  1. Nov 6, 2022 at 6:15 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    I ramped up and power washed the underside to prep for fluid film application tomorrow after it dries. For those who've proactively fought rust before, any advice?
    I got 6 spray cans of Fluid Film and I plan to touch up rusty spots with Corroseal. I previously Corrosealed all rust two years ago but rust resurrected in a few spots.
  2. Nov 7, 2022 at 3:31 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    205k. It was running like new when the alternator went out. So smooth I didn't realize it had died until I lost power steering.
    I changed the oil and filter while I was changing the alternator and there was no 'glitter' in it. There honestly weren't and warning signs. Just a fluke.
  3. Nov 7, 2022 at 3:34 AM
    careyrob
    Carey
    Massachusetts
    No knock until I started it. It caught me totally off gaurd. By the time I got out to listen and figured out what it was it let go.
  4. Nov 7, 2022 at 3:35 AM
    careyrob
    Carey
    Massachusetts
    Anyone got a spare low-mileage 5.7 laying around?
  5. Nov 7, 2022 at 4:09 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    When you changed the filter was the center support tube there? If it broke off in the old filter, then the new filter could have collapsed starving the engine of oil. It’s the only explanation I can think of.
    careyrob[QUOTED] likes this.
  6. Nov 7, 2022 at 4:10 AM
    Bendarrrr
    Bendarrrr New Member
    Baltimore
    2012 TRD off road magnetic grey
    5100’s all 4 corners with Eibach coils and 1-1/2 “ Icon AAL in the rear.
    here’s an easy way to tell. Get under the truck and grab the drivers side cv axle where is attaches to the front diff and see how much play you have. It’s it’s going bad there will be tons of play and alll that play and looseness is the vibration I felt thinking it was a tire. It’s an easy fix just messy.
  7. Nov 7, 2022 at 4:53 AM
    careyrob
    Carey
    Massachusetts
    Nope. Still it there. I remember making sure it was seated correctly in the housing before putting the new filter on it.
  8. Nov 7, 2022 at 10:03 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Washed the car, changed oil, installed fumoto drain valve, greased driveshaft, changed power steering fluid. Should be last of the season since it's starting to get cold.
  9. Nov 7, 2022 at 5:04 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    and you're sure you put oil back in it? Even with no oil I wouldn't expect it to immediately throw a rod... what type of oil have you been running? How many quarts? Intervals on oil changes?
  10. Nov 7, 2022 at 5:26 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Finally installed front TRD sway bar, new end links, and rubber bushings.
    Peeeheeuuu, Red Sonja, WVI and 9 others like this.
  11. Nov 7, 2022 at 7:12 PM
    Tunka
    Tunka New Member
    So cal
    2018 sr5 crwmax
    2.5 leveling kit 30555r20 ko2 fuel assault wheels
  12. Nov 7, 2022 at 7:14 PM
    careyrob
    Carey
    Massachusetts
    There's 7.4 quarts of clean Mobil 1 (0w-20) on my driveway right now. 5k mile intervals.
  13. Nov 7, 2022 at 7:50 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    What a bummer
  14. Nov 7, 2022 at 8:15 PM
    Retroboy1989
    Northern Utah
    Sorry for the horrible luck. I've been under the impression that these are 300k mile trucks.
    It had to be some kind of a defect. Id be curious to see what the bearing and crank look like. Maybe the cap or a cap bolt failed.
  15. Nov 7, 2022 at 11:18 PM
    joseph_womack
    Joe
    Louisiana
    300k+ you mean ;)
  16. Nov 8, 2022 at 12:01 PM
    joseph_womack
    Joe
    Louisiana
    damn, maybe get it over to a shop (if you can't do it yourself) and see if them can tell you what went wrong?
  17. Nov 8, 2022 at 12:50 PM
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    Bilstein 6112’s & 5160’s
    Did Cylinder #7 throw a rod?
