  1. Nov 22, 2022 at 4:36 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    That looks very custom.
    Is it long travel suspension?
    what’s up with the aluminum foil :D
  2. Nov 22, 2022 at 6:15 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    You're too late....it was 15 degrees and all back together. If it's a little nicer in the next week or two I'm going to want to replace that bolt anyway (I'm basically prepping myself to have to drill it out and wreck another few bits, not to mention I'll need a replacement as it's the one that is 'attached' to the lower box from the factory. It did look pretty clean in there when I had it open though...
  3. Nov 22, 2022 at 6:25 AM
    FredB32
    FredB32 New Member
    Fred
    2011 TRD RW
    For anyone with a deck install...how is your Android Auto working? Mine is highly variable...sometimes it'll go for hours without issue, other rides it'll bomb out every 30-seconds to few mins, which is supremely irritating when I'm using Maps and almost to my destination! I upgraded to the high-end high-speed/data cable and I don't think that's the issue. I'm not sure if it's my HU or my phone (I have a Motorola Ace and it's only 64 gb, and has been slow lately, so maybe it's time for a new phone with better storage, although the phone I don't think is even a year old). I've done some research and the only answers have been "get a better cable"...
    Also, since I had my Viper alarm installed, my HU doesn't turn off when it's plugged into the OBD2 port, no real idea why, but the answer I've found was the same as mentioned - add in a resistor. I'm not sure why it worked just fine prior to Viper install, but here we are...I've just left it unplugged in the meantime and have no vehicle data (not the end of the world). I'm leery of plugging it in and forgetting about it and killing the battery...
  4. Nov 22, 2022 at 6:34 AM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    Yeah, it's long travel with glass fenders. As far as the aluminum foil goes:notsure::notsure:
  5. Nov 22, 2022 at 7:14 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I don’t like Android Auto. It won’t auto start and puts the unit in standby mode every time I start up the car and need to manually select android auto every time. I have Galaxy S21 and changed setting on phone to auto connect. I use CarPlay instead with my iPhone 11 and have been working great. I do get the occasional reboots which is annoying.
  6. Nov 22, 2022 at 8:24 AM
    CMikeB
    CMikeB New Member
    I greased the fittings and shot 2 cans of Fluid Film underneath and under the hood. 88,000 miles on this heap and the underside is surprisingly rust-free. 95% of the rust I saw was on fasteners. Also "snugged up" the bed bolts to 80lbs.
  7. Nov 22, 2022 at 8:33 AM
    BEDINTRUDER
    BEDINTRUDER New Member
    Dom
    OHIO
    2011 Tundra RockWarrior (SOLD) 2018 Tundra Limited
    Took a weekend trip out to West Virginia. Pulled good per usual averaged about 8.2mpg
  8. Nov 22, 2022 at 5:40 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    It's the little things. New billet aluminum Mishimoto oil fill cap.
  9. Nov 22, 2022 at 5:45 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    Some pics of today's progress
    B.Ross, wv00097, Marcstryd and 17 others like this.
  10. Nov 22, 2022 at 5:51 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    :yes: #tundragoals
  11. Nov 23, 2022 at 8:01 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    I always use tape, but I'm assuming its to keep slag/splatter from the welder from attaching onto the splines of the CV shaft and ruining it
  12. Nov 23, 2022 at 8:19 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    One more for tonight.
  13. Nov 24, 2022 at 9:55 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    Took me about 2hrs with a few breaks here and there. Very happy with the outcome but probably need to go back and pull the threads a little tighter at some point.
  14. Nov 24, 2022 at 12:51 PM
    Peeeheeuuu
    Peter
    Elk Grove, CA
    Damn that looks good! I will most likely do the same with mines
    Tripleconpanna likes this.
