Installed CALI RAISED sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by LunaPro, Jan 13, 2021.
  1. Nov 21, 2021 at 8:16 PM
    #61
    Darth_cholo
    Darth_cholo New Member
    anybody get quoted on lead times for trail sliders with bedliner?
  2. Nov 27, 2021 at 7:14 AM
    #62
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    They are very capable and will easily support the weight of the vehicle.
  3. Nov 27, 2021 at 9:52 AM
    #63
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Mine took 2.5 months in july.
    Darth_cholo[QUOTED] likes this.
  4. Dec 13, 2021 at 5:10 PM
    #64
    Keithbickford
    Keith
    Seattle
    So they’re spooning?
  5. May 8, 2022 at 9:13 AM
    #65
    rockon34x
    rockon34x New Member
    Just got my sliders installed over the weekend. The only issue I’m having is on the passenger side, the clamp on around the middle of the gas tank (38 gal) is rubbing the tank. Curious for you guys that are running these, did you have any clearance issues around the gas tank?
  6. May 8, 2022 at 9:27 AM
    #66
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Is that the plastic skid plate or the tank itself, I did notch my plastic a little bit.
  7. May 8, 2022 at 1:27 PM
    #67
    rockon34x
    On the actual side on the tank for mine (the silver top bracket that holds it onto the inner C channel)
  8. May 8, 2022 at 1:51 PM
    #68
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    You should be fine, but you could loosen it and square it up a bit if it gives you piece of mind
    rockon34x and MadMaxCanon like this.
  9. Nov 14, 2022 at 9:39 AM
    #69
    Lou-Dogg
    Lou-Dogg New Member
    I purchased the Cali Raised trail version for my 18 Limited with upgraded tank and the guys from Cali raised Off-Road said the sliders wouldn't work because of the upgraded gas tank. They refunded my money. I was so disappointed. I'm currently trying to figure out a solution because I really want those. Option #1 Welding the sliders on, Option #2 moving the gas tank to get the brackets in but the bolt will rest against the tank which may cause issues in the future. Any suggestions or advice from anyone else who had any luck?
  10. Nov 14, 2022 at 10:53 AM
    #70
    MadMaxCanon
    Upgraded gas tank like the 38 gallon oem or did you go with a transferflow or something?
  11. Nov 14, 2022 at 10:57 AM
    #71
    Lou-Dogg
    Lou-Dogg New Member
    Yes, I was referring to the 38 gallon tank. Thank you
  12. Nov 14, 2022 at 11:08 AM
    #72
    MadMaxCanon
    Interesting, I did the install on my 26 gallon tank but dont see why it wouldnt work for the 38 gallon, it would just be harder to install that last bolt but I guess they know their products better than me.
    Lou-Dogg[QUOTED] likes this.
  13. Nov 14, 2022 at 5:24 PM
    #73
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    I installed the step version on my Pro, I did have to notch the plastic tank shield, and that last bolt on the side of the tank was a bit of a pain to get in place, but should work fine with the larger tank.20210206_141341.jpg
  14. Nov 14, 2022 at 5:27 PM
    #74
    Lou-Dogg
    Lou-Dogg New Member
    Thank you for the info I appreciate it.
  15. Nov 14, 2022 at 5:31 PM
    #75
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    You'll definately have to drop the plastic tank shield to get the bolt in, then trim it in one or two places where the new hardware needs a little clearance, but it's just plastic so easy to do.
  16. Nov 14, 2022 at 6:45 PM
    #76
    Lou-Dogg
    Lou-Dogg New Member
    Ok, I’m going to try that. Thank you for all your help.
  17. Nov 14, 2022 at 7:12 PM
    #77
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I had to notch the plastic tank skid in a few spots too. I finally got rid of it and installed a RCI tank skid which fit great, no notching required. I never was able to get the last bolt in though. Something to try at a later date when Incan spend an afternoon under the truck.
    Lou-Dogg likes this.
