GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Oct 20, 2022 at 8:40 AM
    #1531
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Looks great. Not only do the stock Falkens look small, the tread depth is weak. Good looking setup, if no rub then I see no reason to do spacer lift.
    pnw.tundra[QUOTED] and Unitdosed like this.
  2. Oct 20, 2022 at 9:02 AM
    #1532
    gr8fasushi
    gr8fasushi 22 Tundra Limited TRD Off Road
    I recently swapped wheels from the RRW RR-6H wheels with 0 offset to the Method 703 wheels with +35 offset. It reduced the aggressiveness which is what I wanted, and now I don't have such a severe poke. Everything clears except for front sway bar rub at full lock. I think I'll live with that for now. I don't really want to put wheel spacers in and use extended thread lug nuts.
    Yaboy and pnw.tundra like this.
  3. Oct 20, 2022 at 12:06 PM
    #1533
    philbo32
    philbo32 New Member
    2022 Tundra TSS SR5
    Did you have to level or lift for this size tire?
  4. Oct 20, 2022 at 3:01 PM
    #1534
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    What are the stock Wildpeak’s worth from a Pro? I plan on selling mine next week when my Nitto’s arrive. $200/tire?
  5. Oct 20, 2022 at 3:57 PM
    #1535
    Scruffy_Nerf
    Scruffy_Nerf New Member
    2022 Toyota Tundra SR5
    OEM wheels with KO2s (265/70/R18)
    Before:
    After:
  6. Oct 20, 2022 at 4:26 PM
    #1536
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    How does the ride compare?
    Also, I'll go ahead and be the one to ask about the double set of rims...
    Double set of rims for seasonal swap?
  7. Oct 20, 2022 at 4:39 PM
    #1537
    Scruffy_Nerf
    Ride quality is good. Fuel economy is a bit down.
    Your guess is right about the double set of rims. KO2s are for winter and shoulder seasons. Yokohamas are for summer road-trips.
    Unitdosed[QUOTED] likes this.
  8. Oct 21, 2022 at 3:34 AM
    #1538
    ytank1
    ytank1 New Member
    MD
    That looks tough!!!
    Thanks
    One more question before I pull the trigger
    UCAs, how close or how much clearance between the UCAs and the tire
    Thanks again
  9. Oct 21, 2022 at 9:16 PM
    #1539
    ToyoBo
    ToyoBo New Member
    2022 Tundra
    method 316 18x9 +18
    Mickey Thompson Baja Boss A/T 35x12.5r18 load D
    dragokvm, Yaboy, Helo and 2 others like this.
  10. Oct 21, 2022 at 10:27 PM
    #1540
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Looks good. What lift?
    ToyoBo[QUOTED] likes this.
  11. Oct 22, 2022 at 6:37 AM
    #1541
    ToyoBo
    ToyoBo New Member
    2022 Tundra
    R4T custom westscott lift. 3/1 5/8
    iiawah808 likes this.
  12. Oct 22, 2022 at 6:47 AM
    #1542
    2000army
    2000army New Member
    CT
    Would you have gotten by without a lift?
    Unitdosed likes this.
  13. Oct 22, 2022 at 9:07 AM
    #1543
    ToyoBo
    ToyoBo New Member
    2022 Tundra
    I have a slight rub at full lock but I think it’s from to much caster.
  14. Oct 22, 2022 at 7:58 PM
    #1544
    Snomej
    Snomej New Member
    Justin
    2022 Celestial Silver Platinum
    Nothing terribly exciting, but figured I’d add to the stock wheel gang pics. 35x11.5 Toyo OC AT3’s on stock Platinum wheels, Rough Country 1.75” leveling kit as well. Just done today, so no wash yet.
  15. Oct 24, 2022 at 8:47 PM
    #1545
    minh
    minh New Member
    Westcott 3/1, KMC KM724 17x8.5 +0, Toyo AT3 35x12.5
    dagsom, Helo, Alexstundra and 7 others like this.
  16. Oct 25, 2022 at 7:22 AM
    #1546
    3GStormTrooper
    3GStormTrooper New Member
    Huntsville, AL
    2023 Tundra TRD Pro - White
    That is a great looking combo.
  17. Oct 25, 2022 at 7:22 AM
    #1547
    3GStormTrooper
    Huntsville, AL
    Meant to ask, how's your ride quality post the Westcott lift? Any noticeable changes one way or the other?
