  1. Nov 2, 2022 at 1:55 PM
    Casper421
    In the woods
    06 DC
    I buy them through work and only pay around $40 for shipping.
    RUSTYNUTS likes this.
  2. Nov 2, 2022 at 2:10 PM
    oscardog86
    oscardog86 New Member
    Southern California
    Since we've talked about fitting bigger tires in this discussion recently, I happened upon a pretty interesting and informative video yesterday that I figured id share with you guys. Most of you guys probably already knew this but I learned a thing or two. Makes me want to really try to flex out my truck offroad and see how my 33s "fit"
  3. Nov 2, 2022 at 5:17 PM
    Tire Rack. Last three orders I've made with them, it was free shipping, and maybe b/c I'm in the city, they have mobile mount/balance/install for about the cost you'd pay for shipping. Big difference is, I can sit on the porch and have a damn beer while I watch. Always kick your installer an extra $20!
    w666, Siebler, oscardog86 and 3 others like this.
  4. Nov 2, 2022 at 6:58 PM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    They are in his profile picture
    bmf4069 likes this.
  5. Nov 2, 2022 at 8:55 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Those are attached with resistance welding most likely. We use those on our body mounts here. Parts sit on a ground electrode then the positive electrode is on a cylinder. Positive comes down touches the nut then blasts a bunch of current through the part and the corners are all that make contact so it fuses the nut to the part. They are then welded in one spot in the assembly line to make sure they don't fall off either. Seems like the later would have benefited the tundra frames too.
    5N0W808, des2mtn and oscardog86 like this.
  6. Nov 3, 2022 at 7:20 AM
    Well @Jack McCarthy while I was going through my CC statement for this month, I looked back and remembered: My fill-up about 1/3 tank prior to throwing the knock sensor code was at a chain grocery store that also sells gas and has had problems with bad gas in the past. I only got it there because my normal station was having their tanks serviced and the only 2 pumps open had a line.
    Needless to say, I was able to eat through it, then got gas at my normal Shell station earlier this week. I've put around 250 miles on the truck since initially throwing the code, and it hasn't reappeared; if it was an actual knock sensor issue, I'd have expected it to return by now, or to see at least some sort of symptom. I guess maybe you were right, and it was bad gas after all?
  7. Nov 3, 2022 at 2:10 PM
    Casper421
    In the woods
    06 DC
  8. Nov 3, 2022 at 5:21 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Just keeping the old gal all lubed up. Some much needed maintenance
    NUDRAT, hammeron, oscardog86 and 7 others like this.
  9. Nov 3, 2022 at 5:47 PM
    Casper421
    In the woods
    06 DC
  10. Nov 3, 2022 at 6:57 PM
    What size did you end up going with this time? 285/75/17?
  11. Nov 3, 2022 at 7:26 PM
    Casper421
    In the woods
    06 DC
    Yeah, back to 285/75r17.
  12. Nov 3, 2022 at 9:18 PM
    Casper421
    In the woods
    06 DC
  13. Nov 3, 2022 at 10:43 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    What's the plan with those 35's? Those bad boys are just about brand new right?
  14. Nov 3, 2022 at 10:45 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Aero tape like a real nascar.
  15. Nov 3, 2022 at 10:54 PM
    Casper421
    In the woods
    06 DC
    Gonna sell them. Haven’t checked but they have less than 5k on them.
    Adds 5mpg! Grill cracked a few winters back, surprised it took this long for someone to point it out. It’s on the “to fix” list.
    5N0W808, des2mtn, txagg and 2 others like this.
  16. Nov 3, 2022 at 10:56 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Aero tape adds 5hp
    txagg and Mr.bee like this.
  17. Nov 4, 2022 at 12:12 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    hhaha. I saw the 'just say fuck it and duct it' repair work too, didn't wanna mention it as I was hittin you up bout them 35's...
    5N0W808 and Casper421[QUOTED] like this.
  18. Nov 4, 2022 at 4:15 AM
    NUDRAT, Tundra2, FrenchToasty and 5 others like this.
  19. Nov 4, 2022 at 5:49 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I thought my headlights looked pretty clear until I compared them to the new ones...
  20. Nov 4, 2022 at 6:10 AM
    Not that it's anything to brag about, but I think I got you beat on the haze :D there's a before/after polishing at the end of this wall of text here.
    But to take that a step further and show how much the lenses degrade with time, even after polish, check the last pic here.
    When you see the fully-polished lens sitting above the original OEM lens, it really shows how there's (sadly) no substitute for replacing them every 10-20 years...
  21. Nov 4, 2022 at 6:35 AM
    zoomspeed05
    zoomspeed05 New Member
    marc
    2006 tundra double cab sr5 4WD
    love this whole setup
    Casper421[QUOTED] likes this.
  22. Nov 4, 2022 at 6:37 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    So will he if his tires don't rub.
  23. Nov 4, 2022 at 8:17 AM
    Casper421
    In the woods
    06 DC
    Lol Hey sparky! Yeah, those are dead. A lot of empty conduit in this old shop. We still haven’t completely finished demolishing the second floor. We made enough room for another lift then saw something shiny and got distracted. My life is full of half completed projects!
  24. Nov 4, 2022 at 8:38 AM
    Casper421
    In the woods
    06 DC
    It’s amazing how heavy and huge those 35’s were! These falcons drive great and I love this size. Less turning resistance, no vibration and they’re not squared off. Gonna align it later today, kick back on the caster which will improve the camber. Should drive like a…well lifted tundra. With the solos I shouldn’t rub but I’ll test that out next weekend. Picking up the new trailer tomorrow!!
    bmf4069, txagg, FrenchToasty and 4 others like this.
  25. Nov 4, 2022 at 9:11 AM
    w666
    Maryland
    Right! I had polished them a year or so ago, and they were OK for a while. This time around I went for new (TYC ~ $40 side) and spent a fraction of the time installing that I would have spent sanding, polishing, coating, etc.
    oscardog86 and shifty`[QUOTED] like this.
  26. Nov 4, 2022 at 9:22 AM
    w666
    Maryland
    Now that I have clear lenses, I upgraded to Katana LEDs.
    First I installed the headlights. Predictably my fogs stopped working, and the switch for the fogs now controlled my brights!. I asked Katana support for resistors, and they graciously provided them (they sent 2 harnesses) at NO CHARGE!
    I installed one on the passenger side headlight, and the problem was solved. Now that the headlights and fogs were working as intended I installed the LED fogs. Everything still worked as intended. The headlight LEDs were fixed, and required no clocking. The fog LEDS were clockable, and indeed need to be oriented so that the beam spread horizontally.
    When it's dark I'll try to get a picture of the spread. I may need to tinker with the alignment as well.
    bmf4069, txagg and RUSTYNUTS like this.
  27. Nov 4, 2022 at 9:30 AM
    Would you know if they make aftermarket LED headlight reflectors for our trucks to better focus the beam? I assume yours are just stock replacements?
  28. Nov 4, 2022 at 9:40 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Calling all Alignment experts and just some help in general. Just got my baby aligned. Drives great! And all just Caster is way off and tech is not sure why, he thinks its the UCAs that are too tight. Any suggestions?
    oscardog86 likes this.
  29. Nov 4, 2022 at 10:10 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Take pics of the adjusters.
  30. Nov 4, 2022 at 10:11 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    The cam bolts? If those, they're currently maxed out. As per the tech.