  15. Nov 24, 2022 at 1:36 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    Did the same wrap. Very happy with it!
  16. Nov 26, 2022 at 5:34 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    41632AE8-269F-49A0-AE2F-7F4B7960DDAB.jpg 8D5CBCAC-4FA8-4B24-B03B-5805330FF2B4.jpg 5E6DFD79-321F-4A0B-93F7-C7FAF2513150.jpg E9437EDF-42C2-4CCF-8729-2188B26E3927.jpg ECBFCA83-CE14-45AE-9EAF-2057FB44A205.jpg 5122E445-6FA4-47FD-BA10-4263D22BE897.jpg 81CF0088-93C7-44D7-9CD6-6B3FD36D62B7.jpg I replaced the HU in my 2012 Tundra and am looking to sell my old Sony unit. If you are in the VA Beach area and are interested I’m letting it go for $80 or best offer. It comes with the wiring kit to retain the steering wheel controls. It has Apple CarPlay, front USB port, and volume knob. I live in North Suffolk.
  17. Nov 26, 2022 at 5:59 AM
    BoysandHisToys
    Central Virginia
    What did you swap it out with?
  18. Nov 26, 2022 at 6:17 AM
    Danny3737
    A Kenwood DMX957XR with the Maestro RR. A little pricey, but I really like it.
    EE719DD7-B9CC-420B-B0B5-0DEAEC84C550.jpg 0A46A8B2-3159-4BBF-A4B9-A16D8BA63550.jpg C3832FC7-7660-4A07-9BC2-68666C3CA393.jpg 650128EB-B51E-416C-8700-A01ACAE22C8E.jpg
  19. Nov 26, 2022 at 9:52 AM
    Jaredst
    Jaredst New Member
    2012 Crewmax TRD
    Just purchased her.2012 crewmax Texas truck found in Illinois. Tastefully modified already so going to get all maintenance up to speed. Going to spend hours on this page seeing what everyone’s doing to their truck!
    Prostar 190, WVI, Peeeheeuuu and 9 others like this.
  20. Nov 26, 2022 at 10:02 AM
    joseph_womack
    Joe
    Louisiana
    be careful with that ranch hand bumper, I had the same one on my truck for years, until I found out that it was actually breaking the welds on the bumper mount and causing it to separate from the frame
    and also welcome!! :D
  21. Nov 26, 2022 at 10:03 AM
    joseph_womack
    Joe
    Louisiana
    pm sent
  22. Nov 26, 2022 at 10:07 AM
    Jaredst
    Jaredst New Member
    2012 Crewmax TRD
    Thank you for the heads up! Will definitely take a look at it and make sure it’s good.
    joseph_womack[QUOTED] likes this.
  23. Nov 26, 2022 at 11:44 AM
    Danny3737
    SOLD
    D4x4TRD and MTRock like this.
  24. Nov 26, 2022 at 2:41 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I found my problem.
    D4x4TRD, WVI, chugs and 7 others like this.
  25. Nov 26, 2022 at 2:44 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    :( man that's a shame.
  26. Nov 26, 2022 at 2:47 PM
    careyrob
    Carey
    Massachusetts
    Looks like the rod from cylinder #6 thought it was too stuffy in the crankcase and decided to start the demo for some new windows. That was probably after the valve spring broke.
  27. Nov 26, 2022 at 3:26 PM
    joseph_womack
    Joe
    Louisiana
    dang, valve spring broke causing the valve to fall into the cylinder? I guess the motors being non-interference wouldn't exactly solve that
  28. Nov 26, 2022 at 4:32 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I performed an oil change that dumped oil all over my driveway again but hopefully next time it’ll be easier to get it in the bucket.
    The valve, metal oil filter, filter socket, and funnel are all new and great so far.
    thank you for showing me these gems fellas
    TampaRD Pro, WVI, chugs and 9 others like this.
  29. Nov 26, 2022 at 6:23 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    That's a whole bunch of OUCH right there. sorry to see that.
  30. Nov 26, 2022 at 8:37 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    For those who have installed the oil drain valves, are there any issues with clearance with the factory skid plate?
