Diff and T-case fluid brand preference
Discussion in '1st Gen Tundras (2000-2006)' started by Casper421, Oct 30, 2021.
  1. Oct 30, 2021 at 9:31 AM
    Casper421
    Casper421 [OP] Toyota RidgeTrac driver!
    In the woods
    06 DC
    As the title states, which fluid brand do you guys prefer for your diffs and transfer case? I’ve always run Mobil 1 with TransX lsd additive in the rear diff. Interested to see what you guys run.
  2. Oct 30, 2021 at 10:07 AM
    I like Valvoline. It's not expensive and it does the job. Personally, I think synthetic is overkill for diffs and transfer case as I haven't heard of anyone complaining they wished they switched to it.
    Although, maybe that's the way to go if you're not good about changing it periodically.
  3. Oct 30, 2021 at 10:28 AM
    I had been running amsoil, but the dealer I went thru quit selling, so I’ve recently tried redline in my rear diff, so far so good
    wandering_boy and Ely010606 like this.
  4. Oct 30, 2021 at 4:37 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Red Line and don't look back.
  5. Oct 30, 2021 at 8:05 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Mobil 1
  6. Oct 30, 2021 at 8:16 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    All three of mine got Lucas Oil.
    FirstGenVol and DaWhiteTundra like this.
  7. Oct 30, 2021 at 8:22 PM
    patterson.walter
    patterson.walter New Member
    Walter
    2007 white SR5 5.7 db cab
    Valvoline because when I asked the dealer for the OE fluid he said don’t buy it here its “stupid expensive” go to Walmart and buy valvoline. So I did :cool: and no issues in the 20k it’s been in there.
    Jack McCarthy and Ely010606 like this.
  8. Oct 30, 2021 at 8:28 PM
    SouthPaw
    2000 Limited 4x4 AC
    In all reality, any name brand synthetic will do just fine. Even the SuperTech Wally World brand would be fine IMO as long as it’s changed regularly.
    patterson.walter likes this.
  9. Oct 30, 2021 at 8:58 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Amsoil and don’t go heavier weight thinking you’ll get more protections, you’ll just create heat.
    Redline is also good stuff.
    In reality as long as you meet the factory spec, and you don’t run anything dry, it will probably never fail.
    coldcanuk likes this.
  10. Oct 31, 2021 at 8:34 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Do you use Red line for all 75w90 for all 3? I logged on to redline and they recommend same for all 3 but I see that for the rear diff it says for LSD. Can you use that for the front and transfer?
    How much do you need to do all 3?
  11. Oct 31, 2021 at 8:40 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    I only use AmsOil on my track car great stuff. Which AmsOil do you use for front diff,transfer and rear?
  12. Oct 31, 2021 at 8:54 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Severe gear 75W90 in all three holes for your year. You'll never have a problem if it's not your first time doing it.
    Just like a Harley D. (I'm making a joke, don't eviscerate me for exceptions)
    Darkness likes this.
  13. Oct 31, 2021 at 8:57 AM
    Dave8699
    Dave8699 Trackrat
    NJ
    By first time doing it you don't mean first time using Amsoil correct? Just want yo make sure I change it I believe around every 30K but I want to Starr doing it myself.
    Is this what you use? How much do you need for all 3? Also do you add anything to the LSD?
  14. Oct 31, 2021 at 10:04 AM
    coldcanuk
    No, I just meant if it's a 2004 and this is the first time the fluids are being changed in the diffs and Transfer case that wouldn't be good. I'm sure you take great care of your truck, the added expense of a top shelf gear oil now is worth the peace of mind if you ask me. I like Amsoil and Red Line gear oils, I'm no expert but have never had an issue with any Toyota parts protected by this gear oil and I'm an old man.
    Easy to find the quantities, you can even plug your vehicle in an Amsoil app and they tell you. As far as a LSD additive I don't think you need it but I'd let an expert comment on that, certainly it's not needed in gen 2.5.
    I like the old Tundras!
    Tundra2 likes this.
  15. Oct 31, 2021 at 10:19 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    As mentioned, 75-90 Severe Gear. I use it in all my diffs even the Dually.
    Probably will be the last fluid the diffs see in their lifetime lol.
    AZBoatHauler likes this.
  16. Oct 31, 2021 at 1:10 PM
    Royal purple full synthetic in my cases.
  17. Oct 31, 2021 at 2:47 PM
    Not that they are the end all be all of gear wisdom, but the folks at East Coast Gear supply do not recommend synthetic gear oil. They have a long write up on the subject I've shared before but it's not necessarily specific to Toyota. They like Lucas dino oil which is what I run.
    https://eastcoastgearsupply.com/ft-2536-ecgs-gear-oil-recommendation.html
    "Other findings, and this varies based on the actual synthetic used: Synthetics thin out quickly once hot and lose their cling ratio to the metal object, when the oil is stuck to the gear it provides a cooling factor for the metal. We also believe that dino oil has better pressure properties, ie it provides a better cushion then synthetic for two reasons. First, it does not thin out as much and two it clings to the gear."
    Darkness and FrenchToasty like this.
  18. Oct 31, 2021 at 6:08 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    This is interesting, What motor oil weight do you use and additive?
  19. Oct 31, 2021 at 6:13 PM
    Engine oil? Mobile 1 5W-30 synthetic. This thread is about gear oil though.
  20. Oct 31, 2021 at 6:17 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    Yea I know but you said dino oil usually that's a nick name for conventional motor oil so it confused me.
  21. Oct 31, 2021 at 6:24 PM
    des2mtn likes this.
  22. Oct 31, 2021 at 6:39 PM
    Dave8699
    Dave8699 Trackrat
    NJ
  23. Oct 31, 2021 at 6:47 PM
    Wait, you guys change your diff juice?
    coldcanuk, Tundra2, Darkness and 6 others like this.
  24. Oct 31, 2021 at 6:59 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    Oh shit here we go the battle of which oil and don't change or change:fistbump:
    Darkness and bmf4069[QUOTED] like this.
  25. Oct 31, 2021 at 7:03 PM
    0h6SR5
    0h6SR5 New Member
    2006 Phantom Grey Tundra
    3 inch OME with AAL wheels and tires. 285 70 17
    Amsoil all day
    07DCLimited, coldcanuk and Ely010606 like this.
  26. Oct 31, 2021 at 7:45 PM
    I would take this information with a shaker full of salt.
    HAL69000 and 07DCLimited like this.
  27. Oct 31, 2021 at 7:50 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    ^^^ X2
  28. Oct 31, 2021 at 7:58 PM
    Dave8699
    Dave8699 Trackrat
    NJ
    Amsoil and Lucas synthetic are both $15 a quart. Red line is about $20 a quarter. Mobil synthetic is around $14 a quart. So price is not that big of a difference
  29. Oct 31, 2021 at 7:59 PM
    Very few Tundra owners here see -40 temps and yes synthetic does make a difference in that case.
  30. Nov 1, 2021 at 6:29 AM
    They did back it up with an explanation at least. I'd say as long as people do regular changes the fluid probably isn't that important. Curious why you don't believe them though. I don't have a real strong opinion on it.
