  1. Oct 24, 2022 at 5:34 AM
    TheDarkside
    TheDarkside New Member
    Georgia
    2021 Trail Edition Tundra
    Defender flares, Barricade HD Stubby Bumper, front black Bumpershellz, graphics, undercover LX tonneau cover, interior chrome delete, custom seat covers, desert eagle cat shield, JL Audio speaker/amp upgrade from Tech12volts, TRD Pro grill…
    Got the JL Audio system installed this weekend by Tech12volts.com and it is amazing!!!!!IMG_5286.jpg IMG_5289.jpg IMG_5292.jpg
    Ace96, GarTX526, rebmo and 14 others like this.
  2. Oct 24, 2022 at 6:23 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Yeah Casey, I did not have any for quite a while and starting to here the noise the one day. I don’t think it’s anything else. It don’t bother me as of now so I can wait till I get it in for its next oil change.
  3. Oct 24, 2022 at 7:08 AM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    :rofl::rofl::rofl::rofl:at the Biscuits and Porn sticker! I know that place in the OBX
  4. Oct 24, 2022 at 11:41 AM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    It doesn't look like you used the new hardware at the plate joint. How did you tighten the 2 carriage bolts?
  5. Oct 24, 2022 at 12:51 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    I did nothing to my truck... I did drive the wife's highlander on a road trip, and was in heaven seeing 25mpg
    Velocity72 and Tripleconpanna like this.
  6. Oct 24, 2022 at 3:07 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    I was able to get the passenger side plate joint carriage bolt from the passenger side in front of the crossmember with a ratcheting wrench and the driver side one I had to remove the front section of the engine skid plate and reach back from the front to get access to it with a ratcheting wrench also. It wasn’t that much more work and I’m glad I have the carriage bolts there instead of the hex bolts with the retro fit bracket and speed clips. Both of the plate joint bolts are easily accessible to tighten once the front section of the engine skid plate is removed. I didn’t think of that until I realized that was my only option to gain access to the driver side plate joint bolt. I did have to remove the oil filter access plate to get the middle front skid plate bolt, you can get to the other two from the side
  7. Oct 24, 2022 at 5:54 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Drove by a Prius today that was louder than my truck. Made me really thankful for my cat plates :spy:
  8. Oct 24, 2022 at 6:10 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Took it to the dealership to get a 4 wheel alignment. Quoted $199. Told them I need new tie rod ends too as the boots were compromised. They couldn't even do the alignment. They came back with a quote with the grand total of over $1000. $157 for EACH tie rod end and $762 for labor (including the alignment.
    I just ordered a pair of tie rod end on Amazon for $58.
    https://smile.amazon.com/gp/product/B07JDTP7YT?ie=UTF8
    Jcmf52 and welshmike like this.
  9. Oct 24, 2022 at 6:15 PM
    you might be disappointed with those. I’ve had to replace a set of non-OEM tie rod ends after 2 months. Pretty hit or miss with the “other” options.
    Tripleconpanna likes this.
  10. Oct 24, 2022 at 7:23 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    What dealership did you go to?? Those tie rods should only be an hour of labor for install
  11. Oct 24, 2022 at 7:33 PM
    Baja Mike
    South Bay, Ca.
    DCH Toyota in Torrance.
    I'm gonna do the tie rod end myself then get it aligned. It's not like the truck is pulling to one side, it's just that there's some noticeable positive camber.
  12. Oct 24, 2022 at 8:42 PM
    SAGE63
    San Diego County
    Coach builder for the win...
  13. Oct 24, 2022 at 9:23 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    Alignment done, picking up tomorrow morning. Looks like I gotta do the front fender liner mod and a CMC since the tech said it rubs at tight turns. Not sure how bad the rubbing is as the tech wasn’t overly descriptive
  14. Oct 25, 2022 at 4:45 AM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    You should call the toy shop in cypress. They specialize in toyotas and lexus. Idk if the also do alignments there but they can do the tie rods for way cheaper tha. The dealer
  15. Oct 25, 2022 at 7:22 AM
    BarcelonaRedTundra
    BarcelonaRedTundra New Member
    Rotors and pads.
    No more shaking!
  16. Oct 25, 2022 at 7:25 AM
    Best color ever!
  17. Oct 25, 2022 at 10:41 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Diggin the paint cans for the assist!
    Voda48 and cartage1 like this.
  18. Oct 25, 2022 at 11:45 AM
    colenation
    colenation What’s next?
    Cole
    Alabama
    2018 Tundra TRD Sport
    Readylift 4”F/2”R SST LIFT Kit Fuel Sledge D595 (20x9 +20) Thunderer Ranger A/TR (35x12.5R20) Havoc HS2 black hoop steps
    RainMan_PNW and SAGE63 like this.
  19. Oct 25, 2022 at 12:28 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Lunch break mod today just switched over to the AFE pro5s dry air filter.
  20. Oct 25, 2022 at 1:22 PM
    Cthulhu
    You have probably never in your life uttered more ridiculous words...but...that is one of the most well cared for, mirror-finished, beautifully bumpered, sharpest trucks I have seen on this, or any other, forum. :bowdown:
    Other than the color...that's just dog shit. :rofl:
  21. Oct 25, 2022 at 1:39 PM
    :D :rofl:
  22. Oct 25, 2022 at 2:32 PM
    Baja Mike
    South Bay, Ca.
    Cypress is a bit of a drive but you just reminded me of a Toyota/Lexus specialist near my parents house.
  23. Oct 25, 2022 at 3:31 PM
    1794TX
    Steven
    N.TX
    '20 1794
    If you haven't already, or don't already know - if you want to keep your fender plastic intact, you can shim out the front bumper with these:
    Coachbuilder Front Bumper Shim Kit Tundra 2007-2021 ( Including TRD Pr – Shop Coachbuilder (shop-coachbuilder.myshopify.com)
    I have them, and they'd allow the bumper to accommodate a little larger tire and/or wider offset than my 285/60/20's on +50 offset wheels.
    Also; that truck is smokin hot.
  24. Oct 25, 2022 at 3:33 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    Yeah I already have them installed, also removed the mud flaps. I think just need to remove the bolts, push the fender liner forward and drill new holes. Hopefully I can have the caster adjusted to give some more clearance on the rear cab mount
    1794TX[QUOTED] likes this.
  25. Oct 25, 2022 at 3:52 PM
    :monocle:
    Sean492 and Vr0ck like this.
  26. Oct 25, 2022 at 4:27 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Final wiring, nmo antenna and rain cap arrived. Still waiting on the lights but those should be here end of the month first week of Nov. Unless I get impatient and go to local place lol
    rdiddy5, Cthulhu, mgm16trdpro and 7 others like this.
  27. Oct 25, 2022 at 6:52 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    Minor rub on the body mount and the front fender liner. The liner I can do the cut and drill new holes and that should take care of that. Cab mount will need to be chopped for proper clearance
    pvn.beluga, reywcms and bulldog93 like this.
  28. Oct 25, 2022 at 7:45 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What’s your wheel offset and tire size?
  29. Oct 25, 2022 at 9:15 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    zero offset 17x8.5” tires are 35x12.5
    pvn.beluga and ZPhilip[QUOTED] like this.
  30. Oct 26, 2022 at 6:12 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Get more caster out of your alignment. I have the same 17x8.5 with 0 offset on 35x12.5s and don’t rub the body mount.
    JCBerb and AZEric like this.
