Coolant leak
Discussion in '1st Gen Tundras (2000-2006)' started by robabeatle, Nov 20, 2022.
  1. Nov 21, 2022 at 9:40 AM
    Chris Fix is a lot less annoying than Scottie K.
    bmf4069 and FrenchToasty like this.
  2. Nov 21, 2022 at 10:08 AM
    robabeatle
    robabeatle [OP] New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
  3. Nov 21, 2022 at 10:23 AM
    shifty` You can call 1 (800) PP5-1-DooDoo
    I've caught ScottieK espousing his opinion as fact one too many times to tolerate his BS. I don't like ChrisFix, but at least I don't find myself calling bullshit on things he says the way I do with ScottieK.
    ChrisFix puts out solid content, which I refer people to often, he mostly annoys me because he talks exactly like someone I know IRL and can't f'ing stand (nobody y'all would know), they happen to be from one of my least favorite areas of Jersey, which is one of my least favorite states in the Union b/c of some real low-quality folks I've met from there. No offense to the NJ crowd or anything, believe me, I know GA isn't perfect and we've got some real douchenozzles here, I may be one of 'em. :D
  4. Nov 21, 2022 at 12:04 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I agree that ChrisFix can be annoying, but I also agree that he has solid content. My solution sometimes is to turn down the sound...
    FirstGenVol and shifty` like this.
  5. Nov 21, 2022 at 7:54 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I run the Peak OET pink. Think its $18 a bottle 50/50 mix. You can get concentrate according to the internet but I've never seen it on the shelf. Think a lot of others run some blend of Zerex Asian coolant too though. As others have stated if you don't have pink right now you gotta make sure and flush out every drop.
    shifty` likes this.
  6. Nov 22, 2022 at 7:55 AM
    robabeatle
    AZ
    I will go through the chrisfixit flush when the new radiator arrives (next Wednesday) and hobble along until then.
  7. Nov 22, 2022 at 10:02 AM
    robabeatle
    AZ
    Whoa, radiator already arrived today, but the thremostat wont be here until next week. Any issue with replacing the radiator tomorrow and the thermostat when it arrives? Does it just mean that I will lose some coolant when I go to do the thermostat? Or maybe I should just source the thermostat locally and send back the rock auto one?
    BTW, this forum once again is a life/$ saver. Thank you guys for all the help.
    FrenchToasty and shifty` like this.
  8. Nov 22, 2022 at 10:07 AM
    I'd do them both at the same time. If you can source the part locally, from a dealership, go for it.
  9. Nov 22, 2022 at 10:29 AM
    I agree with this. Even at a stealership, the thermostat shouldn't be too expensive and it will save you work doing both at the same time.
    robabeatle[OP] likes this.
  10. Nov 22, 2022 at 10:46 AM
    robabeatle
    AZ
    Sounds like a plan
  11. Nov 22, 2022 at 10:49 AM
    bmf4069 Captain wtf
    Don't forget the pics. We like pics. Like, a lot.
  12. Nov 22, 2022 at 11:08 AM
    robabeatle
    AZ
    Will do.
  13. Nov 22, 2022 at 5:11 PM
    NickB_01TRD
    KY
    It doesn't hurt to pull your thermostat when doing the flushes/drain and fills. Can speed up the process if the thermostat isn't too hard to get to
    shifty` and FrenchToasty like this.
  14. Nov 23, 2022 at 4:36 AM
    robabeatle
    AZ
    I went ahead and got the thermostat/gasket locally but the store didnt have the upper radiator hose. I am hoping to find that elsewhere today and start the process later this morning.
    shifty` likes this.
  15. Nov 23, 2022 at 6:55 AM
    bfunke
    bfunke Tundra Curmudgeon
    I'm finally getting around to changing the "all vehicle" green antifreeze for the correct one. Looking at Toyota Parts they sell 5 different types of coolants both red and pink. Which is best for 2000 Tundra.
  16. Nov 23, 2022 at 11:56 AM
    robabeatle
    AZ
    Game day
    bmf4069, w666, Mr Badwrench and 2 others like this.
  17. Nov 23, 2022 at 12:25 PM
    robabeatle
    AZ
    lol petcock wings immediately snapped so i removed the lower rad hose to drain. dont do this! i took a little coolant bath
    bmf4069 likes this.
  18. Nov 23, 2022 at 12:54 PM
    Mr Badwrench
    Mr Badwrench New Member
    I am astounded that the radiator made it to you with zero damage. I bought one from toyotapartsdeal.com and it was an absolute mangled mess by the time it arrived.
    Man was I pissed.
    robabeatle[OP] and shifty` like this.
  19. Nov 23, 2022 at 1:45 PM
    robabeatle
    AZ
    Drained
    Fill with water, run 15 min
    Drain
    Fill with cleaner and water run
    Drain
    Fill with water run
    Drain
    Fill with water run.
    Lots of sludge came out but last drain is clear-er.
    Old fluid and drains:
    Time to unbolt rad and get at the thermostat as well.
    FrenchToasty and bmf4069 like this.
  20. Nov 23, 2022 at 2:01 PM
    #50
    If it wasn't already mentioned, did you know about the drain plugs on the engine block too?
  21. Nov 23, 2022 at 2:08 PM
    #51
    robabeatle
    AZ
  22. Nov 23, 2022 at 2:11 PM
    #52
    robabeatle
    AZ
    Tundra2 likes this.
  23. Nov 23, 2022 at 3:17 PM
    #53
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hell yeah!
  24. Nov 23, 2022 at 3:26 PM
    #54
    robabeatle
    AZ
    all set.
    need to go for a test drive.
    that was not hard at all.
  25. Nov 23, 2022 at 3:29 PM
    #55
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Gotcha a label maker, or a piece of scotch tape? I'd put a date, and mileage on it so you know when you changed all that. That's just me though
  26. Nov 23, 2022 at 3:50 PM
    #56
    robabeatle
    AZ
    lol, nope. hope that isnt too big a deal with all the flushing I did.
    Thanks, I keep a spreadsheet of everything I do. Im nerdy like that.
    FrenchToasty and Tundra2[QUOTED] like this.
  27. Nov 23, 2022 at 4:30 PM
    #57
    Not a big deal. But if you end up flushing again I would use the drain plugs.
  28. Nov 23, 2022 at 5:20 PM
    #58
    Meh. Drain plugs are overrated. They're great if you want to fully drain an engine before pulling, but for stuff like this, where you're going to be flushing repeatedly, I feel like it's maybe overkill. Granted, if you did use them, you could probably shave off a flush or two, just because you'd have less contaminated water in the block after each flush.
    Sludge out is GOOD! That's a lot of sludge on the left.
    Hell, I'd have kept going. I'm shocked at how little change there is between each gallon :D
    scAmazon has a 6pk of Prestone flush, product num is AS 105. That's usually what I get for a full flush, and, as much as some people would disagree with me on this, I run the flush with a straight-up hose water. I've seen guys hook up a waterhose straight up to the t-stat housing neck, and leave things open on the other side to flush out (after draining completely and capturing the existing coolant so you don't kill anyone's cat or dog).
  29. Nov 23, 2022 at 5:25 PM
    #59
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'd have used the drain plugs, but that's just me.
    Here's what I got out of the passengers side engine drain using a NPT 1/8" nipple with a hose going into my water jugs.
    This is what I started with though so.....
  30. Nov 23, 2022 at 5:36 PM
    #60
    Damn bro, I forgot all about how much you yoinked out of your engine. But you guys are literally neck and neck. I'd be distraught if I ended up pulling as much brown funk out of my block as you guys both did. Yikes!
    Tundra2[QUOTED] likes this.
