2022 AutoStop Disable Kit - Solved
Discussion in '3rd Gen Tundras (2022+)' started by Craigt914, Oct 17, 2022.
  1. Oct 17, 2022 at 5:41 PM
    Craigt914
    Craigt914 [OP] New Member
    Craig
    DFW
    22 Limited LWB
    Apologies up front if this issue has been covered already but I didn't find it after a brief search.
    I am really liking my new '22 Limited, but like others who have voiced their displeasure in the auto shut off function, I too am less than thrilled with this feature. It wouldn't be an issue if it would just stay off for good once it's turned off.
    I'm looking for a kit to disable it, but seems that the kit suppliers haven't gotten around to our new Tundras yet. Has anyone found one?
    If nothing is available, I might consider making one up using a timer relay.
  2. Oct 17, 2022 at 5:44 PM
    Siblue
    Siblue Well-Known Honda Butt Pirate on GRC forum
    22 Tundra Limited
    From all the auto start cars I’ve owned this is the most user friendly one. I have to mash the brake pedal to engage so it doesn’t get much use from me.
  3. Oct 17, 2022 at 7:18 PM
    AZRC
    AZRC New Member
    2022 Limited TRD
    Yeah, that's all fine and dandy, but it still shuts off then turns right back on when put in park whether your foot is on the brake or not. If you disable the stop/start, it does not do that. I would buy a device to disable just to avoid turning my engine off, then on, then off in 3 seconds every time I park.
    Craigt914[OP] likes this.
  4. Oct 18, 2022 at 9:59 AM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
  5. Oct 19, 2022 at 6:41 AM
    Craigt914
    Craig
    DFW
    22 Limited LWB
    This is an awesome write up, thanks for the link! This kit looks to do exactly what I was hoping for, and modifying the connector is no big deal.
    A comment that was made in that thread about disabling the amber instrument panel auto off disabled light. That too would be nice.
  6. Oct 19, 2022 at 7:08 AM
    cain0725
    cain0725 New Member
    i just shut off the fake noise and i cant tell when its on or off.
  7. Oct 20, 2022 at 7:59 AM
    Craigt914
    Craig
    DFW
    22 Limited LWB
    I spoke with Steve @ iocanetech yesterday and he was very helpful. Installing their kit will be about as easy as an aftermarket add on can be. I will be installing this kit and also adding an on/off switch. This will give the option to turn the add on unit off so that things go back to the oem set up when desired, such as for taking the truck in for factory service. I don't want any voided warranty excuses.
    I get it for those of us that this issue is a non issue, but as an industrial technician I can see how this auto stop function will adversely affect the long term wear and tear on key drive line components.
    Now to look into how to turn off the amber instrument cluster auto stop indicator lamp.
  8. Nov 27, 2022 at 6:21 PM
    Craigt914
    Craig
    DFW
    22 Limited LWB
    Finally got outside today to get this mod installed. Like Tom's thread mentioned, I bought a kit for a 2020+ Highlander off of ebay, and with some minor connector trimming it fits right in place.
    https://www.ebay.com/itm/124407498886
    I chose to add a push button switch and mounted it discretely on a bracket mount behind the dash so that the truck's system can be returned to normal operation when I take it into the dealer or what ever.
    https://www.amazon.com/dp/B086QTH8RW?ref=ppx_yo2ov_dt_b_product_details
    Like Tom in the other post, I ended up soldering an extension onto the power wire so that it could reach across the dash to the passenger side where the fuse box is located. Works like a charm.
    OnThaLake and ryanwgregg like this.
