Alignment issue - need some insight
Discussion in 'Suspension' started by nobodyintexas, Dec 5, 2022.
  1. Dec 5, 2022 at 4:37 AM
    nobodyintexas
    nobodyintexas [OP] What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    So my truck started to pull to the right earlier this year.
    So, I took it to my trusted shop to have them align it. They said they did it & he "straightened the steering wheel". I should have know then....
    so, I drove it and it still pulled to the right.
    so last weekend I too it to Firestone to align on the fancy laser "Thrust Line" doo-hicky
    well...that didn't work either and now my steering wheel is botched to the right from the previous trip.
    I'm going to take it back to Firestone to fix. I got the lifetime deal.
    see below....do y'all see anything weird?
  2. Dec 5, 2022 at 12:15 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    What tires?
  3. Dec 5, 2022 at 12:16 PM
    nobodyintexas
    South of Houston
    Michelin LTX stock size
  4. Dec 5, 2022 at 12:16 PM
    nobodyintexas
    South of Houston
    it pulled before I got the new tires.
    they have ~5k on them
  5. Dec 5, 2022 at 12:26 PM
    Saltyhero13
    Gotchya. Sometimes the tread pattern can be a factor. I doubt that is the case with LTXs.
  6. Dec 5, 2022 at 3:37 PM
    bflooks
    bflooks New Member
    Metrowest MA
    nobodyintexas[OP] likes this.
  7. Dec 5, 2022 at 6:25 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Step 1. See if you can get your money back and stop going to Firestone. It’s a toe and go shop.
    Step 2. Find an aftermarket or off road shop that does alignments.
    Step 3. Shoot for 0.5 degrees higher caster on right side. This should help your right hand pull. This is what I’ve had done on my alignments and works well. Your camber and toe look fine but I like to see equal toe left and right.
    nobodyintexas[OP] and rcjh0891 like this.
