T100 Brake Booster Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Thrussn, Mar 31, 2021.
  1. Nov 27, 2022 at 12:58 PM
    #151
    Casper421
    In the woods
    06 DC
    Did you feel any difference going up to the 14wa’s? Firmer pedal? More bite?
  2. Nov 27, 2022 at 1:50 PM
    #152
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Excellent post. Thank you for sharing!
  3. Nov 27, 2022 at 1:56 PM
    #153
    If you're going to do it, I would consider buying calipers from the OG, Geoffrey Beers. I keep seeing people on Facebook that bought from him and had success.
    I really don't think the T100 swap is necessary if the Lexus calipers are modified correctly.
    Weagle and FrenchToasty like this.
  4. Dec 1, 2022 at 3:06 PM
    #154
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    100% the pedal feels amazing and stops on the dime
    Casper421[QUOTED] and speedtre like this.
  5. Dec 7, 2022 at 8:08 AM
    #155
    Thrussn
    Thrussn [OP] Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Hey! Did I never update my caliper install? After milling, the calipers and rotors installed perfectly.
    Sorry about being MIA. Lots of life getting in the way this year!
  6. Apr 21, 2023 at 4:09 PM
    #156
    timesinfinity
    timesinfinity New Member
    drew
    northeast
    jumping into this older thread here...
    i hear alot about there being two versions of the booster one with short and one with longer studs. the longer allegedly allowing you to use the aluminum spacer. does anyone have any info on this? do we not need the spacer? i saw the OP here didnt use it but in some other threads they did. just curiuous before pulling the trigger for my 2005 ac 4x4 with abs. thanks!
  7. Apr 28, 2023 at 9:43 PM
    #157
    Lt_taco
    Lt_taco New Member
    Iran
    2003 Camburg race kit Tundra
    Camburg race kit, C27 deavers, 3.0x16” bypasses
    Hi guys, so I need some help. I recently did the T100 booster and master conversion and now my pedal is extremely still. I trimmed about 3/8” of the shaft off and turned the nut that holds the pin all the way in. My stock booster still sat lower, but I had no more adjustment in the new booster to go any further. Any ideas? The booster is an oreillys so it should be good, idk if i’m loosing pressure or what. The pedal works but is too hard. After cruising the freeway and as i’ about to get off the pedal feels like it has absolutely no assist.
  8. Apr 28, 2023 at 9:53 PM
    #158
    Lt_taco
    Lt_taco New Member
    Iran
  9. Apr 28, 2023 at 9:54 PM
    #159
    Lt_taco
    Lt_taco New Member
    Iran
    T100 after trimming and adjusting all the way down. 0A10957B-A89E-4FD2-B0FB-7AE04746D137.jpg
  10. Apr 28, 2023 at 9:55 PM
    #160
    Lt_taco
    Lt_taco New Member
    Iran
    As you can see the stock one has way more adjustability. DB85F75A-93FC-480F-8483-387B2CDD1EBF.jpg
  11. Apr 28, 2023 at 10:00 PM
    #161
    Lt_taco
    Lt_taco New Member
    Iran
    Another thing I saw was that when I went to put the pin in it was super difficult. Another thing I thought about possibly doing was to tap the shaft to get more threads out of it therefore to have more adjustment. Any help is appreciated.
  12. Jun 11, 2023 at 2:36 PM
    #162
    Mattythadaddy
    Mattythadaddy New Member
    Matty
    03 tundra
    Long travel front
    When you did the swap did you use the spacer included on the factory booster? Tried to do it without and brakes felt like crap so went back to factory because I was limited on time I had to tinker. I cut the shaft and ran it without space cause with space the studs on the t100 one I got were too short. Thanks in advance
  13. Dec 21, 2023 at 6:35 AM
    #163
    Krondor
    Krondor New Member
    Just installed the brake booster and master cylinder. My brakes pedal is pretty hard to press now and the brakes don't really work. I'm not sure of my issue. When I crack the brake lines at the master cylinder and press the pedal, the pedal sinks and is easier to press. (it also shoots brake fluid out of the craked fitting). I'm not sure what could be causing the "lock up". Anyone who has done this upgrade experienced something similar?
  14. Dec 21, 2023 at 7:14 AM
    #164
    You sure the T100 MC / booster were both good?
    Was it necessary to make any adjustments to your push rod depth so you're engaging the MC properly?
    What state the calipers om with no pedal pressed, clamping or open?
    If you're not catching where I'm going with this, I'm curious if maybe you didn't adjust things out, so the brakes are remaining engaged at all times, and when you're pressing the pedal in, you're hoping to engage calipers that are already fully engaged because you failed to make necessary adjustments.
    LarrWhy and Trd88noz like this.
