  1. Nov 18, 2022 at 8:20 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Are they vertical shakes like a ham candle or are they rotational shakes? Which is the correct way???
  2. Nov 18, 2022 at 8:25 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Takes a combo. And you gotta swirl the ball around in the bottom of the can every now and then.
    CodyP, FrenchToasty and RUSTYNUTS like this.
  3. Nov 18, 2022 at 8:35 AM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
  4. Nov 18, 2022 at 8:59 AM
    daveeasa
    Getting packed for my voyage. Anyone know the socket size for archive garage u bolt flip kit? Got breaker bar, two torque wrenches, 1/4 socket set, trim removal tools, extra keys, wire strippers / crimpers, fuses, butt connectors. Gonna skimp on heat shrink and just bring tape.
  5. Nov 18, 2022 at 9:15 AM
    Am I the only one that does it both ways and even switches hands? I feel like a bartender sometimes.
    CodyP, NUDRAT[OP], shifty` and 6 others like this.
  6. Nov 18, 2022 at 9:20 AM
    The ol' stranger technique
    CodyP, NUDRAT[OP], shifty` and 7 others like this.
  7. Nov 18, 2022 at 9:55 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Yes, and I'll add flip the can upside down for some shakes as well
    Not sure about the archive flip nuts, but I know I got aftermarket U-bolts and they were NOT the same size as OEM[/QUOTE]
  8. Nov 18, 2022 at 12:32 PM
    daveeasa
    Lucky Chris doesn't work on Saturdays :)
    I have 2pm booked right now and my buddy Jeff doing my bidding, friends sure do help out when you need them.
    NUDRAT[OP] likes this.
  9. Nov 18, 2022 at 12:37 PM
    OK, so instead of buying 2 new amps, I'm thinking about getting a 1000/1 v1 slash series amp to match the 300/4 I already have sitting here. Found one on fleabay for $500 shipped. Then I could put the RD 500/1 and shitty Walmart amp in the van, and donate the slash 500/1 to either gf or daughter.
    For the wiring I'll probably just get the Crutchfield 1/0 amp kit, splitter fuse block, and RCA cables.
    shifty` likes this.
  10. Nov 18, 2022 at 2:43 PM
    daveeasa
    Is the 1000 AB or D? I’d go D for subs if purchasing even if it’ll not match.
  11. Nov 18, 2022 at 2:57 PM
    Might need a bigger alternator for that sub if he wants it to shake fillings & house foundations as he cruises through neighborhoods.
  12. Nov 18, 2022 at 3:16 PM
    Are you saying you want the D? :D
    Yeah, its a class D.
    I'm thinking about the 150A alt and big 3 upgrades too.
    txagg, CodyP, Tundra2 and 2 others like this.
  13. Nov 18, 2022 at 3:23 PM
    When I looked up the correct p/n (not sure if one you posted is technically right, I'd hafta look again) it showed clearly as "Discontinued" at the main Toyota Parts site. This could explain the nat'l backorder - they have no plans to remake. I also noticed on fleaBay, there is someone selling a 3rd party tailgate, but it's only for AC sadly.
    Honestly, the Kicker kits are extremely good, I don't think they sell anything that's copper clad/tinned copper, it's all pure copper, O2-free cable. Sonic Electronix carries and usually has great prices already, but will pricematch if you find cheaper. I typically go with the 4awg kit ("CK4") for most normal installs where I'm not using a power distro block. Maybe PKD-1 is up your alley for this install? (link)
    AleHole[QUOTED] likes this.
  14. Nov 18, 2022 at 3:28 PM
    I would do 200A if Denso makes them to fit our truck.
    bmf4069[QUOTED] likes this.
  15. Nov 18, 2022 at 3:51 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  16. Nov 18, 2022 at 3:57 PM
  17. Nov 18, 2022 at 4:15 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Looking to get the metal roof quotes in the spring. :)
  18. Nov 18, 2022 at 4:17 PM
    NUDRAT
    SW CT
    No = Rooster. I live in a city & my neighbor has a danged Rooster. But not for much longer.... :hungry:
  19. Nov 18, 2022 at 4:20 PM
    Those copper roofs are nice and last a good 100 years, but they are $$$.
  20. Nov 18, 2022 at 4:23 PM
    NUDRAT
    SW CT
    I've been blaming that on living on the wrong side of the hill. :notsure:
  21. Nov 18, 2022 at 4:26 PM
    NUDRAT
    SW CT
    1/2 that many if you store the can on it's top.
  22. Nov 18, 2022 at 4:28 PM
    NUDRAT
    SW CT
    I don't wanna deal with replacing the roof when I'm old. Pay twice now, deal with it once.
  23. Nov 18, 2022 at 4:32 PM
    Sunnier
    Sunny
    San Diego, CA
    Good option, when you live in Connecticut. I could imagine the SoCal tweakers ripping off roof panels to resell the copper.
  24. Nov 18, 2022 at 4:35 PM
  25. Nov 18, 2022 at 4:37 PM
    daveeasa
    Jack McCarthy likes this.
  26. Nov 18, 2022 at 4:45 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I didn't know about it until @Mr.bee posted up a link.
    I wonder if it's a legit direct swap for a 2000 to 2002. Using the same oval plug or the square
  27. Nov 18, 2022 at 4:46 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    My buddies integra had 3 tallboy-sized capacitors. What were those doing?
  28. Nov 18, 2022 at 4:49 PM
    daveeasa
    @Mr.bee I'll find out if replacing the part fixes my headlights tomorrow (I hope).
  29. Nov 18, 2022 at 4:52 PM
    Discharging under load, usually, triggered by heavy draw from bass hits.
    Was it a gimmick? A lot of people said "Yes, totally". In concept the model is viable IMO.
    There were other methods used, also. Phoenix Gold had a unit with an array of smaller caps making 10 farad, the "Power Grid", @bmf4069 has my old one today. Pics of that can be seen over here on this forum post.
  30. Nov 18, 2022 at 4:54 PM
    I'm intrigued. Anyone know if the quality is good?
