General Supercharger Thread
  1. Nov 16, 2022 at 10:15 AM
    #4231
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Negative....never once had any issues...
    snivilous[OP] likes this.
  2. Nov 16, 2022 at 10:24 AM
    #4232
    HonorNotInner
    HonorNotInner I speak the 3rd most eyetalian
    Alex
    Fort Worth
    Added money to it.
    Do y’all use the reducer with the 3/8 hose for the intake port on the harrop?
  3. Nov 16, 2022 at 10:32 AM
    #4233
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Mine delivers today...I'll let you know.
  4. Nov 16, 2022 at 10:38 AM
    #4234
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    I’m thinking that may be the issue is I used the 1/2” tube on the intake port because the directions say to do that on the late model tundras. But because of the Harrop is different and not the same size. I don’t think the clamp holds it tight enough so I’m going to try the reducer and use the 3/8” tube on the intake port. But ya when you get into it let me know if you what you think.
  5. Nov 16, 2022 at 10:47 AM
    #4235
    nobodyintexas
    nobodyintexas What?
    South of Houston
    is this the connection just under the inlet snout?
  6. Nov 16, 2022 at 10:52 AM
    #4236
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    Yes, the other port is green that’s deeper in there. It’s kind of tough to get the other hose on there because there’s not much room when the S/C is already installed.
  7. Nov 16, 2022 at 10:57 AM
    #4237
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yup...when I 1st had the S/C installed, the snout connection is what caused my vacuum error. I put a small pipe band on it to make it fit.
    I'll do my best to be more professional when I put the CC in....or not.
    HonorNotInner[QUOTED] likes this.
  8. Nov 16, 2022 at 11:01 AM
    #4238
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    Do you remember if it was throwing P0171?
  9. Nov 16, 2022 at 11:04 AM
    #4239
    nobodyintexas
    nobodyintexas What?
    South of Houston
    don't remember
    but it went away when I clamped that hose under the snout.
    my installer used a flimsy spring tightener and the hose was loose under there. (like you said - wrong size)
  10. Nov 16, 2022 at 11:22 AM
    #4240
    snivilous
    SW UT
    300k+ Supercharged 2008
    Never any issues on mine. I'd run whatever is a tight fit, maybe add some grease or rtv between the nipple and the intake pipe if you think it's leaking there. I also use proper hose clamps for all the connections instead of the factory spring ones.
  11. Nov 16, 2022 at 11:24 AM
    #4241
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    If I remember correctly, the green part is off the PCV and goes into included 3/8” line to the catch can. The 1/2” return line needs to reduce down (with included 3/8” reducer) to connect to port under blower.
    My truck originally had the stock hose from PCV to blower with tons of slop at the snout connection, reusing a spring clamp. I don’t know how it didn’t throw a code.
  12. Nov 16, 2022 at 11:30 AM
    #4242
    ZPhilip
    Philip
    West Chester, PA
    Is the dip stick screwed in? I opened it once with the engine running and was surprised how much vacuum there was.
    Saltyhero13 likes this.
  13. Nov 16, 2022 at 11:55 AM
    #4243
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    He said nipple
    GODZILLA and Saltyhero13 like this.
  14. Nov 16, 2022 at 11:58 AM
    #4244
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  15. Nov 16, 2022 at 12:08 PM
    #4245
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
  16. Nov 16, 2022 at 12:32 PM
    #4246
    Saltyhero13
    Saltyhero13 Throbbing Member
    HulkSmurf14 and Black@Blue19 like this.
  17. Nov 16, 2022 at 12:39 PM
    #4247
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^^^^Holey Moley! WOW
  18. Nov 16, 2022 at 1:38 PM
    #4248
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    You can also start with a non Raptor, gen 2 is mostly the same as normal F150, before getting the Tundra I was ready to do a Raptor Jr (with the 2.7L EB), this thread even has parts list:
    https://www.f150forum.com/f118/2016-f-150-raptor-conversion-402182/
    the 7.3L with supercharger is pretty wild, these guys are logging 4.3s 0-60 with a superduty
    https://youtu.be/LkQI0xOZsoA
    With guys working on turbo kits, I also can't wait what they are going to cook up, may be some proper twin turbo kit.
    https://youtu.be/azds-J_5v6U
  19. Nov 16, 2022 at 1:50 PM
    #4249
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    Thank you. I have a 2019 w/5:29's and 37's, I'm saving my penny's and couldn't see why I wouldn't just go to a STG 2 from the start (knowing myself so well, lol)
    I appreciate the update and the recommendation of Peitz. Mind sharing what the time with Peitz cost you ? Ballpark is fine
    nobodyintexas and Saltyhero13 like this.
  20. Nov 17, 2022 at 9:40 AM
    #4250
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  21. Nov 17, 2022 at 10:42 AM
    #4251
    Black@Blue19
    Ken
    SE Texas
  22. Nov 17, 2022 at 11:30 AM
    #4252
    ssmokedz
    Shelton CT
    This is the first time I've posted in this thread so hi! I've been a slacker. I supercharged my 19 Pro back in March and just have not posted about it. I guess now that the excitement has worn off i have found the time. I am both happy and not. The Magnuson tune is just eh. Primarily i hate how the transmission feels. I've reached out to @ViktorG in hopes that he will take a look at it. IMG_9226.jpg IMG_9225.jpg
  23. Nov 17, 2022 at 11:33 AM
    #4253
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Reach out to these guys and thank me later.
    https://overlandtailor.com/
    Saltyhero13 and M3Tundra-JK like this.
  24. Nov 17, 2022 at 11:36 AM
    #4254
    ssmokedz
    Shelton CT
    I probably should have waited until after Christmas to post in here. You guys are going to make me want to spend all of my money. But thanks i will definitely check it out!
    nags and Saltyhero13 like this.
  25. Nov 17, 2022 at 11:38 AM
    #4255
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yes, yes we will.
    we have a reputation to uphold.
    we also offer quite a portfolio of excuses for the wife.
  26. Nov 17, 2022 at 11:40 AM
    #4256
    ssmokedz
    Shelton CT
    I told my wife the supercharger only cost me $3500. She said wow that's expensive. I've learned to always cut the price of my mods in half.
  27. Nov 17, 2022 at 1:20 PM
    #4257
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Seconded. OTT is doing mine. I've internet-known Justin with those guys for years and he specializes in Tacoma, Tundras, and 4Runners
    reywcms[QUOTED] likes this.
  28. Nov 17, 2022 at 1:29 PM
    #4258
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    OTT did mine also. Also just an update with the 75mm pulley. I’m going to swap out the fuel lines this weekend because I don’t think the stock fuel lines are enough. It gets too lean at the very top. So I’m going to use Viktor’s budget fuel line idea. It’s so close, so we will see if that is enough, if not I’ll swap in the 450 LPh fuel pump and that should do it. It’s probably better to not have the rails daisy chained anyway.
    M3Tundra-JK[QUOTED] and Silver17 like this.
  29. Nov 17, 2022 at 1:52 PM
    #4259
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I would say its the pump not the lines.. What pumps in there now?
    HulkSmurf14 and snivilous[OP] like this.
  30. Nov 17, 2022 at 1:53 PM
    #4260
    HonorNotInner
    Alex
    Fort Worth
    Added money to it.
    The one harrop supplies. I believe it’s 340Lph
    reywcms likes this.