  18. Nov 8, 2022 at 1:27 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    oem
    With SPC adjustable UCA’s and Coachbuilder outter tie rods, and the oem splash shields removed
    Oem UCA exposed ball joint for those interested
    With ARK splash guards installed
    how much clearance I have with the Coachbuilder’s and tires.
    Just waiting on the Amazon van to arrive with the 31mm or 32mm socket required to torque down the UCA top nut.
    Dropping it off at alignment shop at 0700 tomorrow assuming the socket works.
    Other than a 31mm or 32mm nut I would recommend having a 22mm wrench; long & box ended or whatever would be preferred bc I had to use giant vice grips and a breaker bar which sucked.
    I’m also waiting on a grease gun to arrive so I can fill and then maintain the tie rod heim joints as well as zerk UCA ball joints. New toys to play with!!
    :yes:
    It took me yesterday and part of today to finish bc I didn’t have all the proper tools and I go slow and am meticulous when doing things that involve holding the wheels on.
    btw, 173 ft lbs of torque really is a doozy but I got it done solo in the driveway so anything is possible
    Prostar 190, 07 Tundie, WVI and 8 others like this.
  19. Nov 8, 2022 at 1:43 PM
    BlueCrushSC16
    Charleston, SC
    The cap for the trailer harness I installed a couple years ago came off because the hardware had rusted away. Replaced it with the much better updated design that comes on most trucks these days. I wrapped and loomed the wire harness before I installed (not shown). I didnt know the Hooke Road bumper cut out fit the 41144 plug design or I would have just gotten that one back in 2020.
    07 Tundie, Skew12, omgboost and 8 others like this.
  20. Nov 8, 2022 at 4:50 PM
    TheBeast
    TheBeast The Beach
    basic maintenance:
    oil change: 8.4 QT of Kirkland 0W-20/ Toyota oem filter.
    New Michelin Guardian wiper blades / costco special..
    omgboost, Mountun Goat and MTRock like this.
  21. Nov 8, 2022 at 5:46 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Got the LCA's removed and old bent Cam tabs out and cleaned up. Then spent the rest of the time welding up and getting ready for install Total Chaos Cam Tab Gussets. First time in 11 years since I've picked up a welder :rofl: kinda was fun suiting up in my gear again.
    Half Assed, wv00097, WVI and 13 others like this.
  22. Nov 8, 2022 at 6:20 PM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    7.4 or 8.4 on that 2012?
  23. Nov 8, 2022 at 6:55 PM
    Retroboy1989
    Northern Utah
    2012 is 7.9.
  24. Nov 8, 2022 at 8:57 PM
    omgboost
    East Coast
    I just put in a tad over 8 qts yesterday and it registers a bit shy of max on the dipstick on my 2012.
    TheBeast likes this.
  25. Nov 8, 2022 at 9:54 PM
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Installed some Seat Jackers and a Decked system I found on Craigslist. Pretty excited about both so far.
  26. Nov 9, 2022 at 4:24 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Does your alignment tech know how to use the cam tabs?
    I ask bc I just dropped mine at Tires Plus and the guy said he has never seen adjustable UCA’s like the SPC’s I just put on, which was exactly what I was afraid he was gonna say. Then he said they only do OEM specs even though it’s lifted. :eek::eek2::confused:
    joseph_womack likes this.
  27. Nov 9, 2022 at 12:29 PM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    Technically it drives better than it did before I drove it to tires plus, but the alignment specs looks like they did nothing.
    i guess I should find an off-road shop that does alignments, not really sure
  28. Nov 9, 2022 at 2:09 PM
    TheBeast
    TheBeast The Beach
    8.4 put me right in the middle of the dip stick.
    I usually put 8QT then drive the truck around then adjust dip stick.
  29. Nov 9, 2022 at 2:17 PM
    Danny3737
    I have a 2012 Platinum 5.7 and 7.9 puts me at the full mark
  30. Nov 9, 2022 at 2:33 PM
    TheBeast
    TheBeast The Beach
