Rear end
Discussion in '1st Gen Tundras (2000-2006)' started by michalakd, Dec 6, 2022.
  1. Dec 6, 2022 at 8:34 AM
    michalakd
    michalakd [OP] New Member
    2010 Tundra
    Can you switch out 04 for an o10
  2. Dec 6, 2022 at 8:37 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    bmf4069, hagrid and shifty` like this.
  3. Dec 6, 2022 at 8:38 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    04 into a 10? Not recommended. 1st and second gens are fairly different, lug pattern for starters.
    des2mtn likes this.
  4. Dec 6, 2022 at 8:40 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Color me surprised that the max track width of an '04 (?DC?) is about the same as the track width of a '10, within 1/2".
  5. Dec 6, 2022 at 8:41 AM
    michalakd
    2010 Tundra
    Can live with that but is wheel base same
  6. Dec 6, 2022 at 8:50 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Axle has different shock mounts and everything. Won't work without fab work.
    You'll have to buy two wheels for the rear. Your rear wheels won't match the front wheels anymore.
    I would highly advise you stick to looking at 07+ rear ends.
    alb1k likes this.
  7. Dec 6, 2022 at 8:52 AM
    When you say rear end, what exactly do you mean? Rear axle and diff? (The assumption) or like, tho whole back end of the truck? The bed?
  8. Dec 6, 2022 at 8:53 AM
    Wheel base shouldn’t matter for the rear axle swap. Just all the problems you’ll have as mentioned above.
  9. Dec 6, 2022 at 8:56 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I think i've read that kieth from dirty deeds is running a 2gt axle under his 1gt. If so, he'd know more about it than the rest of us.
  10. Dec 6, 2022 at 9:27 AM
    07-minus rear-ends you mean. And if OP's truck is a Tundra, skip the Sequoia because they're disc rear, IIRC. And if it's Access Cab or Regular Cab, skip Double Cab because width is different (and vice-versa).
    Unless you like a little pain. But if you really are a masochist and love the pain, there'd be no point in asking this question in the first place, you'd just dive in to get dirty.
  11. Dec 6, 2022 at 9:30 AM
    des2mtn
    SW
    Tonto cover
    No, I do mean 07+ trucks. Why are we trying to downgrade a 2010 Tundra?
  12. Dec 6, 2022 at 9:31 AM
    I think OP is trying to do the opposite: Slap a 2010 rear into a 2004. But maybe they can clarify.
  13. Dec 6, 2022 at 9:39 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Oh, maybe he means the innards? I dont know if the 2gts ever had the '8.4"'. I think they've got a 10.5".
  14. Dec 6, 2022 at 9:50 AM
    michalakd
    2010 Tundra
    What I'd really like to do is find an 010 cab an put it on the 10 but in my there hard to come by
  15. Dec 6, 2022 at 9:51 AM
    michalakd
    2010 Tundra
  16. Dec 6, 2022 at 9:56 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    You're gonna have to ask better questions here.
    Brewster, Tundra2 and alb1k like this.
  17. Dec 6, 2022 at 9:58 AM
    My brain hurts now
    Tundra2, w666, des2mtn and 1 other person like this.
  18. Dec 6, 2022 at 10:02 AM
    Wait ... do you have a 2010, or a 2004? This is the 2000-2006 Tundra/1st Gen forum. The 2007-2013/2nd gen forum is over here: https://www.tundras.com/forums/2nd-gen-tundras-2007-2013.26/
    If you have a 2010, they'll probably be able to help you more easily than us miscreants over here.
    Tundra2 likes this.
  19. Dec 6, 2022 at 10:26 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    While we wait on OP to explain himself, what about swapping a 3.31 3gt axle under a 1gt? anyone know how to find out f&r diff info for the '22?
    KNABORES likes this.
  20. Dec 6, 2022 at 10:39 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This discussion is pointless until we clarify which oil is being used.
  21. Dec 6, 2022 at 10:40 AM
    Depends if mercury is in retrograde
  22. Dec 6, 2022 at 10:41 AM
    alb1k
    Left Coast
    It's good
    And adjust for magnetic north.
    hagrid[QUOTED] and bmf4069 like this.
  23. Dec 6, 2022 at 10:45 AM
    I like turtles.
    hagrid, FrenchToasty and alb1k like this.
  24. Dec 6, 2022 at 10:47 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Toyotas and teslas dont need oil. Water is vegan 0wt.
    bmf4069 likes this.
  25. Dec 6, 2022 at 10:49 AM
    LET'S GO GET SOME SHOES!
    bmf4069 and hagrid like this.
  26. Dec 6, 2022 at 11:00 AM
    There goes the neighborhood
  27. Dec 6, 2022 at 11:07 AM
  28. Dec 6, 2022 at 11:11 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Do'22's have the 9.5/10.5 like the 2gt?
    anyone ever found anything about swapping in a 2gt front diff?
  29. Dec 6, 2022 at 12:30 PM
    michalakd
    2010 Tundra
    Ok let me put this straight iwas going to buy an 04 cheap miles plus blown rear end .neighbor rolled an 010 can get it real cheap an switch REAR ends after reading seems not to promising. Now my other problem is my 02 has no speedometer reading replaced vss took speedometer cluster out looks ok where do you go now to dealer???Need help
  30. Dec 6, 2022 at 12:39 PM
    It can work, it has been done. You would need to figure out the leaf spring and shock mounts in the rear. You would have to figure out the driveshaft interface and the pinion flange. You could get your buddies wheels to use on your truck, would need a wheel adapter to bolt it up to the front. Your gears would not match front to back if 4wd and would have to address that as well.
    shifty` and Mr.bee like this.
