While I was doing a valve cover gasket change….
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Oct 28, 2022.
  1. Oct 30, 2022 at 6:18 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    There's some question about the contents and whether it should be used as an oil additive. It is, however, a good penetrating oil and has a long history in radio controlled aircraft and car engines as an after run oil to prevent corrosion.
    https://en.wikipedia.org/wiki/Marvel_Mystery_Oil
    shifty`[QUOTED] likes this.
  2. Oct 30, 2022 at 6:24 PM
    Weagle likes this.
  3. Oct 31, 2022 at 9:56 AM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Many years ago I worked as an aircraft mechanic. I worked in mainly
    Radial engines. Most of the work was resurrection of parked and pickled
    obsolete Military warbirds. The owner used to get a gallon of Marvel Mystery
    Oil. He removed every spark plug and sprayed in the oil. Not a lot, maybe 3 pumps.
    when it got time to start the engine, the MMO really smoked. We never had a cylinder
    not come back to life after decades of sitting. Considering the length of inactivity,
    the pre oil really worked.
