    Doughnut
    Doughnut [OP] New Member
    2005 SR5 Access Cab
    Happy new owner of a 2005 SR5 access cab. Toyota owners online info doesn't say anything about an LSD in the rear differential. However, there is clearly an LSD sticker on the casing. Who should I believe?
    5N0W808 and Jack McCarthy like this.
  2. Dec 8, 2022 at 2:02 PM
    I believe your diff housing needs to be replaced
  3. Dec 8, 2022 at 2:04 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I wouldn't worry about LSD for now, and yes it was available in trucks.
    It looks like you have some rust to address. Hopefully the frame does not look like that.
  4. Dec 8, 2022 at 3:25 PM
    Crusty! I would think the option would be listed in the VIN somehow.
  5. Dec 8, 2022 at 3:38 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    If Toyota Owner's Online doesn't list an LSD sometimes the Toyota Vin Decoder will.
  6. Dec 8, 2022 at 3:48 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I’d be looking for a whole new reared with an LSD already in it??:) looks pretty rusty crusty!
  7. Dec 8, 2022 at 4:50 PM
    Please be a troll post.
    txagg, Mr.bee, Silver17 and 2 others like this.
  8. Dec 8, 2022 at 5:05 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    That LQQKS like an LSD while 'ON' LSD.
  9. Dec 8, 2022 at 5:11 PM
    I AM A BANANA.
    I'd believe the rear-end, but also run through a VIN decoder. Toyota Owners site says my truck came with cloth 60/40 or something crazy like that, but I have leather captains chairs, so ... meh.
    Silver17 and FrenchToasty like this.
  10. Dec 8, 2022 at 5:14 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Your VIN on my Toyota account will tell you
    Also, drain it and peek inside and you will also know
    As if that sticker is still there.
    speedtre likes this.
  11. Dec 8, 2022 at 5:17 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
  12. Dec 8, 2022 at 5:18 PM
    MEWaters
    MEWaters New Member
    Maine
  13. Dec 8, 2022 at 5:18 PM
    15 or 25? Aw hell, I'm in either way.
  14. Dec 8, 2022 at 5:27 PM
    Shhh! He’s just driving it until the wheels fall off, literally from all the rust holding it together.
  15. Dec 8, 2022 at 5:37 PM
    Doughnut
    2005 SR5 Access Cab
    Lol, don't any of you live in New England? That's just surface rust! I have no idea how that sticker is still holding on.
    Also, the frame was replaced.
    lsaami, txagg, Jack McCarthy and 3 others like this.
  16. Dec 8, 2022 at 5:44 PM
    Doughnut
    2005 SR5 Access Cab
    I suppose there is no harm in putting in LSD specific gear oil (90w?) vs. the 75w90 that a non LSD diff would use?
  17. Dec 8, 2022 at 5:49 PM
  18. Dec 8, 2022 at 5:59 PM
    I live here and that’s a little more than surface rust. lol. A small hammer will let you know how bad it really is there. Less rusty diffs than yours had fluid leaking problems.
    It’s good that the frame was replaced. How’s the bed? Got any rust trying to break through the paint?
  19. Dec 8, 2022 at 6:08 PM
    Doughnut
    2005 SR5 Access Cab
    No puddles of fluid under the diff yet...
    Bed and body seem to be great. There is a bubble under the paint on the back cab corner- driver's side. Otherwise, it's as rust free as you could hope for in the Northeast.
    Except for what might be happening under the bedliner... I'm in no hurry to pull that up. Is it worth it to keep the plastic bedliners in? Or do they simply trap the water and contribute to rust?
    It looks like Shifty has it right on the fluid- I just checked Amsoil and they recommend the same fluid for both LSD and no LSD. Thanks! I'm sorting everything out for the typical first service of a new (used) vehicle.
    txagg and FrenchToasty like this.
  20. Dec 8, 2022 at 6:12 PM
    Rules of the forum are no politics and religion. :rofl:
    (It's a heated topic with polarized answers - I'm personally always leaving mine in. But you should pull and clean under the liner once every other year or so.)
    Doughnut[QUOTED][OP] likes this.
  21. Dec 8, 2022 at 6:58 PM
    You may be in for a big surprise when you lift that bedliner. These trucks have a flaw in the supports underneath that trap water and salt and rust through from under the bed. This is mine as an example.
    shifty` likes this.
  22. Dec 9, 2022 at 1:59 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    My rear end looked like that when I got it, although not quite as bad. I was worried that trying to remove the fill plug would shred the pumpkin, but no problem. I knocked all the loose rust off with a wire brush, then used rust converter, followed by Eastman Rust Encapsulator (others use POR-15...another religious debate I'm afraid).
    Jack McCarthy likes this.
  23. Dec 9, 2022 at 5:27 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Pretty sure mine will look something like that.
    Have you done anything to fix it?
    SPP
  24. Dec 9, 2022 at 5:33 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Jack up the back wheels, in neutral, if your brakes arent dragging, do both wheels rotate the same direction?
    txagg likes this.
  25. Dec 9, 2022 at 5:41 AM
    Silver17
    Northeast
    Looking more closely, is it just me or does the bottom left portion of the diff look like it has oily residue from a leak? That sucker may be pretty thin steel at this point. I’d make sure it’s not low on gear oil.
    MEWaters and KNABORES like this.
  26. Dec 9, 2022 at 5:55 AM
    Yup, it's already saturated. Not much OP can do on that one other than find a new housing and/or replacement rear axle assembly from a matching-cab/similar year truck.
  27. Dec 9, 2022 at 6:30 AM
    MEWaters
    MEWaters New Member
    Maine
    I live in Maine. I still don’t have any surface rust on my frame. Just a smidge surface on some of the diff.
  28. Dec 9, 2022 at 8:12 AM
    Nothing yet. The plan is to learn how to weld first. For now, the plastic liner just goes over it and I spray fluid film underneath every winter.
    slowpokepete[QUOTED] likes this.
  29. Dec 9, 2022 at 8:37 AM
    THORYOTA
    THORYOTA God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    I prefer molly or DMT, but to each their own.
    FrenchToasty and bmf4069 like this.
  30. Dec 9, 2022 at 10:25 AM
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    My diff housing looks a lot like yours. I am afraid if I try removing the plug its going to twist the metal out around it. I have no idea if the fluid has ever been changed or not. I carefully removed as much loose rust as I could and used rust converter to hopefully prolong its life. I will drive it as long I as can and then make a decision on whether or not to replace it.
    w666 likes this.