  18. Oct 25, 2022 at 10:56 AM
    #1548
    minh
    minh New Member
    Not too bad! I honestly have not noticed any negative in ride quality, I’m sure there are some but not enough for me to notice or care
  19. Oct 27, 2022 at 2:35 PM
    #1549
    ytank1
    ytank1 New Member
    MD
    Went to a local shop to purchase and install some 35s
    Was advised that 35X12.5x18 will rub on the UCAs and I will have to install some spacers to clear
    I know I've seen some guys on this thread with 35s no lift or spacers
    Any pics of the clearance/space between the 35 and the UCA without lift/spacers you guys can post please
    Thanks
  20. Oct 27, 2022 at 4:52 PM
    #1550
    minh
    minh New Member
    You’ll likely need 11.5” wide instead of 12.5
    ytank1[QUOTED] likes this.
  21. Oct 27, 2022 at 4:57 PM
    #1551
    Breathing Borla
    Northern Illinois
    be cool to color match those flares, that would make the wheels and tires pop, looks good!
  22. Oct 27, 2022 at 4:59 PM
    #1552
    Breathing Borla
    Northern Illinois
    thanks for those pics, Im trying to decide if I want to stick with the stock wheels for an upcoming purchase. They are growing on me a bit but leaning towards the TRD off-road black ones that come on limited.
    I did see one guy who switched the lugs to black on a set-up like yours and it really made a nice difference
    Snomej[QUOTED] likes this.
  23. Oct 27, 2022 at 10:34 PM
    #1553
    Defector7
    Defector7 New Member
    Eastern ID
    2022 Black Tundra SR5 Crewmax 6.5’ Bed
    Has anyone tried these and know if they fit? Or any pictures available of them mounted on their tundra? F13375F4-235E-4BC2-A364-FE75EB55D231.jpg91CC763E-DA2D-4A40-A499-DF00BF3541EC.jpg
  24. Oct 28, 2022 at 6:47 AM
    #1554
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    They will fit but the offset is very aggressive and the tires are 2 sizes too small imo
  25. Oct 28, 2022 at 7:56 AM
    #1555
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    I agree with the above also they are only 7 inches wide so that really limits the tire sizes you can put on em
    Yaboy[QUOTED] likes this.
  26. Oct 28, 2022 at 5:22 PM
    #1556
    photowil
    photowil New Member
    Wil
    2022 TRD OR
    Dang it... thought I was getting a sweet deal on these TRD Pro take-offs, but the OEM-spec Falkens make it more like TRD Faux. No mtn/snowflake icon like the Wildpeaks I've been buying for three years. Good thing it doesn't snow much anymore....IMG_4103.jpg
  27. Oct 28, 2022 at 5:58 PM
    #1557
    Snomej
    Snomej New Member
    Justin
    An 18” wheel would certainly look a lot more aggressive with all of the meat! I achieved the desired look I was going for, just a little more brawn. If you plan on wheeling, the TRD OR wheels would certainly be better, but if you’re not getting a killer deal on them, maybe a set with a lower or negative offset? I’d hate to see the +60’s (I believe that’s what they are) after navigating rocks
  28. Oct 30, 2022 at 6:41 PM
    #1558
    Odithtfg747
    Odithtfg747 New Member
    2022 SR5
    Swapped for some SR5 OR wheels and did General Grabber ATX in the non-E rated 275/70/18 size. Not super aggressive but should be better for dirt roads and snow here in Utah.
    Love this truck
    Siblue, AND, ytank1 and 4 others like this.
  29. Oct 31, 2022 at 4:46 PM
    #1559
    AverageAZN
    AverageAZN New Member
    Austin
    2004 Toyota Sequoia
    OME/Dobinson long travel lift, 34s
    Are the front brakes on the hybrid larger than the non-hybrid? Will 17" wheels clear the calipers?
  30. Oct 31, 2022 at 7:32 PM
    #1560
    Adam_1794
    Adam_1794 New Member
    MA
    22 1794 Metallic Black -Tow package/AVS/Air
    295/70/18 ATIIIs arrived this weekend, METHOD 705s ETA is tomorrow! More to come
    vichmr, ytank1, Yaboy and 1 other person like this.