  15. Dec 21, 2023 at 7:32 AM
    #165
    Krondor
    Krondor New Member
    All reasonable questions. The T100MC and booster were both purchased new. Not OEM however. The MC is a an ASIAN so I feel confident in that. The booster is an ACCARDONE so I'm not as confident in that. But I should still be able to stop the vehicle with a heavy foot and a bad booster.
    The push rod was red locktighted in place. I didn't feel any pressure when putting the MC on. but that is a good area to check. I might space the MC out with washers to test that theory before breaking the locktite.
    I'll throw the truck up on jack stands and test the calipers/ brakes to see if there is any hang up and report back.
    Thank you for the ideas.
    shifty` likes this.
  16. Dec 27, 2023 at 9:47 AM
    #166
    Krondor
    Krondor New Member
    There was a little hang up with the master cylinder so I spaced it out with 3 washers. The pedal stroke is much better. I then bled the system but the trucks brakes slowly. It can stop the truck but it doesn't stop near as quick as it should. I also can't lock the brakes up, even if I stand on the brake pedal.
    shifty` likes this.
  17. Dec 27, 2023 at 12:24 PM
    #167
    Sounds like you need to adjust your pushrod, it wasn't adjusted properly.
    On mushy pedal, you bled in the order of pass ear, LSPV, driver rear, passenger front, driver front, right? (You did bleed the LSPV, right?)
    Did you use pressurized bleeding, or shove-foot-to-foor bleeding method?
  18. Dec 27, 2023 at 1:04 PM
    #168
    Krondor
    Krondor New Member
    It's not really the pedal that is mushy. The pedal feels like it should braking wise. The pedal is also stiff when the truck is turned off. But the truck just takes more time to slow down. (much longer than it should). Pumping the brake pedal while it's on doesn't change the pedal feel either.
    I did bleed in that order and made sure to bleed the LSPV. I initially used a vacuum bleeding tool then used the old shove foot to floor after driving it and not getting the results I was expecting. I got similar results with both.
    I may look into bypassing the LSPV with a wilwood unit. That is the only part of the system that I have yet to replace. The tundra is a 2000 without abs so it's about as simple as it gets.
    shifty` likes this.
  19. Jun 27, 2024 at 7:14 PM
    #169
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    So I'm starting to get the symptoms of a bad BB (paddle chattering (only has happened a few times) stiff pedal and noticing longer braking distances my abs light has been on and off the last two-three weeks) anyways I want to upgrade to the t100 BB and MC but I'm wondering which parts to get? I found the oem BB for about 700 but the MC is discontinued. Which would you guys recommend? I really don't have pickaparts near me and I'm not really comfortable with eBay lol. is something off rockauto usable or is it a LBJ topic haha.
  20. Jun 28, 2024 at 2:41 PM
    #170
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    I have this for sale. Think it came off gx470
  21. Jun 28, 2024 at 8:17 PM
    #171
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    I wouldn't know if that's compatible
  22. Jun 29, 2024 at 1:29 PM
    #172
    BluegrapeVr6
    J
    I was told this was a good upgrade for our trucks. Others might know more. P/n on it is SK 007 L37 1332
    I have no incentive to sell , it was given to me, just trying to help u out. U pay for shipping you can have it. If it works just send me whatever i was asking for it and if not return is totally cool. Its new. If too much hassle no worries. I was told it was for a gx480 or t100 or something. Some guys on here can chime in im sure. 20240629_162347.jpg 20240629_162318.jpg 20240629_162339.jpg
  23. Jun 29, 2024 at 1:31 PM
    #173
    BluegrapeVr6
    J
  24. Jun 30, 2024 at 9:57 AM
    #174
    Stock63
    Stock63 Clueless
    2005 Tundra DC 4WD
    I'm okay but I appreciate the offer.
    BluegrapeVr6[QUOTED] likes this.
  25. Sep 3, 2024 at 8:10 AM
    #175
    Fieldnstreamer
    Fieldnstreamer Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    Do you still have it? Do you know if it's a comparable upgrade to the t100 upgrade? My brakes have been acting super weird lately. Sometimes working fine, others the pedal just goes to the floor. I was going to try to do the T100 upgrade but this may be an equivalent.
  26. Sep 27, 2024 at 7:00 PM
    #176
    michael.crg
    michael.crg Pothole Hitter
    Michael
    2000 Toyota Tundra AC Limited 4x4
    Bilstein 6112's leveled (6/4), SCS F5 17x8.5 4.3' Backspacing on 285/70
    I'm going to attempt this upgrade. Is there a specific MC that I'll need to be compatible with this booster or can I just buy any OEM/Aftermarket booster? The link is currently turning up with nothing on the write up.
